Tig pedal question. 15 vs 20 ohms
Ok so I got my 330abp up and running today with an old off brand pedal that had 2x 20 ohm circular wound resistors in it wired in series. I changed them to a parallel setup for 20 ohms instead of 40. But my 330 abp specs a 15 ohm resistor.
The 3 prong plug arrived today and I got to test the pedal out and it seems to work fine. Just wondering if anyone knows what difference or if there is any negative effects to running it on 20 ohms instead of 15? I have a 15 ohm resistor from an old 3 phase miller I scrapped if needed but would require quite a bit of pedal modding to make it work which I am trying to avoid
Airco 330A/BP. Lincoln SP250 W/ spoolgun, GoWeld x2 TA Predator, ESAB 300AVS Feeder ESAB 875 plasma. . Bernard Cooler. Evo 355. OA Demo: Longevity Tigweld 200SX, Forcecut 42i Everlast 140ST.. On loan to friend/sale pending |
Re: Tig pedal question. 15 vs 20 ohms
(2) 20Ohm resistors in series will give you 40Ohms. Where as (2) 20Ohm resistors in parallel will only give you 10Ohms. The formula for calculating total ohms in a parallel setup is:
1/((1/R1) + (1/R2) + (1/Rn)) for as many resistors you have wired in parallel. So for (2) 20Ohm resistors in parallel you would have: 1/((1/20) + (1/20)) = 1/(0.05) + (0.05) = 1/ (0.1) = 10Ohms As far as how it will effect the welder using a different ohmed resistor than is specified. I don't really know. When I ohmed out the potentiometer in the foot pedal on my Airco I got a total resistance of 23.7KOhms, but when I bought a new potentiometer for it I replaced it with a 25KOhm one without any problems.
Brad George Current Equipment: AIRCO Heliwelder IV 300Amp Model - Total Awesomeness! Old 120v Hobart Handler MIG Various grinders, cutting tools, hammers, clamps, ect... "I'm an amateur welder with lots left to learn..." |
| Thread Tools | |
| Display Modes | |
