Old 05-11-2004, 04:49 PM
fatfrank fatfrank is offline
New Axle
So after getting advise from you guys, I was planning on modifying a new axle to fit my trailer. I call a local trailer place to find a 3500lb axle. He said that he would put on spindles and hubs at the length I wanted for about $75. I thought, what a great deal, just the hubs run about $35 and spindles around $15 each. That put me at about $100 just in parts not including labor. So I go to pick up the axle and new tires and this is what he gives me.
Old 05-11-2004, 04:51 PM
The spindle is 1 and 5/8 inch diameter. The center of the axle is 2inch square tubing. and the ends that are holding the spindles on are made of 2 and 1/2 inch angle iron welded togather
Old 05-11-2004, 04:52 PM
Here is another shot of the axle.
Old 05-11-2004, 04:54 PM
And I thought I was an amature welder. I am no longer embarassed to show my welds off. Here is a close up of some of the welds.
Ok thought I would throw in a pic of myself just so you would know how handsome I am. LOL
Old 05-11-2004, 04:55 PM
Forgot to put in the pic.
Old 05-11-2004, 05:01 PM
Brainfarth's Avatar
Brainfarth Brainfarth is offline
Ewww... Looks like the welder ate at Taco Bell
Common sense in an uncommon degree is what the world calls wisdom.
Old 05-11-2004, 05:06 PM
Hobweld Hobweld is offline
I'd say you bought the parts. Myself, I would grind that mess out and reweld what I could. I'd sure find a better way of extending an axle. The porosity and contamination in those welds are terrible. Good luck.
Old 05-11-2004, 05:14 PM
Did you guys notice how the spindle is welded into the angle iron? If you look in my second picture, it is only welded on the right side and the bottom. There is a gap about an inch wide on the top of the spindle and the left side of the spindle.
Old 05-11-2004, 05:25 PM
enlpck enlpck is offline
I would certainly have...questions about the quality of the welds. If the welds have decent fusion and are of sufficient size, they may just be uglier than a deer after a train hit-ugly welds arn't necessarily bad. Unfortunately, A couple of the welds in those shots look cold-lapped, giving them no strength.
If you can cut the angles apart and expose the spindle welds, you may be able to fit reinforcement in and reweld the removed pieces. Otherwise, it's a nice kit you have there.
Kinda scary, some of hte 'professional' work on the road, eh?
Old 05-11-2004, 05:40 PM
I am thinking of just cutting out the parts and getting a new axle and cutting it to length. What size pipe or square tubing would you guys think I should look for( OD, ID or schedule? not sure of common sizes available?). I believe that the part of the spindle you insert in the axle is 1 5/8 inches.
Old 05-11-2004, 05:41 PM
Sticky Sticky is offline
Fat frank,
Please show us more pictures of your bbq smoker and tell us about it. I want to build one this month.
Old 05-11-2004, 05:53 PM
Sticky, no problem. I just got it painted up this past weekend and now I need to make the cooking racks and put on the new axle and chrome wheels. That would have been done tonight, but its looking like more than just bolt the new axle on . I will get some finished photos by the weekend and start a new thread on it in a few days.
Old 05-11-2004, 06:54 PM
Jim314
Guest
Posts: n/a
Your certainly better looking than the welds
Nice looking smoker too !!
Old 05-11-2004, 07:13 PM
7018 7018 is offline
Moved On
1 5/8 spindels fit in 2x2x3/16 sguare tube thats what i used to use when i was building trailers for the farn center here.Never had any trouible from them.That guy u got the from should be put in front of a fireing squad
Old 05-11-2004, 07:15 PM
Moved On
OOOOOO if u build one find center of the tube run 4 inches of weld with 7018 each side of center 4 places it will give u the right amount of camber.
Old 05-11-2004, 09:56 PM
SlagKing
Guest
Posts: n/a
FatFrank. Your a good looking guy, and if it wasn't for me, you'd be the best looking weldor on this site. Those welds don't look very good. I'm sure you can repair that axle, and be proud of doing it correctly. Would like to see a picture or more when you get it done. Then maybe show the guy you got it from the way it should have been done.
Old 05-11-2004, 10:58 PM
Paychk
Guest
Posts: n/a
I'm finding hard to believe that you paid for that.......unless you just wanted the huds & axle stubs so you could build it the right way.
Old 05-11-2004, 11:55 PM
TheFrenchCanadian
Guest
Posts: n/a
7018, Can you elaborate on the caveman speak? I'm interested in knowing what this technique is, but can't seem to translate anything tonight!
Luc
Old 05-12-2004, 12:02 AM
Franz Franz is offline
Since Jack is doubtless otherwiuse occupied, NICE use of astrigals on the smoker.
Now, I see a lot of bird**** on that iron, but where are the welds?
Did that POS come with a complementary can of Bondo?
Where the hell are the spring perches?
Will you be using Vaselene or KY when you give it back to him?
Old 05-12-2004, 04:15 AM
Brainfarth's Avatar
I’m wondering something… Does the date of them welding the axle coincide with “take your kid to work” day?
Old 05-12-2004, 04:18 AM
Brainfarth's Avatar
TheFrenchCanadian, when you weld on one side of a piece of flatbar, it tends to camber twards the weld side.
Old 05-12-2004, 05:25 AM
Moved On
Well i guess Brainfarth told u what u needed to know,tubing does the same thing, the welding causes it to arch alittle u would put the arch up this giving u the needed camber,or off set to ur wheels.also dont drill the spring locating wholes in the axle.drill them in a peace of 1/4 inch flatbar and weld them to the tube!!
Old 05-12-2004, 10:50 AM
The only reason I went ahead and bought it was they were charging me less than what I could buy the parst for and also I was buying some wheels and tires from them. I figured it wasn't that big of a deal because I can fix it and I was in a good mood and not wanting to ruin it by being an a-hole.
So anyway, I went last night sorted through my neighbors junk pile and found a some sections of oil field pipe that I may use for a new axle. The pipe is O.D. of 2 3/8 and looks to be about 1 7/8 for the I.D. I found some spindles that are 1 3/4 for $15. I think it may be easier to just cut a section of pipe and insert new spindles and reuse the hubs rather than cutting out the poorly welded ones. I want to have this road worthy by friday and only have 2-3 hours in the evening to work on it. Do you think this pipe will be ok for an axle?
Franz, nice use of the work astragals. I had to look it up to see what it meant I thought I was just covering up my crooked kerf so no one could notice. LOL
Old 05-12-2004, 12:28 PM
Oh yeah, 7018
Now when putting the camber in can you elaborate on the weld postions. I understand that it needs 4 welds on each side of center, each being 4 inches long. Are the welds side by side or end to end?
I kinda assume side by side, if so how do you space between the welds? Does each stringer touch the next, or do you space them apart 1/8-1/4 inch. Also how close to the center line would you place them, just a couple of inches off the center line? Does the same hold for round tube as square.
I realize that I am asking you to be real specific, but I want to get this on the first try and not have to keep messing with this. I appreciate your help. I know it must suck having to teach a rookie over the internet.
