#26
Old 06-13-2007, 04:41 PM
Re: HOW TO - make a 220V extension cord
If you follow the above, you'll be fine. Home Depot cord, parts and bada-bing!
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 06-13-2007, 04:50 PM
crawler's Avatar
crawler crawler is offline
Mac,
Will 10 gauge be sufficient for 30amps (230volts)?
Thanks,
Charles
Millermatic Passport Plus
Millermatic 200
Millermatic 350P with Python
XMT 304 /w S-64 feeder and 12RC
Dynasty 300 DX
Victor O/A
Premier Power Welder for my trail junk.
Old 06-13-2007, 06:09 PM
WolfmanJack13 WolfmanJack13 is offline
Originally Posted by crawler
Mac,
Thanks,
Charles
10 gauge is perfect for a 30 amp cord.
Latest Toys Miller 180 Mig and Elite Mask!!
Wright Welder 225AC
Shop OutFitters 20/20 Bending System
Hypertherm 380 Plasma
30 Years of Sparking (Electrical & Welding)
Old 06-13-2007, 06:22 PM
MAC702's Avatar
MAC702 MAC702 is offline
#10 is what your dryer already has between the panel and that receptacle.
Old 06-14-2007, 08:27 AM
crawler's Avatar
Thanks for the info on the wire gauge... I used #6 for my receptacles since I had purchased 2 spools of 500' I didn't want to have to worry about upgrading wire later when I installed a 50 amp breaker....
Millermatic 200
Dynasty 300 DX
Victor O/A
Old 06-14-2007, 09:34 AM
lewray's Avatar
lewray lewray is offline
Heres my ole thing....sure saved my butt two days ago went out to weld on some mtr mounts and the outlet was just too far....works great
http://i204.photobucket.com/albums/b...p/DSC01050.jpg
weld it like you own it
Old 06-14-2007, 09:57 AM
rustywrangler rustywrangler is offline
Is that solid wire or stranded?
Come try it out and stay a while.
Old 06-14-2007, 10:53 AM
IrishBrewer IrishBrewer is offline
Looks good but I would like to make a suggestion.
Either get the enclosed wall-mount type receptacle or screw a metal box onto the type of receptacle shown in the photos. This will better protect the wires at this end of the cord. The type of receptacles that have their own box are nice because they have a cord clamp built into them.
Old 06-14-2007, 02:08 PM
MAC702's Avatar
It's always nice when you post something like that to at least mention to others who might try it, that it's illegal.
You no doubt did it because you were using material you had on hand. Romex, as you can see in the photo, is not very flexible, and is really only designed to be bent during a permanent installation.
Real cords are stranded with much finer wire, designed to take constant flexing which can break the larger strands in Romex, especailly if the utmost care wasn't taken during stripping of the individual wires. The slightest nick on the copper will be sure to be a broken strand in a short period of time.
I'm not telling you not to use it, and you've obviously already learned how to deal with its tripping hazards.
Old 06-14-2007, 02:11 PM
MAC702's Avatar
It's stranded, but NOT the fine stranding designed for flexible cords. It's stranded just enough to allow it to bend while being installed inside a wall.
It looks like either #8 or #6, so the main conductors will be stranded, but it will have a #10 solid for the uninsulated ground. Real cords also have an insulated ground.
Old 06-14-2007, 03:50 PM
A VERY good note to other members. Please be safe out there and try to do stuff the safest way possible.
John
Old 06-14-2007, 04:25 PM
I've done something similar like the OP only used 25' of 10/3 SOOW wire.
http://i131.photobucket.com/albums/p...5/DSCF8369.jpg
Old 06-14-2007, 06:39 PM
MAC702's Avatar
Nice cord, Rusty.
Old 06-14-2007, 06:40 PM
Very nice! Mine is more colorful though and bright!
Gotta' love safety YELLER!
John
Old 06-14-2007, 08:27 PM
lewray's Avatar
Im very impresed there Mac702 very very good observation. Yes thats very correct I should have explained it was used for a "to get out of a tight situation" I could not agree more. Yep its stranded enough just to bend which do creat hazards.
I never made it to journeyman
Then I noticed IBEW......Yep worked w/ alot with those guys and nearly joined once during the tower thing with Fuellgraf Elec. You have a Great Eye
Old 06-15-2007, 06:47 AM
tanky321 tanky321 is offline
Originally Posted by MicroZone
The receptacle end is the same - green is ground, black and white are power. I made sure to connect like colors on the "big tooth" or the larger pin. I am lacking words this morning, still first cup of coffee.
Attachment 9930
The aftermath, cut 110V connectors, various cable encasing:
That Recepticle should be in a box from what I can tell. Looks like a regular Recessed Recep from the pic. Id put it in a a 4" Sq. deep box.
Old 06-15-2007, 11:28 AM
tanky - Yes, afterwards I had installed it in the proper box, I just don't have the time to take a picture and post. It's a common sense type of thing, so I didn't bother. Thanks for pointing it out though for our other memebers.
John
Old 06-23-2007, 12:52 PM
wild west wild west is offline
I'm having a hard time finding the receptacle that's shown in that extension cord. What brand/part no. is that, and where do you shop for high amp stuff? Home depot sucks for any specialty parts.
Old 06-23-2007, 01:37 PM
MAC702's Avatar
Home Depot and Lowe's here both carry these. The part numbers will vary, but the receptacle is a NEMA 6-50R configuration. If you put that in Google, you'll get hits for the manufacturers as well as on-line retailers.
If Home Despot and Blowes in your area aren't up to par, you'll have to go to an electrical supply house.
Old 06-23-2007, 01:57 PM
Sandy Sandy is offline
The Home Depot here is pretty hit and miss on that kind of stuff. I've seen them more consistantly at local hardware stores but with quite a huge price increase to go with it. I lean towards shopping where I can get what I need and cost is secondary.
Old 06-23-2007, 02:39 PM
It looks like that receptacle is kind of like this one: leviton surface mount receptacle. That's just a wall mount style though. Doesn't it make you a little nervous having a plug laying around that is encased in steel and isn't water tight?
EDIT: I guess I can only post 1 link at a time? I have another question - I'll add another post.
Old 06-23-2007, 02:42 PM
Is there something like this for 50 amp, or would these work with 10/3 wire?
wetguard plug and this wetguard connector.
Old 06-23-2007, 02:54 PM
MAC702's Avatar
You should be able to get raintight connectors if you are willing to pay for them, but not from Home Despot. My connectors aren't out sitting in water, though, and have no need for that protection. Heck, I can't remember the last time I even saw a cloud that wasn't created by a passing aircraft.
Old 06-23-2007, 02:58 PM
LOL, yeah, I wasn't planning on welding in the rain. Just something about 50 amp/240 volt service and steel cord wraps that makes me nervous. I like my stuff to be more idiot proof, as sometimes I am the idiot. "oh wait, maybe I should turn off the breaker before I jam this screwdriver in there!"
Old 06-23-2007, 03:03 PM
MAC702's Avatar
The steel box is grounded. The electricity would much rather stay there, than go through you, even if there was a fault or wet conditions created one. But yeah, never underestimate an idiot.
Murphy's Law: When something has been made idiot-proof, someone will invent a better idiot.
[IMG] code is Off
