flux core with argon?
would flux core weld OK with 100% argon?
Lincoln Power Mig 200 Ready Welder spool gun Lincoln Tomb Stone AC DC MPM 150 AMP DC portable Arc welder and Generator Riland 40 AMP Plazma Cutter |
Re: flux core with argon?
umm..... no, 75/25 mix if you are talking dual shield fluxcore.
or CO2, depending on the wire. But regular self-shielded needs no gas.
Rules are made to be broken, particularly by hobby welders, but the correct thing to do would be to consult the manufacture's recommendations.
For critcal applications, the use of the wrong gas can affect the loss/transfer of important elements from the filler to the weld which can significantly affect the mechanical properties of the weld. For example, if the wire is designed to run with 100% CO2 and you run something rich in Argon like 98% Ar/ 2% O2, less elements from the wire will be lost in the arc, making the weld metal rich in these elements and changing the strength, hardness, ductility, and impact toughness of the weld. |
I was using fabshield 7100 Ultra with C02. At lower heat levels acording to the chart, it would not spray at all. I was getting globular transfer. Welding supply store told me to use AG8. I tried it and on lower settings it seemed to work fine, but at higher settings, there was a crack right down the middle of the weld. Like pulsar said, If its designed for Co2, it will run best that way. Running self shielded with gas throws the metal composition off because there are things in the weld made to be sacraficed. With gas they stay in the weld. It changes the properties.
This is my version of what pulsar said.
I own a 87 troopie (rust is slowly owning it )I ride a quad and I love sticking metal together. And I live in OZ... (Geelong)
Look at the second page of link it shows types of gas for the wire specified.
http://content.lincolnelectric.com/p...ature/e754.pdf |
I read the book last night in the "Library". It says Co2 gives globular transfer and deep penatration. At arc tempitures, Co3 dissacociates into CO and O2. The O2 reacts with the more reactive elements in the weld pool and float to the surface with the slag. Mn, Si and Al are contained in the core as deoxidizers to compensate for the oxadizing effect of the Co2. Phew!
The higher the percentage of an inert gas in a mixture with Co2, the greater transfer percentage of deoxidizers in the deposit. Welds made with C/25 generally have higher tensil and yield strength and approach spray transfer. Argon /Co2 mixtures are prefered for out of position welding. All parafrased from the Lincoln procedure handbook of arcwelding. My speeling is the pitts today, sorry. David
And all that sounds appropriate for solid wire, not flux-cored, though.
Hey Bro. Yes 100% Argon is the way to go with flux core for good quality welding with .035-.045 wire. I guess you allready know that your puddle appearance during the welding process will not be the same as with standard solid wire welding. Once you get used to this picture you'll have good looking quality welds with pure Argon and flux core. Stay cool and weld clean.
Second, if you are so all-fired sure that Argon doesn't affect the end result with self-shielding wire, then tell me what your charpys and tensils yielded with and without the argon. Also, please inform all of us ignorami here exactly what wire you are using. |
I can see one person is making a lot more ASSumptions about the other...
I think you need to have a talk with lincon then, the stupid engineers over there decided they didnt need no 100% pure argon and would rather have 100% CO2 or 75/25 ran with their dualshield wire.
http://www.mylincolnelectric.com/Catalog/consumableseries.aspx?browse=104|13275| In fact, I ask you to find one wire that is made for 100% argon and commonly used in the industries you mentioned.
Have we all gone mad? |
#19
WTF? a 26 month delay in this flair up. Any way I will bite. As a hobbist I run alot of shelf sheilded flux core and this is the first I have every heard of using gas with it. But when it comes to welding I will try anything once. As the shelf sheilded flux core was/is designed not to run with gas what does adding the argon do? Another words what can I expect to be different when running the beads with and with out gas and what the weld going to look like with gas? Explain more to an ignorami and I will give it a try. Maybe your talking about dual-sheild wire?
#20
Wow, everyone is in a great mood today. The original poster did not specify whether it was self or dual shield wire.
Greg, as far as Welderwoman's "practical experience" I have chatted with her several times a she is a professional weldor that dumps lots 'o' flux-core. Please provide us with where you get 100% Argon for running dual shield flux-core. We're all dying to know why everyone (Lincoln, ESAB etc...) tells us to use 100% Co2 and 75/25. Half of us here are not hobby guys, you're not the only one here working shut-downs, welding pipe and passing x-rays. But your are the only one here with a really crappy attitude. What gives? You don't have many posts and your first couple posts in.....let's see 21 months are bringing up an old argument. If you want to participate here please try to have a good attitude, or not, whatever.
Yup |
#21
I will be the first one to bow out of this. |
#22
Cool
Yup |
#24
I hope all those x-ray welds, power plant, aerospace, shipyard etc welds were run with a procedure qualified using 100% argon. If not, that's a lot of code violations that have gone undocumented.
#25
Gregg(Spiderman),
Wow! I just happened to stumble on this thread and obviously I have much to learn. As others have requested, please give us the details on the FCAW with 100% Ar. This will go a long way in helping us understand what it is you have accomplished. I'm not outright calling you a liar, but if all you can remember is the wire diameter than that holds no credibility. I find it very hard to believe that you have reinvented the wheel. That you have accomplished more than the manufacture with there unlimited resources. When performing welding to the applicable code Aerospace, Paper, Power, Chemical, and ShipYard Industries do not allow the use of 100% Ar (maybe that is something you did not know?) I would be willing to bet a weeks pay that you could not pass UT or RT or bends or tensile welding FCAW-G with 100% Ar. Just another ignorant persons opinion. David R, shielding gas has no influence on FCAW transfer mode. Additionally, FCAW is not broken down into short circuit, globular, and spray transfer modes. This only applies to GMAW
"Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." -- Seneca the Younger |
| Tags |
| fluxcore |
