#76
Re: Home made tools!
Neat little home-made eductor MM. We use slightly more refined
devices for fire fighting foam proportioning.
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
#77
Thats where i got the idea from - fire fighting school, USN Philadelphia 1965.
A butterfly without wings, is just an ugly bug ![]()
#78
HI,
Home made gardening tools are easy to made, I made some of my tools ![]() French Wholesalers Directory & Trade Suppliers |DIY Wholesale Tools Suppliers Directory | American Wholesale & USA Wholesalers Directory | French Wholesalers & Suppliers Directory |
#80
![]() 6ton barrel vise / press......A few pieces of angle iron, a couple of 3/4" bolts and a cheap hydraulic jack.....BINGO! ![]() ![]() Action Puller.......Used to "pop" a rifle action out of the stock after epoxy bedding ![]() Various "Barrel Blocks" to use with barrel vise above..... ![]() Reloading trays to hold cartridges while reloading. Made from Air Conditioner suspended ceiling grills.
Roy B Dartmouth, Ma http://www.rvbprecision.com MM 185 MIG Diversion 165 Purox W200 O/A Grizzly 9957 Mill Grizzly 4030 Metal Band Saw Grizzly 1050 Knife Belt Sander Jet 1236 Metal Lathe CM 14" Metal Band Saw TP Blast Cabinet |
#81
Got tired of forking over ridiculous bucks for moto tire changes.
Works good on car tires too. ![]()
Airco 300 squarewave Mig welding center... Powcon sm300/LN 25 Powcon sm200/PD l Hypertherm PM 1100 Miller AEAD 200LE W/LN25 FC and now another sm200 pd l combo. Last edited by sunline; 12-11-2008 at 10:32 AM. |
#82
tube roller with dies cut on a wood lathe out of Delrin (have held up so far)
![]() ![]() ![]() my first bender - uses pro-tools dies ![]() ![]() new hydro bender - uses pro-tools dies ![]() ![]()
#83
Great stuff.
#84
came across this thread tonight, man I am excited. I will be copying a lot of your guys stuff, this stuff is great, ideas, ingenuity, and improvising. I LOVE IT
![]() here's a few that I had laying around, they don't really compare, they are all realitivaly cheap and readily available, but when you don't have the patience to run to the tool store or wait for the snap on guy this what I have made... more to come
#85
I just made this today, and its one heavy duty scratching thingy
, for drawing lines on steel, i don't know the translation![]() http://www.box.net/shared/i9e0hx4yin http://www.box.net/shared/qy3ij7i10n
¤ If you got money, i've got time
#86
A "SCRIBE" perhaps
#87
That must be it,
Because if the translate the danish word directly to english it becomes "Scratching Spike"
#88
![]() Tool for standing up 2"x6" tubing used for lath. Works wonders when the entire length is a few hundred pounds and you're sitting on a 4" I-beam flange. 4" isn't really enough for a whole buttcheek.
MM210, For sale $1k with cart,reg,gun,hose, and 250cf bottle Dynasty200DX w/coolmate1 MM Vintage Lincoln AC225 Victor O/A, Smith AW1A Cutmaster 81 IR 2475N7.5FP Rage3 Jancy USA101 9" SB 9" Craftsman/Atlas lathe (worn out) AEAD-200LE |
#89
OK!
Here's my contribution. One of the tools I have made, its a bending jig, made for bending flat stock of up to 4" wide, I have used this to bend up to 1/2" thick stock, and can bend as short as 2" from one bend to another! I made the jig for a smaller shop press that I had, and am now converting it to be used on this monster! "The second pic"
#1. If you don't like what I wrote, or if it offends you, then don't read it! #2. I am living life the way I see fit, if you don't like the way I'M living, tough sh**! |
#90
This is one of the bigger tools I have made!
I am now making one even bigger.
#91
Here's a "poor man's" faceplate I made for a friends wood lathe.
![]() ![]() I welded a nut with the threads that match his lathe spindle to a chunk of 3/4" plate. Then mounted it on a piece of all-thread, chuck it in the metal lathe, turned the plate into a circle and faced it off. I've just recently started using a metal lathe and my skills are not so good. I couldn't get a very nice finish. The facing was fair, but the outside edge kept chattering. I don't think I'm grinding my tool bits correctly (HSS). It'll be good enough for wood working.
#92
Make sure that:
The chissel is right on centre The angles are right There's not too much freeplay in the cross slide Then you should be ok. |
#93
Just some handy dandy dogs, they do the trick everytime.
Disclaimer; "I am just an a$$hole welder, don't take it personally ."
#94
dogs handy dandy deedy dey do..very cool mon
#95
Toz, I like them dogs.
#96
Woof!
#97
nice job everyone....my problem is not enough time and too many ideas in my head
anyone ever made a rotisserie for welding pipes with a 3 or 4 jaw lathe chuck and variable speed motor ? |
#98
this thread should be stickied
#99
"this thread should be stickied"
Define stickied please.
#100
You might find that the libraries in your area have some basic machining textbooks. If not, (ours threw stuff like that away long ago; isn't PC), take a look at the reprints of old manuals and such at Lindsay Publications Lots of interesting and reasonably priced material here. Even some stuff on a new field they call 'Welding'!
| Thread Tools | |
| Display Modes | |
