FS: Idealarc 250/250 Tombstone parts: Seattle WA
Parting out Lincoln Idealarc 250/250 AC/DC "Tombstone"
I bought this machine knowing it had a problem with the DC side. I was unable to fix it after purchasing various new parts, some of which are being offered here. The transformer was bad. Serial number on the machine was AC-542016, code# 8645-C. All used items work as expected. Postage is additional and will done with USPS flat rate boxes depending on the size of the items. Purchasing multiple items will get you combined shipping. Flat rate postage is $5.35 (small), $11.35 (med), or $15.45 (lrg) Only USPS money orders or Paypal accepted. Items will be sold to the first persons who respond via PM. Sheet metal/tins: $5.00 each, front, back, hood (2-pcs.). Pretty straight, surface rust. Prefer Local pickup only on these. Power switch: New from Lincoln $30 Power factor capacitors: New, $15 Polarity Switch: Used, smooth, no pitting or burning: $30 Stabilizer Capacitor w/resistor wire: New, $10 Faceplate set of three, readable: $15 Hand wheel: used $5 Pointer and arm: new and used: $10 OEM Cart:local pickup only, $50 Rectifier Diodes (set #1): new $25 Rectifier Diodes (set #2): new $25 Rectifier overload thermostat (Klixon): used $5 Suppressor circuit: $5 Output studs (pair) : $10 Fan & Motor: $15 Click on images to enlarge ![]() ![]() ![]() ![]() ![]() ![]() ![]()
____________________ Retro_shop Lincoln V300 Pro Lincoln LN-25 w/ Tweco #4 gun Cobramatic 150-003 w/ push-pull gun Miller Dynasty 200 |
Re: FS: Idealarc 250/250 Tombstone parts: Seattle WA
OEM cart is sold.
both sets of diodes & pointers parts are sold pending payment.
Hi! I am interested in buying the 3 piece plate set that goes on
the front of the welder, and I'll probably need more parts before I'm done with this thing. Bought it in 1975, never powered it up. Going to try it now. Please email contact info. Thanks. dirkpitt@wowway.com |
Hello, I am new to this forum. I am looking for a polarity switch for Lincoln 250 250 welder and saw your post. If you have it would you email me? Thanks, Edward
any chance of you still having the two output terminals ,send contact info if you do
Felon
Caution lurker lives here " hmmm That is serious,pass the ganja and pick up a 24 of MGD" |
Still got the fan? If so please send contact intfo.
2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30 local 26 I.B.E.W Electrician |
I need the little arrow or indicator, that moves side to side to point to the amperage on the face plate.
"Stick-man is wise" - Farmall "Stick-man is right. Much as it pains me to admit it, the thieving knucklehead." tbone550 "StickyFingers-man" Commander 500D, LN25 Shopmaster 300, Super S-32P Hypertherm Pmax 600 Smith & Oxweld O/P |
