Old 05-05-2004, 05:45 PM
Mike W Mike W is offline
Pic of my battery charger/mig welder
This is a 24 volt, 100 amp electronically regulated charger. It is rated continous duty with no fan. I plug in either the Lincoln or the Miller wire feeder.
I had to do a couple on minor mods. It had a walk in circuit to limit the current when it first comes on. I disabled it. It has 300 amp diodes. I re-calibrated the amp meter to read half the actual current.
http://img36.photobucket.com/albums/...t=DSC00278.jpg
Old 05-05-2004, 06:14 PM
MAC702's Avatar
MAC702 MAC702 is offline
Re: Pic of my battery charger/mig welder
I love the idea and the ingenuity. I can't figure out why you wanted to only read half the current, though. Maybe I'm overlooking something really obvious.
Old 05-06-2004, 03:56 AM
Hi Mac, actually I changed the meter calibration so if it reads 50 amps, the actual current is 100 amps.
Old 05-06-2004, 11:15 AM
david_r david_r is offline
But why?
Have you tweaked it so it'll put out more than 100 amps actual?
Old 05-06-2004, 02:09 PM
Right, I tested it at 150 amps. I just needed to get the meter to read more then it's 100 amp full scale reading. The charger had a current limiting circuit circuit that I disabled.
Old 05-06-2004, 02:37 PM
morpheus
Guest
Posts: n/a
that battery charger is a lot bigger than I had imagined !
Old 05-06-2004, 05:33 PM
It is a little heavy. I made a dolly setup so I can move it around in the back yard. I once had the Miller wire feeder winched up 12' in the air.
