Old 06-08-2012, 12:12 PM
zapster's Avatar
zapster zapster is offline
Moderator
Rubber Injector..Cooling Chamber..Plunger Repair..
Long involved job here..
3 parts to this assy and all need attention..
The rubber injector is placed in a cooling chamber with seals on each end for sealing in the cold water..
Over time rust and corrosion has wiped out the seal land in the chamber..The seal area on the injector and the plunger has scraped inside the injector and scored the outside finish on the plunger..
Got all that?
OK we will deal with the injector first..
Name:  Cooling Chamber Parts 003.jpg
Note the area near the opening where it's "Shiney" on the OD of the tube..
That's the seal area..
Name:  Cooling Chamber Parts 004.jpg
This end has no seal area left!
Name:  Cooling Chamber Parts 005.jpg
Before I could turn that I needed to make a steady rest area so I could hold it and re-center the end..
So using a brass ring on the threads so they stay nice indicate the tube in as best you can then make your rest area..
Name:  Cooling Chamber Parts 006.jpg
The opening end center was right on..
Before flipping it over turn off the other side seal area for your new ring..
Now set up the steady rest and face and re-center the end..
Name:  Cooling Chamber Parts 007.jpg
Next!
...zap!
I am not completely insane..
Some parts are missing
I have figured out that keeping everyone happy is nearly impossible but pissing people off is easy and fun.
Old 06-08-2012, 12:17 PM
zapster's Avatar
Moderator
Re: Rubber Injector..Cooling Chamber..Plunger Repair..
OK all faced and re-centered...
Name:  Cooling Chamber Parts 008.jpg
Time for new rings..
Name:  Cooling Chamber Parts 009.jpg
Heat..
Name:  Cooling Chamber Parts 010.jpg
Install..
Name:  Cooling Chamber Parts 011.jpg
Next!
...zap!
Old 06-08-2012, 12:21 PM
zapster's Avatar
Moderator
Weld in the new rings..
Name:  Cooling Chamber Parts 012.jpg
Name:  Cooling Chamber Parts 013.jpg
Name:  Cooling Chamber Parts 015.jpg
Re-machine to size and this part is finished..
Name:  Cooling Chamber Parts 017.jpg
Name:  Cooling Chamber Parts 018.jpg
Now on to the chamber..
...zap!
Old 06-08-2012, 12:26 PM
zapster's Avatar
Moderator
Ahh yes the chamber..
Name:  Cooling Chamber Parts 001.jpg
Wiped out end..
Name:  Cooling Chamber Parts 002.jpg
This small fitting is in the way..
Name:  Cooling Chamber Parts 020.jpg
The tab is in the way..
Name:  Cooling Chamber Parts 021.jpg
After grinding off the tab we machine off the old end..
Name:  Cooling Chamber Parts 023.jpg
Next!
...zap!
Old 06-08-2012, 12:33 PM
zapster's Avatar
Moderator
After much math..How much to remove..How much to add..Take into consideration the shrink area..The fitting area..
This is what I ended up with..
Name:  Cooling Chamber Parts 024.jpg
New end to install..
Name:  Cooling Chamber Parts 025.jpg
Heat..
Name:  Cooling Chamber Parts 026.jpg
Install..
Name:  Cooling Chamber Parts 029.jpg
Set up positioner again..
Name:  Cooling Chamber Parts 030.jpg
One more..
...zap!
Old 06-08-2012, 12:35 PM
zapster's Avatar
Moderator
Weld in end..
Name:  Cooling Chamber Parts 031.jpg
I gave this .010 shrink because the tube is sorta thin and we don't need any leaks..
Monday I will do the other end and address the plunger..
Now it's time!!
...zap!
Old 06-08-2012, 02:19 PM
Mechtician's Avatar
Mechtician Mechtician is offline
Nice work, as always! I like that welding positioner, what kind is it? I also like the little support rollers under the cooling chamber, I'll be stealing that idea! Keep up the good work
Old 06-08-2012, 03:52 PM
zapster's Avatar
Moderator
The positioner is a "Aircrafter" by Airco..
Got it on Ebay for cheap$$$
All my wheels are home made..
I have nice rubber ones for when the surface can't be marked up..
Big steel ones...smaller ones 4 different sizes...
VERY handy!
...zap!
Old 06-08-2012, 10:04 PM
killdozerd11's Avatar
killdozerd11 killdozerd11 is online now
You always get the good jobs
Great stuff zap
Backed my CATMA over your CARMA oops clusmy me
What would SATAN do ??
Miller Digital Elite
Miller Trail Blazer 302 Air Pak
Suitecase 12RC
Spectrum 625 Xtreme
Victor O/A
Evolution Rage 3 saw
Rusty old Truck
Old 06-08-2012, 10:16 PM
kidtigger24's Avatar
kidtigger24 kidtigger24 is offline
VERY handy!
...zap!
How is that positioner holding up anyway? It sounded like it was on it's last legs last time I was up there, and you were only welding 4 link bars, not a heavy piece like that. Time to hit the boss up for a new one. God knows how much money that one made him.
kidtigger24
If it ain't broke, fix it anyway!
Old 06-08-2012, 10:27 PM
bhardy501's Avatar
bhardy501 bhardy501 is offline
Very cool job. I would love to work on stuff like that, with the right equipment.
Making as much progress as a one legged duck in the middle of a pond, just going in circles.
Old 06-08-2012, 11:47 PM
zapster's Avatar
Moderator
kidtigger24
It's just fine..
Needed a tune up.
...zap!
Old 06-09-2012, 12:35 AM
jdh239's Avatar
jdh239 jdh239 is offline
I never really post on your threads as I am not at your level when it comes to machining and welding, but I find them very admirable. I enjoy your posts. You do great work. Thanks for sharing.
The Lord has declared, "This is my work and my glory--to bring to pass the immortality and eternal life of man" Moses 1:39
Link: My name is John, and I am a Mormon.
I know it. I live it. I love it!
-- ColdCreekWorks.com --
Old 06-12-2012, 04:17 PM
zapster's Avatar
Moderator
Here are the finish up pics..
I replaced both ends of the chamber..
Set it back up in the lathe and cut new steady rest spots because after heating and welding the old ones run out about .010 and we can't have that..
(.010 on the steady rest just transfers .010 to your finished part..)
It is possible to indicate both old spots in at the same time..
You use the chuck wrench near the chuck and a rubber hammer on the end..
So after that I bored the sleeves out to the proper ID then set up the tooling for cutting the seal groove in..
The groove is .375 wide and .203 deep..
You can't measure inside the groove so you have to rely on your dials and your math..
I just used a custom ground tool by me and did the plunge cut on the groove..
No roughing it out..Just do it..
Pics..
#1..Set back up in the lathe..
#2..New steady rest spots..(Same size!!)
#3..New spots..
#4..Seal groove tool..
#5..Seal groove done..
Name:  Cooling Chamber Parts 034.jpg
Name:  Cooling Chamber Parts 035.jpg
Name:  Cooling Chamber Parts 036.jpg
Name:  Cooling Chamber Parts 037.jpg
Name:  Cooling Chamber Parts 038.jpg
The plunger was sent out for re-chroming and will be ground when it comes back.
Well that's it for this job..
...zap!
