Old 05-26-2009, 05:07 PM
David R's Avatar
David R David R is offline
Mig like Tig
This thread is about making MIG look TIG, or really nice looking mig welds.
I am going to try something.
ONLY POST IF YOU HAVE A PICTURE OF YOUR OWN WORK.
The point is we want to SEE your attempt.
I am going to try to master this too.
Here is my picture. It aint like ZTfabs, but it was about 200 feet of weld.
WFS 330 of .035, about 20 volts C/25. This is 3/16" square tubing so there is a natural perfect fit up. I should have been at around 200 amps.
Horizontal, making circles going up on the forward stroke. First pass on clean bare steal, second pass down through the puddle. I turn the heat WAY UP to do this. 200 amps on 3/16" horizontal groove.
Here is a link to another thread
http://weldingweb.com/showthread.php...hlight=mig+tig
Nothing discussed here but Mig welds.
David
edit: Mig gun was held straight in the joint.
Real world weldin.
When I grow up I want to be a tig weldor.
Old 05-26-2009, 05:17 PM
ol'goldenarm ol'goldenarm is offline
Solderer
Re: Mig like Tig
i have never tried to tig weld i was wanting to know if it is at all harder than stick, i need to know cause works gettin scarace and i may have to go singel hand and they say combo pays better
Old 05-26-2009, 05:27 PM
weldbead weldbead is offline
Re: Mig like Tig
harder shmarder, its different. its like oa welding, heat in one hand to make the puddle, and filler in the other to feed it. in ways its easier than stick , cause thers no slag to block yer view, you see the molten metal and its up to you to make sure it goes where it should.
Old 05-26-2009, 05:54 PM
David R's Avatar
My attempt
I was welding bucket teeth on using a forward whip and bare wire.
Mig welds that look like tig welds or attempts at it.
David
Real world weldin.
Old 05-26-2009, 06:16 PM
GerryR GerryR is offline
Re: My attempt
Just curious, is this a new fashion thing or is their some good technical reason to make MIG look like TIG??
Old 05-26-2009, 06:25 PM
David R's Avatar
Re: Mig like Tig
Take a look here and see what started this.
http://weldingweb.com/showthread.php?t=30507
Along with other threads about the same thing.
This is a trial thread.
David
Real world weldin.
Old 05-26-2009, 06:33 PM
Bob Warner's Avatar
Bob Warner Bob Warner is offline
Re: Mig like Tig
Here is an image that I got out of my welders manual. It shows that dragging is a real method which was challenged in another thread.
Also a meager attempt of getting the tig weld look on some crappy rusty steel. There is a photo of the welds and a photo of the inside of the box.
I did not have good steel to try it on but will try to get something better soon.
Bob
Old 05-26-2009, 09:58 PM
dclevinger dclevinger is offline
Re: Mig like Tig
I'm glad you started this thread David. I've been wanting to try doing this and just needed a reason.
Lincoln 100 HD with .030" NR-211-MP on some 1 1/4" X 1/8" angle iron. I didn't hold it at the end quite long enough but it ain't too bad after about 5 minutes of playing around. The dime is partially covering a tack, I ran a few beads on the other side before trying this one.
I may re-post this one so you guys can critique it without hijacking this thread.
David Clevinger Engraving
Old 05-26-2009, 10:24 PM
welderShane's Avatar
welderShane welderShane is offline
Re: Mig like Tig
Here was my attempt on 3/8 plate to 5/8 roundbar. I used a lincoln weld pak and .035 lincoln innershield nr211mp wire. This was a table mount for my sander.
Shane
Ya gotta spend money to make money!
Old 05-26-2009, 10:25 PM
TSOR TSOR is offline
Re: My attempt
For my business - custom off road fabrication- it is the customers perception that these types of welds are better. Of course, appearance doesn't really have much to do with the quality. As welders we know that, but for me, aesthetically appealing welds help sales.
Here is a pic of a Dana 60 axle housing I mig welded to the tubes.
Old 05-26-2009, 11:32 PM
ZTFab's Avatar
ZTFab ZTFab is online now
Re: Mig like Tig
Here's a couple of my attempts at it.
These were some prototype brackets, .125" CRS.
This is a truss that I made for a 9" differential housing: I cut the truss from 2"x3"x.125" tubing.
And here is the "box" from the previous thread. It is actually a cover for an old rooftop hatch that was de-commissioned. .125" CRS.
Hold my beer...watch this.
Old 05-26-2009, 11:40 PM
Re: Mig like Tig
"attempts" - that's funny right there!
Old 05-27-2009, 03:42 PM
ZTFab's Avatar
Re: Mig like Tig
Here's a few more...
.125" and .188" CRS.
These are both open corner joints like the "box". THere is a small piece with a lap joint on the .188" as well.
Old 05-27-2009, 07:06 PM
rode2rouen's Avatar
rode2rouen rode2rouen is offline
Re: Mig like Tig----I'm ready for a critique!
My first attempts were more like "MIG like MIG".
I cut 8 coupons of 1/8" CRS and tacked them to give myself open groove joints.
This was also my first try at pulling the torch, I usually push.
Each coupon was welded in 2 steps, from the corner to the center tack, left to right, with changes in WFS and voltage made on each half. You can see the reference marks: 1A/1B,
2A/2B, etc.
Basic settings:
Lincoln PM300 in GMAW (#5) mode....no pulse.
.035" ER70-6
92/8 Ar/Co2
Coupons tacked but needing cleaned. The "Spot" feature is cool! .5sec duration.
Coupon 1: A side, 150 WFS / 20 volts Too Hot!!....B side, 150 WFS / 17.5 volts.
Coupon 2: A side, 140 WFS / 17.5 volts....B side, 140 WFS / 16 volts....still hot.
Coupon 3: A side, 130 WFS / 16 volts....B side, 130 WFS / 15 volts....unstable arc @ 15volts, 16 seems mo' better.
Coupon 4: A side, 120 WFS / 16 volts....B side, 110 WFS / 16 volts.
Coupon 4A seems to be the best of the lot, from a WFS/Volts standpoint. I think my technique of making the "e" is too slow. Like, I'm not taking the horizontal move far enough to the right before I curve back around counter clockwise.
I spent about 1/2 an hour doing "dry runs" with the machine turned off so as to get a feel for the drag/"e" technique. The 400 amp gun is definitely NOT the one for this!
Comments and pointers will be appreciated!
Rex
Old 05-27-2009, 07:17 PM
JC'sWelding's Avatar
JC'sWelding JC'sWelding is offline
Re: Mig like Tig
No fair! I think Paul should be excluded from this "attempt"
Michael Jordan: "Just put this ball through that loop? Sure, I'll try it"
Old 05-27-2009, 07:18 PM
David R's Avatar
Re: Mig like Tig
Amps or heat is the wire speed.
Volts are the bead width. You can see that in your cupons.
I would try 120 to 130 ipm with about 17 -18 volts. To your own taste of course.....
If you look at cupon 3, A side you are close, but there is too much weld or wire.
you could also try straight in and push.
I like the attempts, looks like you are on your way!
More please
David
Real world weldin.
Old 05-27-2009, 07:46 PM
Dan Dan is offline
Re: Mig like Tig
Here are a few sample T joints that I ran quite a while ago.
Old 05-27-2009, 09:41 PM
BigTuna's Avatar
BigTuna BigTuna is offline
Solderer
Re: Mig like Tig
Old 05-28-2009, 09:40 PM
Jamie Webb Jamie Webb is offline
Re: Mig like Tig
It is a small part, but that is all I have in here right now. I honestly can't remember if I pushed or pulled this one. I push/pull based on which side I am coming from and what I can do to get comfortable. I can also weld with either hand so right to left or left to right doesn't bother me.
For a comparison, here is a small tig weld I did recently.
Jamie Webb
Welder & Inspector
Business and Hobby
Lincoln Pro-Mig 180 with Spool Gun and Lincoln AC225
Old 05-29-2009, 12:06 AM
ZTFab's Avatar
Re: Mig like Tig
Those are beautiful welds Dan.
Old 05-29-2009, 01:36 PM
maniak's Avatar
maniak maniak is offline
Re: Mig like Tig
I hate guys that weld like that It's beautiful work, you make us all proud...I know you've listed it before, but ZT could you give your parameters again? I've got an itch to give it a go too. Hat's off to all those that showed up on this! Thanks
maniak
Old 05-29-2009, 05:56 PM
wesdavidson wesdavidson is offline
Re: Mig like Tig
That axle truss is art.
Just realised, referencing another thread, GOOD ART. didn't want any mistakes here.
past work toys; lathes,mills, drills, saws, robots, lasers ironworker, shears, brake, press, grinders, tensile tester, torches, tigs, migs, sticks, platten table, positioner, plasmas , gleeble and spot. Retired June 30, 2009.
Old 05-29-2009, 06:24 PM
ZTFab's Avatar
Re: Mig like Tig
Thanks.
I like this one that I did a little better. It's in two separate threads.
http://weldingweb.com/showthread.php?t=10922
http://weldingweb.com/showthread.php?t=11016
Old 05-29-2009, 06:25 PM
ZTFab's Avatar
Re: Mig like Tig
maniak
Any weld in particular? I posted a couple of different ones and they would obviously have different settings.
Old 05-30-2009, 12:03 AM
tanglediver's Avatar
tanglediver tanglediver is offline
Re: Mig like Tig
I wouldn't want my mig welds to look like tig. Clean and consistant, yes! But not like tig, it ain't natural. The best from my days leading up to certifying.
Lincoln V350 Pro @ 18.~plus volts and LN-7 wire feeder @ 225-ish? ipm.
Here are some tig beads from cyberspace...yeah, I can do that!
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
