Old 09-01-2011, 02:25 PM
nickestes250 nickestes250 is offline
Solderer
sa 250 d problem
ive got a code 8912 sa 250 d, it stoped welding so i took the cover off the excited and found that from one slip ring to the frame i had continuity and from the other slip ring to the frame i had it as well, but i have 46 ohms resistance between the two slip rings with the probes on each one, so i figure the rotor is burnt up, i found a sa 250 gas welder with a locked up engine, the face plate looks the sam as mine with the 230 rec and 120 rec for ac voltage, so first will that generator unit work on my diesel rig and how much trouble is it to swap them out?? any help with be great!!
Old 09-01-2011, 03:00 PM
gizzardgutz's Avatar
gizzardgutz gizzardgutz is offline
Re: sa 250 d problem
Weldmart has a CD you can send for with the troubleshooting guides for the SA 250. Clicking the link will also give you access to them in pdf.
http://www.weldmart.com/technical/manuals.htm
Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.
-Cree Indian Proverb
SA 200 Lincoln
Victor Torches
[IMG] code is Off
