Old 06-26-2007, 03:13 PM
zapster's Avatar
zapster zapster is offline
Moderator
Funky Two Step Journal Repair..
Have 2 Rubber covered rollers to repair..
I could'nt get the end too hot so the rubber would melt..
Hmmmmmm.......
What to do....
Here's the worn shaft..
Here's the bearing thats going back on..
Thats way too much to fill with weld..
Name:  Too much to weld.jpg
So here's what we're gonna do..
Just weld as "normal" and make it all nice nice..
Put it in the lathe and turn the new bushing step..
Name:  Finish step 1.jpg
OK...
Now I have to go down front and make a bushing..
Back in a few..
...zap!
I am not completely insane..
Some parts are missing
Old 06-26-2007, 03:21 PM
zapster's Avatar
Moderator
Re: Funky Two Step Journal Repair..
I hate the other lathes...
After 20 min. heres the new bushing..
.005 shrink fit so heat it up!!
Name:  Heat it up.jpg
Now heres a little trick for you..
The bearing landing is .900 wide..
So make the bushing .700 wide..
Install in the middle of the landing...
And now you have .100 to fill in on each side so when you finish turn it you won't turn all the weld off..
Now weld it...
Name:  Bushing welded.jpg
Now finish it!
Name:  Finished shaft.jpg
The new bearing surface is .0015 bigger so the bearing will "tap" on with a light hammer...
I gave the journal where the key is the "once over" with the welder just so I know everything runs true after..
And we do not have to re-cut the key either..
I get all the fun jobs...
(And this only took 2 posts......)
...zap!
Old 06-26-2007, 03:43 PM
MoonRise's Avatar
MoonRise MoonRise is offline
But, where's the dime????
Interesting optical interference banding in the pic of the plain bushing.
You didn't have to skim cut the keyway at all?
Nice job as usual Zap.
Old 06-26-2007, 03:59 PM
zapster's Avatar
Moderator
No we don't..
We try everything we know to stay away from the keys..
Before with the stick welder it was pretty tough to do..
But with the tig now its relativly e-z..
...zap!
Old 06-26-2007, 04:33 PM
welder.man's Avatar
welder.man welder.man is offline
Nice work Zap.
Simon
Label Everything
Metal Fabrication - Welding Repairs - Wrought Iron - Sign Writing - Custom Decals.
Old 06-26-2007, 04:42 PM
Hammack_Welding's Avatar
Hammack_Welding Hammack_Welding is offline
Nice work zap, as always.
Old 06-26-2007, 04:46 PM
olddad's Avatar
olddad olddad is offline
Resident Curmudgeon
Yep, nice work as usual, sure wish I'd learned the machining end of the deal at some point in time.
Anything worth doing is worth doing RIGHT
Old 06-26-2007, 04:52 PM
zapster's Avatar
Moderator
Lathes are fun-duh-mental
...zap!
Old 06-26-2007, 06:22 PM
Great job, you have both ends to do, right?
That's why you get all the fun jobs!
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 06-26-2007, 06:37 PM
usmcgremlin's Avatar
usmcgremlin usmcgremlin is offline
looks good like normal Zap!
63' Lincoln SA200
2008 miller trailblazer 302
fibre-metal pipeliner
miller camo BWE
and all the guns and ammo a growin boy needs
Old 06-26-2007, 06:38 PM
zapster's Avatar
Moderator
Both ends on the other one...
(Not there yet)
Just this end on this one..
...zap!
Old 06-26-2007, 07:45 PM
MAC702's Avatar
MAC702 MAC702 is offline
Good thread. Thanks for sharing all the details, too.
Nice pics as usual.
Old 06-26-2007, 08:20 PM
jamlit's Avatar
jamlit jamlit is offline
Nice work Zap.
Miller DVI2
Lincoln Precision Tig 225
Thermodynamics Cutmaster 38
Everything else needed.
Old 06-27-2007, 09:08 PM
Joker11's Avatar
Joker11 Joker11 is offline
I don't see the rubber on the roller. It is hard for me to sometimes visualize what is going on. Looks like a great job.
Lincoln Power Mig 350MP Ready Pak
Lincoln Precision TIG 275 Ready Pak
Lincoln WeldPak 100
CK TIG TORCH gas diffuser and pyrex cup
A stout 15 yr old son to help!!
Old 06-27-2007, 09:59 PM
phila.renewal phila.renewal is offline
This kind of rings a bell. I remember reading about sleeving journals that could not be welded up as usual because of some reason I can't remember (something to do with how they were heat treated maybe?).
Anyway, shear genius as usual.
Favorite right now is a Miller Syncro 200.
Tons of tools and I blame at least one of them when things don't go right.
Old 06-30-2007, 07:34 PM
elvergon's Avatar
elvergon elvergon is offline
SOo
what happened to the ruber? :P
Nice work zAP!
My Babies:
HF Drill press
HF Pipe Bender
3 4.5" Black and Decker angle grinders
Lincoln Electric PROMIG 175
that´s it!
Old 06-30-2007, 08:03 PM
tresi's Avatar
tresi tresi is offline
I wish I had a big lathe to do that kind of work. Then again I wish I had room for a big lathe. Great job.
