sa 200 trade for big 40
what is everyones thought on this was thinking i might be better off with ac power for running tools and its diesel with a deutz motor i know the welder it came from a mine that i used to work at it is a late 70s early 80s modesl thanks.
Re: sa 200 trade for big 40
nobody think good idea?
The question is, do YOU think it's a good idea based on your needs.
The Big 40 has 1-1/2 times the weld output capacity and being a 3-phase rectified DC machine would provide good arc characteristics similar to the pure DC of the SA-200. I would guess fuel consumption of the two machines at comparable outputs would be close. Diesel-vs.-gas. The Big 40 is going to weigh in a bit heavier than the SA-200. Is that going to be an issue? Is the 115VDC only auxiliary power of the SA-200 inadequate for your auxiliary power needs? Although still relatively simple in design, the Big 40 is a little more complex machine than the SA-200. Are you comfortable with that? So again, do YOU think it's a good idea for YOU?
MM200 w/Spoolmatic 1 Syncrowave 180SD Bobcat 225G Plus - LP/NG MUTT Suitcase Wirefeeder WC-1S/Spoolmatic 1 HF-251D-1 PakMaster 100XL SA-200 Blackface Code# 8638 Star Jet 21-110 ![]() Two term limit - one in office, one in jail. |
Thanks Duane I have a ln-25 that i want to run and the miller seems to run it a little better I have used a miller just like it welding in the coal mine on equipment gonna start up a small weekend welding business so weight wont be a problem the miller just air arcs better is my main reason thanks again
