ASME Certified Pressure Vessel Welding records
Hi
This is a question for pro-welders who do welding that needs to be verified, NDT, and records kept for pressure vessels and critical work. I am interested to know how you keep track of all the individual welds and metal records. Do you use folders for paper records or do you scan them and record all the details in a spreadsheet or data base? Dazz |
Re: ASME Certified Pressure Vessel Welding records
dazz
Generaly both. You, yourself will have all your qualifications on paper/card and the pressure vessel agency you are qualified with will have their own coppies filed away somewhere on a database. Now, if you are a pressure vesel qualitied boiler maker making critical welds on a high pressure steam boiler on a very large project, all your welds will kept track of by the company your working for. In the event of a failed "squeeze" test on the boiler. Your weld will pont back to you.
Jason Lincoln Idealarc 250 stick/tig Thermal Dynamics Cutmaster 52 Torchmate CNC table I.A.M. Local 771 Owner/Operator Devlin Metal Works Custom CNC Plasma Cutting and Welding Last edited by snoeproe; 05-05-2012 at 12:20 PM. |
wondering what happen if a ''critical'' weld fail and they track the welder who done that job, what they tell him ? is there any epic story about that ?
Calculator > Bevel Square |
Take a boiler maker for example.
Before he gets to strike an arc on any part of a boiler, he will have already passed a test on the material he is welding. Xray passed. So, you know he can do the job. Can't pass an xray? You dont get to weld on the boiler, simple as that. Now, we are all human and a mistake can and does happen. Boiler fails a squeeze test? (and this happens), de pressurise the boiler, drain the water, open it back up and reweld the bad joint. No epic story.
Jason Lincoln Idealarc 250 stick/tig Thermal Dynamics Cutmaster 52 Torchmate CNC table I.A.M. Local 771 Owner/Operator Devlin Metal Works Custom CNC Plasma Cutting and Welding |
Dazz |
Hi
If the pressure vessel ordered by U stamp, so the pressure vessel manufacture must be ASME stamp holder which already passed the joint review by ASME designee and AIA (Authorized Inspection Agency). for more detail review http://www.inspection-for-industry.c...ification.html This article explain detail of certification process for pressure vessel manufactures manufacture responsible for sound quality control as per ASME Sec 8 Div Appendix 10, one of the requirement is welding which need to be monitored by authorized inspector it is also is necessary the welding recorded and kept another requirement is that radiography films must be kept for 5 years. for more detail review following articles: http://www.inspection-for-industry.c...section-8.html http://www.inspection-for-industry.c...re-vessel.html http://www.inspection-for-industry.c...re-vessel.html |
Not to be picking at nits, but 10-13 (ASME Section VIII Div 1) specifies a 3 year record retention period, and only the RT reports (or reader sheets) need to be maintained, not the films. The films themselves only need to be kept until the AI signs the data report (ref: UW-51)
