Old 06-23-2007, 09:37 PM
codenamezero codenamezero is offline
how to penetrate both metal sheet without burning a hole?
i tried to edit my previous thread's title but err... there is no option of edit post or edit thread...
my problem:
i can penetrate the metal, but i can't penetrate the second one. so i increased the power, i sorta penetrate the second one, but the first one have a hole and they don't stick...
how well do i have to clean them? if the second metal sheet have little paint on it, would it matter? since the heat is gonna melt everything including the paint anyway.
welder: Lincoln Weld-Pak 100HD, flux core, setting tried B-1.5, C-2, D-2.5
on the thin sheet of metal (first one, ~0.80 mm thick), i can penetrate it fine with C-2, and burn a hole with D-2.5
the second sheet of metal is about 1mm thick... and penetrate good with C-2
So i tried to use D-2.5 but it just burn through the first metal sheet...
how long should i hold the trigger?
Old 06-23-2007, 10:10 PM
tapwelder tapwelder is offline
Re: how to penetrate both metal sheet without burning a hole?
clean, clean, clean. At the very least it takes heat to burn the stuff away.
Could you be more clear about you joint set up? Is it butt lap or tee?
Old 06-23-2007, 11:18 PM
WolfmanJack13 WolfmanJack13 is offline
Looking at his other posts, he's usnig a mig trying to spot weld with it.
Latest Toys Miller 180 Mig and Elite Mask!!
Wright Welder 225AC
Shop OutFitters 20/20 Bending System
Hypertherm 380 Plasma
30 Years of Sparking (Electrical & Welding)
Old 06-23-2007, 11:44 PM
is lap, one on top of the other.
first layer ~0.8mm
second layer (the car frame) ~1.0 - 1.2mm
both layers have paint on them. altho i sort a sand down to the metal on the first later before i tried to spot weld it. i am wondering maybe the electricity didn't pass through to the second layer because of the paint?
i am going to clean them both, and both side tomorrow and give it another try. i was able to get a nice, ~5mm circle spot weld (on a single layer).
question:
1) is the other side of the spot weld suppose to be smooth?
2) the feeding wire, does it fuse with the metal? or it just vanish as the arc ignite?
Old 06-24-2007, 12:27 AM
Any metal being welded needs to be cleaned when using a MIG. If your work clamp is on painted material it won't provide and adequate connection.
I'm not sure what your other 2 questions mean.
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 06-24-2007, 12:59 AM
Well i tested on scrap metal... and the MIG melted a spot. So i was wondering if the back side of the spot i welded suppose to me smooth?
Old 06-24-2007, 03:03 AM
MAC702's Avatar
MAC702 MAC702 is offline
As long as it melts into the second layer, you're pretty much done when it comes to sheet metal. You aren't hanging bridges off of this.
If you are using solid wire with a shielding gas, you need CLEAN steel, no paint.
Old 06-24-2007, 08:01 AM
David R's Avatar
David R David R is offline
I think its been said enough. Clean the metal where your ground goes. Clean the metal where you are going to weld. As in BARE shiny metal.
I have been welding for 30 years and I am still not "good enough" to weld through paint.
David
Real world weldin.
Old 06-24-2007, 02:11 PM
I cleaned the metal up, to the bare metal, still couldn't get them spot welded.
At some point i got them sticked together, but the weld was so weak that i can widget it a few time and then it broke off...
I tried to hold the trigger longer so that it can burn through the second metal... but it just make a hole in the first sheet... and then the second... then the first sheet won't stick since it has a hold there... ugh.
welding is tougher than i thought lol
Old 06-24-2007, 02:19 PM
MAC702's Avatar
You said before that you are renting this equipment? I'd go back and also rent the gas shield bottle and get the .023" solid wire, as long as you're going to rent anything at all.
Then, you can turn the heat up a little bit for the solid wire, with less chance of blow-through.
Old 06-24-2007, 02:33 PM
Sandy Sandy is offline
It's good that you are doing your best to test your results before hand like this. Just picture all the pounding and vibration the front end is going to be subjected to for thousands of miles. This may be a job for small bolts and fender washers.
Old 06-24-2007, 03:26 PM
PatrickJ PatrickJ is offline
The only advice I can give is to use the higher setting (the one that penetrates the thicker metal,). Start on the thicker metal, and move very quickly on and off the thin metal and back to the thick. Make little circles, move slow on the thick side, and do a quick loop onto the thin metal.
Patrick
Lincoln 175HD
Old 06-25-2007, 11:47 AM
MoonRise's Avatar
MoonRise MoonRise is online now
"Spot welding" is a different process. Spot welding involves heat (from electricity) and pressure (from the tongs that are squeezing the two pieces to be joined together) and when the heat between the two surfaces to be joined is -just- enough to start to melt the surfaces then the pressure holds them together while they fuse together and resolidify.
Next, you can't weld paint or rust or dirt. You can weld metal (sometimes, with the appropriate welding process, parameters, and skill). So CLEAN THE METAL WELL!!!!!! Yes, I'm yelling at you.
To join two flat pieces of sheet metal together in the middle when there is no edge or seam to join them, you -make- an edge. Take your 'top' piece of metal and make a hole in it in the appropriate place and size. Now when you lay that top piece onto the bottom piece, you have an edge to weld the from the top piece onto the bottom piece. That's usually called a "plug weld". Weld the edge of the hole onto the bottom piece. If you don't need a flat surface, just weld that edge all the way around. If you do need a flat surface, weld all the way around the edge and then spiral in and fill the hole.
There is a procedure where you use a wire-feed welder to do a quasi spot weld, but because there is no pressure squeezing the two pieces together it isn't quite a spot weld and is a wee bit trickier to do. The plug weld is a better choice IMHO. And if you make the hole small but appropriately sized, you end up with almost the same result of two piece of sheet metal welded together not at the edges of the sheets.
You're working with 20 and 22 gauge sheet metal, that takes a light touch to weld them and not just blow a hole through them. Practice.
And MIG using 0.023/0.025 solid wire and C25 gas (or other argon-CO2 blend gas, C25 is just a very common and useful blend for short-circuit MIG on mild steel) would work better and be easier on that thin sheet metal than trying to use flux-core wire.
