Old 07-05-2012, 01:32 AM
Thorton Thorton is offline
Welding Deck - Aluminum vs. Steel
Thinking about getting a Welding Deck made.. Either made of Steel or Aluminum. I know that Aluminum would be 1/3 the weight of steel, but if you were getting a Welding Deck, would you have one made of steel or one made of Aluminum? Also, What are the advantages and Disadvantages?
46’ sae300
47’ sa200 w/Wisconsin VF4
51’ shorthood
56’ shorthood
56’ shorthood
68’ redface
69 redface
07’ ranger 305G
13’ sae300
Inconel/Hastelloy – SS – Duplex – Chrome/Carbon Tig – F3Downhand – STT/RMD – F3F4 – B Pressure
Old 07-06-2012, 12:21 AM
Kevin Morin Kevin Morin is offline
Re: Welding Deck - Aluminum vs. Steel
Thorton, I don't know the term? welding deck?
what is a welding deck? sorry to be ignorant of that term.
cheers,
Kevin Morin
Old 07-06-2012, 02:25 AM
Dualie Dualie is offline
If money was no object i would get aluminum, if i was paying for it i would go with steel.
Vantage 500's LN-25's, VI-400's, cobramatics, Powcon inverters, XMT's, 250 Ton pacific 12' press brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas.
Lincoln idealarc tig 330A with bernard cooler Sync350LX. Miller migs, marvel saws
Old 07-06-2012, 04:51 PM
cheers,
Kevin Morin
I apologize that you are ignorant of the term.
Cheers,
Thorton
46’ sae300
51’ shorthood
56’ shorthood
56’ shorthood
68’ redface
69 redface
07’ ranger 305G
13’ sae300
Old 07-06-2012, 07:20 PM
boatbuilder boatbuilder is offline
Kevin's no idiot and either am I and I don't have a clue as to what your talking about. Maybe you could explain what a welding deck is? Are you talking about welding down decking?
Welderbob
Old 07-06-2012, 07:26 PM
Broccoli1's Avatar
Broccoli1 Broccoli1 is offline
Cheers,
Thorton
WTF?
"The message you have entered is too short. Please lengthen your message to at least 5 characters."
Oh ok then
WTF? WTF? WTF?
Ed Conley
http://www.screamingbroccoli.net/
MM252
MM211
Passport Plus & Spool gun
TA 185
Miller 125c Plasma 120v
O/A set
SO 2020 bender
Beer in the fridge
Old 07-06-2012, 07:27 PM
Broccoli1's Avatar
Welderbob
It is a phucking welding platform for a truck or a trailer but he's too ignorant to just tell you that
http://weldingweb.com/showthread.php?t=62450
Ed Conley
MM252
MM211
TA 185
O/A set
SO 2020 bender
Beer in the fridge
Old 07-06-2012, 07:32 PM
Jack Olsen's Avatar
Jack Olsen Jack Olsen is online now
A welding deck (or service deck) is the custom rear section of a welding truck (or rig).
But I had to Google it.
It would have taken just as much typing for Thorton to explain it.
Old 07-06-2012, 07:33 PM
Jack Olsen's Avatar
Oops. I'm too slow on the keyboard. Ed got it.
Old 07-06-2012, 08:50 PM
slim83's Avatar
slim83 slim83 is offline
Welding deck is definitely a Canadian term. Not saying anything bad just saying most folks in the states call them welding beds. Aluminum would be nice because of the weight factor. Steel also has it advantages to work off of. Its really up to you bud. Why don't you build one yourself? Time,no place to Fab one? Just curious. I almost never got started on mine but now I'm half way through and it definitely has been fun
Old 07-06-2012, 10:01 PM
lotechman lotechman is offline
An aluminum truck deck is not much good for anything unless you are loading wood or aluminum. The battle scars from steel on aluminum would look pretty ugly after a few years. I cannot see you mounting a small crane or even a vise to an aluminum deck.
The connection between the truck frame and the aluminum deck would be subject to corrosion unless you carefully isolate steel to aluminum surfaces.
Certainly if you never use the truck deck for anything other than carrying your portable equipment and tool cabinets it would be a savings in weight.
Old 07-06-2012, 10:51 PM
jakeru jakeru is online now
When I first read this, I assumed he was from some other country and was talking about a welding table. He didn't put his location in his user profile though, so who knows?
I guess he can clarify if he wishes whether he's talking about some a vehicle-mounted welding surface, or a welding table that stands directly on the ground.
Best of luck getting your questions answered helpfully with the attitude you choose to exhibit, OP.
Old 07-06-2012, 11:41 PM
Now hold on guys, Kevin said that he was Sorry for not knowing the term, and I simply apologized to Kevin that he did not know the term, because maybe I was not very clear - I did not realize that "Welding Deck" was not a universal term.
Some guys think its a strange name when you call a "Shorthood" a "Stubby"
Some guys call "Welding Helmets" "Facemasks"
Some guys call them "Pipe Wrench", I always call them "Monkey Wrenches"
46’ sae300
51’ shorthood
56’ shorthood
56’ shorthood
68’ redface
69 redface
07’ ranger 305G
13’ sae300
Old 07-07-2012, 01:04 AM
mb_welder's Avatar
mb_welder mb_welder is offline
If money is no Object? Aluminum.
Otherwise? Steel.
An aluminum deck will save on weight and an added bonus...when you have to fab something on the back of your truck...spatter won't stick to it!
Old 07-07-2012, 05:48 AM
CEP's Avatar
CEP CEP is offline
Personally I can't imagine using a aluminum welding deck! I've had an aluminum flatbed for 5 1/2-years now, don't use it for a dam thing and it is still getting screwed up. So bad I bought treated plywood to protect the deck! I have a dump trailer, and a gooseneck flatbed trailer for work around the place, the aluminum flatbed is just for looks.
http://www.alumaklm.com/truck-beds/i...ruck-beds.html
Dynasty 300.
V350-Pro w/pulse
LF-72
SG Spool gun
LN-25.
PowerArc 200.
5 SA-200s.
1800 Ellis saw
Powermax 1250, CNC table.
PROFAX Welding Positioner.
JD2 model 3
Old 07-07-2012, 05:57 AM
Kelvin Kelvin is offline
I apologize that you don't know what a Monkey Wrench is.
It's this:
not this:
Old 07-07-2012, 07:08 AM
Eliotmay@yahoo.com's Avatar
Eliotmay@yahoo.com Eliotmay@yahoo.com is online now
Sometimes it amazes me the lack of courteous behavior. I applaud those that can answer politely and ignore it. I am not so nice I guess, I call you out.
Miller diversion 165
Miller mig 211
Hypertherm pm 30
Milwaukee 6230 14 inch chop saw
Md 45 mag drill (RIP; fell on its head)
New MD 45! Thanks to the esposa!
Finally got an O/A setup
Old 07-07-2012, 08:06 AM
astaindsoul5446 astaindsoul5446 is offline
Pipe wrench have teeth, monkey wrenches are flat jawed, sorry you ignorant to the names lol just playing around
Miller bobcat 225g - spoolmatic 1
Mm250 - 30a spool
Miller spectrum 375
Thermal arc 95
Everlast Ex 250
As the boiler turns, these are the days of our lives
Old 07-07-2012, 08:09 AM
I think steel would hold up a lot better, aluminum tends to distort with heat and will eventually be very untrue of a surface to work off of, durability, longevity, and truness my dime is on steel.
Mm250 - 30a spool
Miller spectrum 375
Thermal arc 95
Everlast Ex 250
Old 07-07-2012, 12:19 PM
dubl_t's Avatar
dubl_t dubl_t is offline
I don't know, my pipe wrenches are aluminum and thery're holding up just fine. I can't tell it they distort with heat as I don't touch them when they're hot.
Wait.....are we talking about monkey wrenches? Then never mind, I wouldn't own one of them bastardized tools
Trailblazer 250
Esab Caddy 160
Thermal Arc 201TS
well, I tried real hard to bite my tongue and not get involved....
Old 07-07-2012, 02:42 PM
Weld on a piece of 1/4 aluminum, on a piece, say 8x8x1/4. Run 4 6 inch welds in the center of the plate side by side, 4 stringers. Allow it to cool and take a piece of glass to use as a straight edge and on edge put it corner to corner both ways. You'll visually see the distortion. Over time heat from welding piece not the table is going to distort the aluminum. Then take a piece of steel cut with a torn an drag it across the top on the alumin 100 times..... Get my point yet? We can keep going
Ps last time I checked the jaws of a pipe wrench are steel, replace your jaws with aluminum one and tighten a few pipes, then let me know how the jaws look.
Mm250 - 30a spool
Miller spectrum 375
Thermal arc 95
Everlast Ex 250
Old 07-07-2012, 08:09 PM
I was looking over the Website http://www.expresscustom.com/ Most specifically at the BB60 Series Welding Bodies - it is so difficult to choose between Steel and Aluminum, it really is.
I wasn't thinking about building my own because I do not have the patience to build one. It is a great deal of work, requiring alot of time and dedication.
To be honest, I am more willing to pay for the convenience of someone else to build one rather than save money and build one myself. But you never know - I may decide to make an attempt.
46’ sae300
51’ shorthood
56’ shorthood
56’ shorthood
68’ redface
69 redface
07’ ranger 305G
13’ sae300
Old 07-07-2012, 08:35 PM
CEP's Avatar
CEP CEP is offline
I always wanted to build an aluminum bed. Built several steel beds over the years, no one here couldn't build a steel bed. When I got my new 2007 3500 Dodge cab & chassis, I started pricing aluminum, I couldn't even come close for the price of buying new bed. I bought a 10 1/2 foot bed, side boards, and tail gate for under $3,000.00. I'd be floored if you could build a bed cheaper than buying new!
Dynasty 300.
V350-Pro w/pulse
LF-72
SG Spool gun
LN-25.
PowerArc 200.
5 SA-200s.
1800 Ellis saw
JD2 model 3
