Old 04-02-2012, 12:19 PM
FrankM FrankM is offline
Solderer
1" Steel Plate
Hello,
I'm a small excavating contractor in North Central N.J. I have one machine with a few attachments. I would like to store the attachments on a 1" x 8' W x 15' L plate so I can move them all in one pick. I've received prices around 30/s.f. which seems quite expensive. Can anyone tell me if there is a used market for this?
Thank You in advance
Frank
Old 04-02-2012, 02:05 PM
morgaj1's Avatar
morgaj1 morgaj1 is offline
Re: 1" Steel Plate
That works out to $0.75/lb. Around here in AL, the going rate for plate steel is about $0.65. However, steel prices vary all around the country.
Lincoln Powermig 255
Hypertherm Powermax 45
Thermal Arc 161S
Oxweld 24R OA Torch
Still Looking for an Old Round Top Idealarc 250
Old 04-02-2012, 02:59 PM
sn0border88 sn0border88 is offline
Re: 1" Steel Plate
The only used market you are going to find would be a scrap yard, go to one that lets you look around and see if you can find plate that will suite your needs.
Have we all gone mad?
Old 04-02-2012, 03:24 PM
forhire's Avatar
forhire forhire is online now
Re: 1" Steel Plate
Steel is generally sold by the pound (actually hundred weight), in your example that's $75 per hundred or 0.75/lb. I get real nervous when I'm quoted by the square foot.
My price on some wide beam last week was around $57 per 100.
For plate I've been using Chapel Steel out of Portland, OR. They have a location in Philadelphia, PA... not sure if that's too far for you. Might give them a call. Trucking is really driving the material costs. Find a yard that brings it in by rail and your cost will generally be lower. http://www.chapelsteel.com/locations.html
I hope your planning on supporting this plate on some beams... even 1" plate is like spaghetti.
Old 04-02-2012, 03:50 PM
ironmangq ironmangq is offline
Re: 1" Steel Plate
I would look into building a frame to carry the implements rather than a piece of plate, It will be stiffer and probably easier to move around
Old 04-02-2012, 04:29 PM
Fat Bastard's Avatar
Fat Bastard Fat Bastard is offline
Re: 1" Steel Plate
$75.00 CWT is what I'm paying in Alaska. So $75.00 CWT in the 48 is high way high.
Brucy is an admitted unemployment cheat. AND he is PROUD of it. Kentucky should be proud. Shame on you Bruce.
Prophet Mohammed, womanizer, child molester and ruthless killer?
Old 04-02-2012, 05:12 PM
Mondo's Avatar
Mondo Mondo is offline
Re: 1" Steel Plate
The price you were quoted is probably about right, this is a big chunk of steel. 4'x8' is probably less per pound or sq ft.
Have you really thought this through and considered the weight? You want to store all your "small" machine implements on one plate for easy moving, right?
1" plate is 40.8 lbs/sqft. (http://www.engineeringtoolbox.com/st...ht-d_1561.html) You said 8' x 15' That's 120 sqft
120 x 40.80 = 4,896 lbs. To handle this flat will be like handling a sheet of paper from a note pad unless it has substantial support secured beneath it. Add the weight of the support framing, add the weight of the stuff you intend to store/move on it and you are going to have a rather heavy load. What kind of machinery do you have to handle this load? When you say you want to move it "in one pick" I presume you mean by crane. A big crane.
Oh yes, I need to mention also that you need to provide some means of securing each implement to the plate lest it slide like an omelet off a greasy spatula! I'll watch from a vantage point in the next county.
I am sure this can be done but unless you always work large sites that have one or more big cranes I don't see this as practical.
- Mondo
Member, AWS
Lincoln ProMIG 140
Lincoln AC Tombstone
Craftsman Lathe 12 x 24 c1935
Ask for a wrench and someone will offer you a grinder.
I'll just keep on keepin' on.
Old 04-02-2012, 05:17 PM
Mondo's Avatar
Re: 1" Steel Plate
For what it is worth have you considered keeping the implements secured to a flat or gooseneck trailer and having the crane pick the trailer?
- Mondo
Member, AWS
Lincoln ProMIG 140
Old 04-02-2012, 05:36 PM
Pavinsteelman Pavinsteelman is offline
Re: 1" Steel Plate
Hi 4900 lbs mill price is .52 lb plus frt . try Joseph Fazzio in so jersey for used plate.People paid almost 1.00 lb at Ace Manzo auction in NJ for road plates .
Old 04-02-2012, 09:28 PM
pslwelder pslwelder is offline
Re: 1" Steel Plate
I'll second Fazio's. Price's are fair and huge stock. I believe they have a store at the RT.33-34 circle in wall.
