Old 07-11-2008, 11:14 PM
kepe's Avatar
kepe kepe is offline
Hi from Nashville TN
First post, so it was only proper to introduce myself. I am a 46 year old practicing welder, which means I hack at most of it. Glad to be here, and hope stick around for quite some time, learning and giving any advice that I am able to give. Thanks!
Old 07-12-2008, 12:02 AM
chenry's Avatar
chenry chenry is offline
Re: Hi from Nashville TN
as a felow nashvillain welcome
insert thoughtful quote from someone else
2000 Thermal Arc 300GTSW 3.5 hours
1946 Monarch 20 x 54 Lathe
1998 Supermax 10x54 Mill
2004 Haco Atlantic 1/2" Capacity Laser
not mine but i get to play with it
Old 07-15-2008, 02:47 AM
littlefuzz's Avatar
littlefuzz littlefuzz is offline
Just a little south of Nashville, welcome.
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 07-15-2008, 05:17 PM
mnm4l1f3's Avatar
mnm4l1f3 mnm4l1f3 is offline
welcome.
how long u been welding for? whats ur preference?
Old 07-15-2008, 05:35 PM
kepe's Avatar
Thanks guys...nice to see that some fellow Nashvillians are lurking here
mnm4|1f3, I have been a hobby welder for about 20 years. I have, until recently, welded with stick or OA on cast iron. I restore old machinery, so welding cast is essential. A few weeks ago, I splurged and got a MM185 gmaw and then a week later dipped in the old wallet for a MM Spectrum 375 plasma. I am like a kid in the candy store now!
Old 07-15-2008, 08:49 PM
chenry's Avatar
by all means show us the old machinery
Old 07-15-2008, 09:30 PM
lewray's Avatar
lewray lewray is offline
Another fellow Nashvegas here..
Glad to see ya post here and welcome.
Yeah Id like to hear more about some of the machinery repairs too
weld it like you own it
Old 07-15-2008, 10:25 PM
SWells's Avatar
SWells SWells is offline
Moderator
Welcome kepe, good to have you aboard. I'd be curious to see the machinery pics too.
If you don't want to stand behind our Troops, feel free to stand in front of them.
Old 07-16-2008, 12:22 AM
Engloid's Avatar
Engloid Engloid is offline
I'm in Knoxville. I'm out of work right now, but have a promise of work within the next couple weeks. Anything much going on in Nashville? I'd love to hit a short shutdown or something.
Old 07-16-2008, 11:52 PM
kepe's Avatar
I don't have and pics of the welding equipment yet, but I do have some of the restoration work I have done on a drill press....
The restored pic doesn't include the motor, which was torn apart when the pic was taken. The DP is a 1957 Buffalo Forge No. 18 with a jacobs Super Chuck 14N. Several of the heavier pieces were de-rusted using electrolysis and the smaller pieces were sand blasted. The column was placed in a lathe and spun with 60g sand paper then emery cloth and then polished up with a high speed polisher. Every bearing was replaced and all non painted pieces were polished. All hardware is Grade 8 stainless and it has 4 coats of primer and 2 coats of industrial machine paint.
I have 5 drill presses that are currently in need of restoration. Two are smaller table top models from the mid-50's and my two prize drill presses are from 1904 and 1909, respectively. The 1904 is a Canedy-Otto 22 line-shaft driven DP and the 1909 is a Champion Blower and Forge 20 hand crank/line-shaft driven DP. I will take a few snapshots of them when I get a chance
Old 07-17-2008, 12:10 AM
lewray's Avatar
Thats a great before and after photo
I have an old AIRCO welder 250 amp cc machine and was thinking of painting it up and make it look pretty too
Lots of detail I see all cleaned up and painted....good stuff
Old 07-17-2008, 01:26 AM
littlefuzz's Avatar
Nice... Old machines have much more style than the new stuff
Dewayne
Dixieland Welding
MM350P
Lincoln 100
Some torches
Other misc. tools
Old 07-17-2008, 11:42 AM
chenry's Avatar
might be time to start a nashville area chapter
Old 07-17-2008, 12:22 PM
longevity-inc.com's Avatar
longevity-inc.com longevity-inc.com is offline
Hello from CA! Nice work on the drill and welcome. There is plenty of useful info on here for you to get on your feet.
LONGEVITY Welding
www.longevity-inc.com
Phone: 877-566-4462
JOIN OUR WELDING FORUM. Go to www.freeweldingforum.com
Old 07-17-2008, 01:37 PM
kepe's Avatar
lewray, Thanks. Go for the restore as I am sure it will turn out great! Take plenty of pics
Littlefuzz, sure does, plus it is much stronger than anything I could get today for the money I have in it. I will end up selling it as soon as I get the Champion DP finished, but that project is on hold because I am currently working on a fabrication table and a welding table. The fabrication table is a 6.5'x4.5' hydraulic double-scissor lift table and the welding table is a 4'x4' pneumatic rotating scissor lift table.
chenry, think so? lol
longevity-inc.com, thanks.
Old 07-17-2008, 01:47 PM
kepe's Avatar
Engloid, sorry...I must have missed your post. There is a ton of construction going on here, so there may be work here....I don't get away from home much, I am not totally sure of what is available. I am on permanent "shutdown", and loving every minute of it
Old 10-27-2008, 09:21 PM
NOMADMAD's Avatar
NOMADMAD NOMADMAD is offline
nice restore job. im curently workin on an old buffalo forge no.2 angle & t cutter. contacted a company that still sells the replacment blades and punches so after i get it sandblasted repainted and put back together i will put a post in to show the work. not sure as to the year of the machine though havent found much luck on info from the internet but hopefully soon. good to see others ot there that like to keep the history alive.
Old 10-27-2008, 10:02 PM
kepe's Avatar
Excellent...best of luck
Old 10-27-2008, 11:09 PM
Bruce's Avatar
Bruce Bruce is offline
Nice drill press, older stuff is easier on the eye. Single phase or 110?
Bruce
The Welding Chef
Lincoln Weld-Pack 3200
NORWELD Stick
Stanford Hill Farm
Old 10-27-2008, 11:24 PM
kepe's Avatar
It's a 1P 110V 1/3HP motor.
