Old 05-09-2012, 02:15 PM
teslamusas teslamusas is offline
Thumbs up Trade / Sell Miller Auto-Darkening Helmet for Acetylene Torch
Hi guys,
I'd like to trade someone my Miller auto-darkening helmet (Performance series, good mid-range, p/n 232035), preferably for components of an acetylene rig. I need the whole rig, so I'm open to all the components (combination torch and regulators, back-flash suppressors, etc), except for the bottles and the hoses. Whatcha got?
Helmet is in like-new condition, includes replacement plate cover, bag, etc. received with purchase. I purchased new a few years ago for a welding class, but has sat on the shelf since then. Helmet works great and is lightweight, but I'd rather set myself up with an acetylene rig, which I've had the most luck with and seems to be the best suited to what I need.
Out of curiousity, why don't more people use acetylene rigs? Is the per bead cost higher than other types? I've done a bit of it, but I haven't paid to fill bottles yet myself, so I'm not too sure how long the bottles last or what the approximate per bead / per cut cost might be.
Old 05-09-2012, 03:04 PM
farmall farmall is offline
Re: Trade / Sell Miller Auto-Darkening Helmet for Acetylene Torch
Acetylene is reasonable for welding. I get my cylinders through relentless Craigslist scrounging then exchange them so I don't get boned with a lease.
Give us an idea of WHAT metal and thickness your primary welding will be.
If you have large hands or small hands, handle size will be relevant.
Do some reading here:
http://weldingweb.com/showthread.php?t=27598
Old 05-09-2012, 04:30 PM
Metal will be steel, of varying thicknesses, mostly around 1/8", 1/4", etc. May do some thinner stuff, in which case I'll get a jeweler's torch. I'm also expecting to braze and cut. I'd get a propane setup, but I'd like it to be able to weld as well.
Old 05-09-2012, 06:42 PM
You can use both LP and acetylene cylinders as fuel. Many of us do. I cut with LP, and many folks also braze with it. As long as your regulator has a CGA-510 fitting or you use a (common, cheap) adapter you are good to go.
Old 05-10-2012, 12:01 AM
Mac_nd Mac_nd is offline
Have a larger Victor torch, PM if interested
Old 05-14-2012, 10:43 PM
ironwings's Avatar
ironwings ironwings is offline
teslamusas: I have a small victor setup complete. Everything else works good. Farmalls point about LP and Acet. is good. I have used LP for almost 40 years and have learned how to weld with it (hard) and braze (Acceptable and comparatively easy) It is a lot cheaper if you are going to do a lot of cutting, and it does a better job than acetylene, less clean up etc. Uses slightly more oxygen but not noticable. One 20# bottle will last for 3 to 4 K oxygen bottles.
Old 05-16-2012, 04:21 PM
buggyman buggyman is offline
I have a complete Oxy/Ace set. Where are you located?
Thanks, Paul
[QUOTE=teslamusas;1137731]Hi guys,
Old 05-19-2012, 08:47 AM
Hi Everyone,
Thanks for the comments, and sorry for the slow response. The helmet was inaccessible while we painted the garage door. Helmet is still open for trade, thought I'd add a few pictures.
I also need to clarify the condition - helmet was used with stick welder, and so has a few tiny spots on the plastic parts. You've got to look close to see them, and they absolutely do not affect function. I'd probably say its in excellent condition, rather than like new. No marks on the clear faceplate; it's easily replaceable and helmet includes 3 or 4 unused plates.
Let me know if you have any questions!
Old 05-19-2012, 08:57 AM
second pic, padding looks new, I always wore a baseball hat
Old 05-19-2012, 08:58 AM
third pic
Old 05-21-2012, 09:37 PM
HOBART HOBART is online now
pm sent
Tags
acetylene, helmet, miller, trade, victor
