#26
Old 05-01-2012, 10:08 AM
JoesEdge's Avatar
JoesEdge JoesEdge is offline
Re: Pop Can Crusher 3.0 (Pneumatic)
Originally Posted by Reebs View Post
That is a good question. I think the answer is 100ish psi. I will crush some this weekend with a harder number.
Sorry no video. I'm about as tech. savy as an old order Amishman.
Great! I look forward to those numbers. Thanks!
I used a pneumatic cylinder for some Halloween props before, so I'm sort of of aware of the amount of force those cylinders can make but they're usually rated at a certain P.S.I.
That reminds me, I need to start tinkering with that cylinder I have.
Joey G.
Downey, CA
Lincoln PowerMIG 180C
Old 05-01-2012, 04:42 PM
rusty ripple rusty ripple is offline
if youre trying to do many of them faster, you might be better off doing something with rollers that you can feed cans into, it would flatten them lengthwise instead of axially, but i think they'd end up thinner, so the end product wouldnt actually take up more space
Old 05-01-2012, 08:25 PM
Reebs's Avatar
Reebs Reebs is offline
rusty ripple
I agree this build was with science class in mind and space conservation as a secondary goal. I don't think rollers would be very hard either.
Dave Reber
Wadsworth Ohio
Old 05-05-2012, 11:23 PM
Reebs's Avatar
Joey G.
I just crushed a bunch of cans @ 100psi. it crushed them fine. I then jumped the pressure to 125 that makes a big difference. They flattened out much more.
Dave Reber
Wadsworth Ohio
Old 05-07-2012, 01:35 AM
JoesEdge's Avatar
Joey G.
Thanks! Good to know. 100 PSI is quite a bit. So is 125 PSI. You might get away with less PSI with a bigger cylinder. There's equations to figure out the force. I need to look them up again.
I was playing around with pneumatics for a Halloween prop. It's kinda fun!
Joey G.
Downey, CA
