Old 07-29-2008, 11:58 PM
gaustin gaustin is offline
Metal Cutting Circular Saw
Has anyone used the HF version of this? I have used the Evolution and Milwaukee saws and liked how well they worked but I am thinking abouot getting a lower end version for things around the house.
Thanks
Have a nice day
http://www.weldingdata.com/
Old 07-30-2008, 12:42 AM
tapwelder tapwelder is offline
Re: Metal Cutting Circular Saw
got one from Northern tool. It works well. I don't have any thing to compare it to, however. I have had no problems. I have used it to make channel out of tubing and sliced 1/8" slivers. I used it on some ashpalt once, slice easily though too slow however. Northern's saw has an odd sized arbor.
Old 12-31-2012, 09:36 PM
AluminumWelder AluminumWelder is offline
$100 on the HF web site, but tomorrow it will be $75 so I'm going to pick up a few. I had been eyeing the horizontal vertical metal band saw, but those things are sooooo slow. For production work like we do I think the cold cut saws are faster/better.
In fact I don't even know what I would use a band saw for? Maybe if you had to notch some metal and wanted slow control???
Old 12-31-2012, 09:50 PM
WyoRoy WyoRoy is offline
Got my second one off eBay, new, but dead in box for $10 delivered. Bought it because it was cheaper than buying a new blade for the first one. Unwrapped the package, pulled out the electrical meter and found the fault was in the plug. Swapped it out and now have a second saw sitting on the shelf.
As far as quality, it gets the job done. One of numerous cutting options. I don't particularly care to use the darned things as metal splinters/chips seem to get spit out of the saw from every pore...still tracking aluminum chips into the house several months after the last time I used the darned thing! Worth the bucks if you can get one cheap enough.
Lincoln PowerTig 275
Miller 251
Miller DialArc 250
Bridgeport mill
Hossfeld bender with dies
Logan shaper
Jet 14 X 40 lathe
South Bend 9 model 'C'...sometimes a 'B'
Hypertherm 900
Ellis 3000 band saw
Too small a shop...too many tools
Old 01-14-2013, 01:25 PM
drujinin drujinin is offline
Is this a saw that looks like a hand held wood cutting saw?
If it is, I used a Panasonic version that had a nice guard.
Then my neighbor bought a blade for his "Skil-Saw", I tried it to cut some long strips of plate not realizing you need the real metal saw because of the chips flying everywhere.
Been thinking about buying one for around the house/garage too?
Old 01-14-2013, 02:06 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
yup
http://www.harborfreight.com/7-1-4-q...-saw-8897.html
Ed Conley
http://www.screamingbroccoli.net/
MM252
MM211
Passport Plus & Spool gun
TA 185
Miller 125c Plasma 120v
O/A set
SO 2020 bender
Beer in the fridge
Old 01-14-2013, 04:32 PM
Softwireman78's Avatar
Softwireman78 Softwireman78 is online now
Same price and more than likely better quality.
http://m.lowes.com/product?langId=-1...65&view=detail
Late to bed, and early to rise. Fish like hell so I don't have to make up lies.
Syncrowave 200
MM 211 w/Spoolmate 100
Old 01-15-2013, 11:03 PM
speedmaster06 speedmaster06 is offline
Hi. I bought one a few weeks ago and used it to cut 16 pieces of 2x2x1/8" square tube. It cut perfectly. Minimal sparks, took about 5 seconds per cut. Handled like a circular saw going through a 2x4.
Much better than grinder, cut-off or chop saw.
No problems whatsoever. Good luck.
Old 01-16-2013, 12:56 AM
While going to purchase a blade for the Northern Saw, I ran into a new 7" steel max circ. saw for close to price of a new blade, it had a new blade on it, too.
It is so much quieter than the northern saw and extremely easy to change the blade. It also feel more powerful.
BTW this thread is old.
Old 01-17-2013, 08:43 PM
joseph_zlnsk's Avatar
joseph_zlnsk joseph_zlnsk is offline
Picture anyone?
Old 01-30-2013, 09:36 PM
power's Avatar
power power is offline
Travers Tool company has them on special this month for 119.00 with lube sticks better deal then harbor fright IMO!!
Miller 250DX
HTP 221 DV AC/DC
Henrob O-A
Miller 180 Mig
Miller 150 Inverter
Hobart 10,000 Welder-Generator Have a good day!!!
Old 01-31-2013, 12:54 AM
Gerry1964's Avatar
Gerry1964 Gerry1964 is offline
My Evolution saw can cut wood and plastic too as well as metal, no need to get any other
[IMG] code is Off
HTML code is On
