WD40 and heat for steel plate rust prevention?
What's the process for doing this? Need to do this to my 1/2" plate table top.
Ran a search but probably did a lousy job of it.
Hobart EZ-Tig newbie. |
Re: WD40 and heat for steel plate rust prevention?
http://www.fluid-film.com/products/ |
1/2" is pretty thick, and should last quite a long time outside. I've got a 1/4" top on my welding/work table and it may corrode down to 3/16" by the time I'm 90yrs old
![]() The real key with steel is how long the water sits on the surface. If it's well drained you generally will get long service life out of it. Of course this might vary, as in the Eastern part of the country with all the industrial air pollutants. Leaving pieces of scrap laying on the table will trap water between the scrap and table top after a rain too. Anyways, any mechanicing work you do on the table will coat it with enough grease to prevent all but atomic salt water from rusting it
Fortunately, the table is inside.....just being picky about protecting it is all. Don't want to paint it because of the welding and other work that will be done on it.
May end up just leaving it as is with the scale on it. Not sure.
I was doing some forge work awhile back and noticed the wd-40 turning the fresh from the forge metal black. I think you have to get it red hot for it to work.
The metal was coolish when I sprayed it then it sat in the Az summer sun. Turned black in a few hours. When the job was ready for powder coat there was no rust to be found. Not sure why it worked but that's what I saw.
From the desk of Kevin Caron Where the answers are stranger than the questions. www.kevincaron.com Longevity TigWeld 200EX Longevity MigWeld 250p Longevity ForceCut 60I Longevity MIgWeld 140 MillerMatic 250 Miller Syncrowave 200 |
Fluid Film is great stuff, but stays soft and could be messy on a work surface. Great for storage, though. Try some Johnson Paste Wax. That is what many woodworkers use on their table saws.
First-born son: KIA Iraq 1/26/05 Syncrowave 250 w/ Coolmate 3 Dialarc 250 SP-175 + TA 161 STL Lincwelder AC180C (1952) Victor & Smith O/A torches Miller spot welder Clausing 5904 lathe Wells-Index 745 mill |
If you do much welding you will find yourself running a grinder or flapdisk over it often enough to remove tacks and spawls that it will probably always be shiny keeping it inside. The last thing I want is oil smoking out of my welding table every time I get it hot...
You can use phosphoric acid to neutralize the rust and convert it from rust oxide or iron oxide. Im not sure if it reacts to heat from welding, but it works great for a few months before the rust shows up again.
I break things for a living... |
I don't know if you get any Lanolin based products over in the US but, this is by a long shot, the best on the market....Hands down.
Make sure you read the anti-spatter properties....arrow down. http://www.lanotec.com.au/pages/industryuses/industrial Looks like Fluid Film, posted by GWD may be similar if not the same....Woolwax?? Sounds like Lanolin to me....Yup, just Googled....same.
********************************* CIG 320SP pulse mig Mitech ACDC315P Samson 510 CNC plasma table Hypertherm 85 Etc, etc,etc. "You don't stop laughing when you get old....You get old when you stop laughing". Last edited by Mick120; 07-20-2012 at 07:18 PM. |
Love the smell of Lanolin. Reminds me of wet sheep.
Ops, let the cat out the bag.
Kemppi Pro Evolution 4200 ![]() Kemppi 530 wire feed with MXE panel Cigweld TransTig 200 AC/DC Hypertherm PowerMax45 CutSkill O/A setup Speedglas 9000x adflow Speedglas 9100xx 2 Labs All at home! |
on cast iron surface plates,talc (baby powder) worked great. haven't tried it on steel.
miller thunderbolt 250v lincoln square wave tig 175 pro lincoln idealarc mig sp250 everlast tig 210EXT everlast power plasma 50 chicago electric (hf) 130 tig/90 arc chicago electric 90 amp flux wire 3 sets oxy/acet |
Jeez Lazza, didn't take you for a gumboot wearer......
********************************* CIG 320SP pulse mig Mitech ACDC315P Samson 510 CNC plasma table Hypertherm 85 Etc, etc,etc. "You don't stop laughing when you get old....You get old when you stop laughing". |
Friends of mine introduced me to it.
![]() ![]() Have quite a few friends from NZ bro.
I think fluid film is a lanolin based product.
I use it almost daily on aircraft control rod ends and other areas, but I don't want anything on the surface of my welding table. |
Linseed oil.
Used on farm equipment and inside aircraft tubes for rust prevention for a very long time.
Syncrowave 350 Coolmate 3 Millermatic 251 Spoolmatic 30A |
Now thats the pic that represents what im talkin' about.
| Thread Tools | |
| Display Modes | |
