Cleaning flux from hard to get areas
Been lurking for a few weeks. You guys sure are a huge wealth of information. Got one question I havn't seen an answer for yet in my travels.
I've got some flux drifting into a hard to clean area (nice 90 degree corner under a lip right next to the weld area). I can't use GMAW. I need to clean that flux out of there, but I cant reach it with any combination of grinder, wire wheel, or wire brush. Is there something I can spray on, or soak it in, or something that'll remove it? --Chris |
Re: Cleaning flux from hard to get areas
The only thing for tight corners I can think of is a good pointed slag hammer.
"Flux drifting in"... Do you mean fume deposits? Or weld slag? Two different animals.
For fume deposits, even Q-tips will get it out. Wipe right off dry, and a spraydown with water and a little detergent will get the rest. Compressed air to dry. If it is slag, say because the weld is going into the corner, then you can try a chisel (a V or a cape point) if you can get a good angle; sharpen the peck end on a slag hammer to a slight chisel point and drag/scrape it into the corner; sand or glassbead blast (a pencil blast gun is a great tool for this... just be sure to meet the requirements for dust collection and breathing air filtering, or you will rapidly find yourself choking to death-- literally); If there is a straight shot, a small carbide burr (or stone point) on a long shank in the die grinder works. |
Yeah, fume deposits. White powdery looking stuff. I didn't realize it brushed off so easy. Time to go poking around at the hardware store for odd shaped cleaning things I guess...
I have a small siphon style sandblaster that I keep. If I run into Flux in a tight spot it will usually clean it right out. Just watch your eyes and lungs with the sand. Fume deposits will usually just wipe off.~Jackson
A needle gun works wonders. I have one on the truck and it will take damn near anything off.
My trick that I use at work. SCREWDRIVER. Simple, cheap, very effective. I carry an assortment in my welding bag. I sharpen them or modify them with the grinder to make them work how I need them. Like a dentist with all my "picks".
Use a jitterbug...Also known as a fingered paint chipper.
i sat use a needle scaler, those things are awesome
A large tub of water bombarded with ultrasonic waves...
One more use for an ice pick.
Specifically a needle gun!
My question would be...if you were able to weld the area how is it that you cannot get at it to remove flux?
ElvisW
Solderer Join Date: Jun 2007 Location: western new york Posts: 2 Re: Cleaning flux from hard to get areas -------------------------------------------------------------------------------- My question would be...if you were able to weld the area how is it that you cannot get at it to remove flux? come weld with me for a day
63' Lincoln SA200 2008 miller trailblazer 302 fibre-metal pipeliner miller camo BWE and all the guns and ammo a growin boy needs |
come weld with me for a day [/QUOTE]Misguided Child, read his intro. Methinks he's seen more than you, perhaps.
Elvis or tagm ? Tek me confused i have seemed to have left my brain at home.
