Old 06-04-2012, 03:01 PM
anickode anickode is offline
Any Punkin Chunkers out there?
I've been watching the annual Discovery Channel Punkin Chunkin specials on netflix recently, and it's been giving me the itch to try it out. I've built air cannons of every sort to launch all sorts of stuff. Nothing that big before though.
Anybody around here who has previously or is planning to compete this year?
Old 06-04-2012, 05:46 PM
ThorsHammer's Avatar
ThorsHammer ThorsHammer is offline
Re: Any Punkin Chunkers out there?
I'm more the Trebuchet type myself, that being said I have yet to chunk my first punk, but it'll happen. Still in the design stage of my trebuchet so it's still all small scale.
There are no problems. There are only solutions. It's your duty to determine the right one.
Hobart Handler 210
Airco 225 Amp MSM Stinger
Old 06-04-2012, 08:24 PM
Trebuchets are definitely cool. I'm definitely an air cannon/centrifugal guy though.
I've got a design in mind that would in theory give far better performance from a shorter barrel and smaller tank than many of the huge 2000+ gallon tanks with 100 foot barrels. It's all about the valving.
Old 06-05-2012, 12:07 AM
Dualie Dualie is offline
i threw a punkin out of an suv going 75 once does that count?
Vantage 500's LN-25's, VI-400's, cobramatics, Powcon inverters, XMT's, 250 Ton pacific 12' press brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas.
Lincoln idealarc tig 330A with bernard cooler Sync350LX. Miller migs, marvel saws
Old 06-05-2012, 12:54 AM
jbmprods jbmprods is offline
i hope you did better than my high school buddy did off the back of my 52 international 1 ton flat bed when we were bombing mail boxes. we cut off his drinken when he forgot to let go of the punkin. thank god it was a wood 4x4 post that was rotten at the base cause at 50 mph he did a sweet body slam on that puppy lol.
225NT bobcat
AEAD200LE
Scott 125
mm175, mm252 w 30A, PT225
mm211, TA 181i
Hyper Therm 380, cut master 52
9100X & XX, Digital Elite
6 Victor sets
smith little torch, meco midget
kalamazoo band saw
steel max saw
evoulution circular saw
Old 06-05-2012, 02:10 AM
Now that i would love to see! we also threw one of of a 150 condor man lift just to see what it would do.
Old 06-05-2012, 12:49 PM
socoj2 socoj2 is offline
Only so much. Unless you wanted to do Helium.
Air has a fixed Expansion rate so even if you have a 100% efficient Valve with the same orrafice as your pipe you are still limited by the barrel size.
Old 06-07-2012, 05:23 PM
Official chunkin rules prohibit the use of purified industrial gases for chunkin. It's compressed air or nothing.
Besides... It would take about a blimp's worth of helium to fill a cannon like that, which will likely NEVER be in my budget.
The efficiency and diameter of the valve is the most important thing... followed closely by the quality of the air you put in it. (moisture content being the key factor)
Most of the cannons out there use a pneumatic ram attached to a butterfly valve, and while that's faster than you could manually turn the valve, there's a LOT of improvement to be had.
