Old 06-08-2007, 04:21 PM
David R's Avatar
David R David R is offline
Some crap welds on a bucket
My customer wanted a "stone sifter" for his bobcat. A new one is about $1600.00. He asked me if I could convert an old bucket. I said Sure! First he wanted 2.5" spacing between the bars. I cut out one section and put in one bar. Looked way too big for me, so a phone call and we agreed on 1.5". Stock is 1/2" X 1" hot rolled. I cut the bottom out leaving the two strengtheners in place along with the cutting edge. There is 80 feet of steel in this bucket.
First I put the bars in and welded with the mig gun pointed down going up hill. Welds were terrible. No wet edges, bulged in the middle. Embaressing, so out came the gouge and away went the crap welds.
Real world weldin.
Old 06-08-2007, 04:24 PM
David R's Avatar
Re: Some crap welds on a bucket
Then I used the mig gun from underneeth and went up with the gun pointed up. Space was limited, so it was not easy.
.045 wire, 150 ipm, 19 volts give or take. Co2 gas.
Real world weldin.
Old 06-08-2007, 04:25 PM
David R's Avatar
Here is the finished product
I stood the bucket on end and finished all the welds flat because I was not going to sit under it and weld.
Real world weldin.
Old 06-08-2007, 04:34 PM
elvergon's Avatar
elvergon elvergon is offline
Any reason why you didnt clean the metal before?
I´m looking for what sifter means 8S
but looks nice and heavy
My Babies:
HF Drill press
HF Pipe Bender
3 4.5" Black and Decker angle grinders
Lincoln Electric PROMIG 175
that´s it!
Old 06-08-2007, 04:37 PM
David R's Avatar
I did clean the metal before I welded, but not the whole bucket.
Sifter is get the stones out of the topsoil.
David
Real world weldin.
Old 06-08-2007, 04:49 PM
Great conversion David - so how much did he save?
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 06-08-2007, 05:23 PM
David R's Avatar
About a thousand dollars, give or take.
David
Real world weldin.
Old 06-08-2007, 06:21 PM
zapster's Avatar
zapster zapster is offline
Moderator
Screw the Bobcat..
That would make an awesome grill..
...zap!
I am not completely insane..
Some parts are missing
Old 06-08-2007, 06:30 PM
David R's Avatar
Hmmm
Never thought of it that way.
Musta made 10 of em. 2 more by July 7th. I just happen to have some of that 1/2" X 1" left. I also bought 80 feet of 1/4" round stock.
David
Real world weldin.
Old 06-08-2007, 06:31 PM
backuproller's Avatar
backuproller backuproller is offline
i agree with ZAP, make him a cover piece for it and voila, they can grill during lunch.
"Retreat hell, were just fighting in the other direction"
Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun
Hypertherm 1000
Lincoln sp 170
2000 F-450 to haul it
Old 06-08-2007, 08:08 PM
sam -oz's Avatar
sam -oz sam -oz is offline
good looking conversion there , when you make your own equipment you save heaps which means more income at end of the day
Old 06-08-2007, 08:29 PM
usmcgremlin's Avatar
usmcgremlin usmcgremlin is offline
good looking work dave
63' Lincoln SA200
2008 miller trailblazer 302
fibre-metal pipeliner
miller camo BWE
and all the guns and ammo a growin boy needs
Old 06-09-2007, 11:19 AM
redhatman's Avatar
redhatman redhatman is offline
Very nice work, how long did that take you.
David R, in order to make a grill it doesnt have to be stainless for sanitary reasons does it?
I'm 21 and learning
Avid 4wd enthusiast
ASE Master tech (Automotive), mechanic/fabricator by trade
Old 06-09-2007, 11:41 AM
zapster's Avatar
Moderator
No not at all..
I've made many firepit grates over the yrs..
You can use any steel but I've found that hot rolled works the best...
Many commercial Grills are made of cast iron..
Stainless will bend and twist with all the heat/cool cycles..
...zap!
Old 06-09-2007, 04:24 PM
TozziWelding's Avatar
TozziWelding TozziWelding is online now
Originally Posted by zapster
Screw the Bobcat..
...zap!
Get out of my head Zap, I thought the same thing the second I saw the pic.
Old 06-09-2007, 04:26 PM
The heat off a good bed of coals will kill any bacteria long before they think of coming near you. Number 4 rebar makes nice grills.
Old 06-10-2007, 09:27 AM
Patriot Performance's Avatar
Patriot Performance Patriot Performance is offline
Screw the Bobcat..
...zap!
Now that would be a machine to take to a job site!
Just scoop up a cow and hold it over the coals!!
Patriot Performance Auto
Lincoln Power Mig 255C
Lincoln AC-225 Stick
Victor Journeyman O/A
Quincy QT-5 Compressor
Old 06-10-2007, 10:14 AM
WelderBoy's Avatar
WelderBoy WelderBoy is offline
Ya, but rust is the main concern. Just wire wheel it every once in a while and coat with vegetable oil before and after use. Voila!
btw, #4 rebar would leave some sweet grill marks!
Would make a badass grill if you used some of this STAINLESS REBAR
SWEET!
Old 06-11-2007, 04:20 PM
Greyhorse Greyhorse is offline
Ok, gotta ask. What do you use stainless rebar for? I'm going to guess nuclear powerplant or some sort of chemical plant.
Old 06-11-2007, 04:51 PM
DirtyLittleSecret DirtyLittleSecret is offline
patios
ThermalArc 185
MillerMatic 180 w/ Autoset
Victor Cutskill Oxy/Acetylene
Thermal Dynamics Cutmaster 38
and spite!
Old 06-12-2007, 11:21 AM
redhatman's Avatar
Thanks for the info guys, maybe that will be a future project of mine. Some sort of grill or smoking pit.
You guys mention rebar and hot rolled steel. What about Cold Rolled?
I'm 21 and learning
Avid 4wd enthusiast
