Old 08-05-2012, 08:28 PM
brucer's Avatar
brucer brucer is offline
Went and picked up an LQ4 up this weekend..
was running and driving when pulled, its a high mileage rebuilder, come out of a GMC Sierra 2500. 180k miles LQ4(cast iron block aluminum heads) 6.0 liter, good oil pressure, I got a decent deal on it, he replaced it with an LQ9 in his truck..
No matter how stupid you think humanity can be, there will always be someone that exceeds your expectations..
Old 08-05-2012, 08:43 PM
rabidchimp rabidchimp is offline
Re: Went and picked up an LQ4 up this weekend..
What are your plans for it?
-Aaron
Hardinge HC Chucker Lathe --- Jet 17.5" Drill Press
Lincoln 175 MIG --- Lincoln 175 Square Wave TIG
Dewalt 14" Chop Saw - Victor O/A Setup
Jet 7x12 Horizontal ---- Jet 17" Vertical
https://www.facebook.com/#!/RabidChimpPerformance
Old 08-05-2012, 08:58 PM
brucer's Avatar
I dont know yet...
thinking rering, ls1 heads, about a .540-.550 lift cam, valve springs, a tune and dropping it in my 98 ta.
the thought has crossed my mind of selling it for profit and just build the ls1.
Old 08-05-2012, 09:45 PM
boatbuoy boatbuoy is offline
might be good for another 100,000 without the re-ring.
miller thunderbolt 250v
lincoln square wave tig 175 pro
lincoln idealarc mig sp250
everlast tig 210EXT
everlast power plasma 50
chicago electric (hf) 130 tig/90 arc
chicago electric 90 amp flux wire
3 sets oxy/acet
Old 08-06-2012, 12:19 AM
brucer's Avatar
I pulled a head off one side tonight, actually looked good and clean.. I'll probably get some pictures of it tomorrow..
Old 08-06-2012, 03:35 AM
G-son G-son is offline
Did you make a compression test before pulling the head? Always good to know if any cylinders need extra attention when looking for problems after the head has been pulled.
Old 08-06-2012, 03:35 PM
brucer's Avatar
no, i guess i should have just to know..
I'm going to go ahead and just rering it and put new bearings in it before I put it in.. its fairly cheap to rering it, so I might as well..
I'm planning on swapping on my stock ls1 heads, should give me a little better than a point of compression using .041 head gaskets, around 10.7:1 I'm guessing. I'll use the intake, lifters and pushrods from my ls1 because they are fairly low miles (88k miles), I'm going to look for an ls6 camshaft because they are cheap, or use a lunati voodoo cam with about .540 lift, and 112 to 114 lsa..
thought about just a hotcam or asa cam also, so i wouldnt have to mess with the converter..
It should make a strong cheap engine, with a lot of capability..
Old 08-06-2012, 11:28 PM
i assume you know not to reuse the head bolts.
everlast tig 210EXT
3 sets oxy/acet
Old 08-07-2012, 09:32 AM
socoj2 socoj2 is offline
Put the Z06 cam in it and how much you want for it?
Old 08-08-2012, 07:06 AM
brucer's Avatar
yep they are torque to yield, tossed them
Old 08-08-2012, 07:39 AM
brucer's Avatar
I now have tore down to the short block,
the block and crank and rods are in pretty good shape,still see faint crosshatching in the cylinders, no noticeable ring land, crank looks good, It would need a rering before I would use it..
It also has the 317 heads which are what a lot of folks want for boost because they have 71cc combustion chambers, stock lq4 compression is 9.5:1.. The valves felt ok, needs new seals, there are 3 manifold bolts broke off in the heads.
bare 6.0 blocks are going for around $450, I'm willing to sell the whole engine, intake to oilpan, disassembled to the shortblock , truck intake, fuels rails,injectors and drive by wire throttle body.
It would probably cost a small fortune to ship it, block alone weighs like 115lbs, think they weigh like 450lbs without the front accessories.
I'm open to offers, pm me..
HTML code is On
