Old 04-13-2012, 02:04 AM
Mick120's Avatar
Mick120 Mick120 is offline
351 Ford mounts
Just knocked up some tough engine mounts for a mates 351 Ford.
He keeps breaking them so, these should get the job done....copied another design I'd seen on the www.
CIG 320SP pulse mig
Mitech ACDC315P
Samson 510 CNC plasma table
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
Old 04-13-2012, 08:05 AM
chimmike chimmike is offline
Re: 351 Ford mounts
Yup, seems to me those should hold! Nice work!
Hobart EZ-Tig newbie.
Old 04-13-2012, 08:49 AM
weldermike's Avatar
weldermike weldermike is online now
Re: 351 Ford mounts
Nice neat job Mick!!!
I hate being bi-polar it's awsome
My Heroes Have Always Been Cowboys
Old 04-13-2012, 05:03 PM
jim cafarelli's Avatar
jim cafarelli jim cafarelli is offline
Re: 351 Ford mounts
Excellent job
Esab Migmaster 250
Esab Caddy160I
Hobart Ironman 230
Hypertherm Powermax 600
Lincoln Precision Tig 225
Lincoln IdealArc 250
Lincoln Weldenpower 225
Victor jr Oxy/Acetylene
Old 04-13-2012, 05:06 PM
dhem's Avatar
dhem dhem is offline
Re: 351 Ford mounts
Nice design. I assume those are poly bushings? What are they from/where did you get them? Might have to copy this idea when it comes engine swap time.
Lincoln PT225
Johnson Horz. Bandsaw
Miller MP-10 Gold Glass Filter
Modified Taig Lathe
Buffalo Forge No 18 Drill Press - Sold
Dayton 1" Belt Sander
Modified Grizzly 8" Bench Grinder
Chinese 20 Ton Press
Old 04-13-2012, 08:34 PM
castweld castweld is online now
Re: 351 Ford mounts
Nice mounts, I guess next he will have frame problems.
Peter
Equipment:
2 old paws
2 eyes (that don't look so good)
1 bad back
Old 04-13-2012, 08:37 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: 351 Ford mounts
All the FORD horsepower and torque......
Nice stuff...
Next step is a front and mid plate...
...zap!
I am not completely insane..
Some parts are missing
Old 04-13-2012, 08:41 PM
Mick120's Avatar
Re: 351 Ford mounts
Yup, poly suspension bushings, aftermarket for Nissan but you could use almost any decent bush.
I fluked getting the right diameter but, they're a tight fit in the tube and come with a bush.
All the design work is done in my plasma program (Design Edge) and, parts CNC plasma cut.
These are the second lot I've done, I did some others for a small block Chev, using the same principal altho, I can't take the credit for the design.
They're just a LOT better than bonded rubber.
CIG 320SP pulse mig
Mitech ACDC315P
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
Old 04-13-2012, 08:56 PM
jmink427's Avatar
jmink427 jmink427 is offline
Re: 351 Ford mounts
Look good! I believe they will hold...
Similar to these I did for a LS series Chevy engine in a Art Morrison Max-G Chassis for a this '69 Camaro I'm working on.....
Old 04-13-2012, 09:59 PM
JWC's Avatar
JWC JWC is offline
Re: 351 Ford mounts
Great work mick. Do you have any other pics of the car. Just curious to see what the 351w is going in.
Shake and Bake
Old 04-13-2012, 10:14 PM
power's Avatar
power power is offline
Re: 351 Ford mounts
Nice job Mick!!
Old 04-18-2012, 09:47 PM
Mick120's Avatar
Re: 351 Ford mounts
Hmmmmm.....wasn't paying enough attention, thought the Ford mounts were similar to the Chev, R & L.
WRONG!!!!!
All you Ford guys will know what I mean......anyways, problem solved, new ones made, both the friggin same instead of mirror image as shown........
Also cut the block mount holes oval, makes lining up a breeze, especially on older vehicles that may or may not be true.
CIG 320SP pulse mig
Mitech ACDC315P
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
Old 04-20-2012, 12:23 AM
Mick120's Avatar
Re: 351 Ford mounts
More mounts, this time for Holden Torana, 308 Aussie V8.
Pics of the mounts being trial fitted, the Torana, plus, the Ford mounts in place.
Not me, not my shop.
Entertainment value only.......
CIG 320SP pulse mig
Mitech ACDC315P
Hypertherm 85
Etc, etc,etc.
www.snapncut.com
Old 04-20-2012, 09:35 AM
ironmangq ironmangq is offline
Re: 351 Ford mounts
do you happen to wear a 4xl glove? For some reason that engine looks way too small
