Old 03-21-2007, 10:23 AM
steve28's Avatar
steve28 steve28 is offline
Flux core bead appearance
This may be a personal preferance but what is the best weld profile? Myself i tend to set up my machine so my welds are slightly covex.
As far as overall strength is a flat bead better is the flat for a fillet weld?
Tonight i will be replacing the 3/8 sheeting in the box of one of our dump truck now i was always told ( when i use to work just with hard wire) any weld over 1/4" as to use multi passes. but i see some guys in the shop lay down a 3/8 weld in one pass. Where i tend to lay down a root pass then one on the bottom and another on the top.
just a side note in our shop we use .045 71m wire and c25 shielding gas.
Old 03-21-2007, 11:53 AM
Re: Flux core bead appearance
Prference on material type and method of laying it down. On some stuff I like to push to get a thicker bead, on other material I like to pull to get a thinner bead. The flat bead strength will depend on your total volts and gas used. I think you're fine for 1 pass 3/8.
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 03-21-2007, 12:09 PM
weldrwomn weldrwomn is offline
Steve28, I think that you have it right doing multiple passes. When you push a large weld puddle with Gas shielded Flux Core, you have the potential for slag entrapment among other things. 1/4in is probably the largest bead that you would want to run with .045 wire in one pass. You should try to weld in the flat position whenever possible and a flat to SLIGHTLY convex bead profile is the most desirable.
Old 03-21-2007, 01:17 PM
steve28's Avatar
Ok, thx for that i work on heavy equipment and transports with only a little fab jobs. So flipping things is next to impossible
Old 03-21-2007, 03:44 PM
lorenzo's Avatar
lorenzo lorenzo is offline
Hey Steve... I would have to agree with weldrwomn.
Wire size, type ( solid, cored ) and the mode of transfer determine how large a fillet I will run before going to a multi pass bead. Spray with .045 soild wire has no problem laying down excellent 1/4" + beads.
_________________
Chris
Old 03-24-2007, 10:28 AM
steve28's Avatar
I've always dragged but i tried pushing and it all went wrong. the bead was wide and concave, nothing seemed to work
Old 03-24-2007, 11:15 AM
lorenzo's Avatar
I use a forehand (push) motion when performing spray and globular transfer, and a backhand (pull/ drag) motion when performing short circuit transfer.
these are a few threads that have pics of some of my welds done with dual shield wire in a spray transfer.
http://www.weldingweb.com/showthread.php?t=9870
http://www.weldingweb.com/showthread.php?t=9589
http://www.weldingweb.com/showthread.php?t=9308
http://www.weldingweb.com/showthread.php?t=9244
If you can post some pics of the problems you are having and the parameters that you are running at.
_________________
Chris
Old 03-24-2007, 11:43 AM
steve28's Avatar
ok i'll snap some pics on monday
