Old 06-08-2012, 05:24 PM
wd40prerunner's Avatar
wd40prerunner wd40prerunner is offline
Drill press table
Got tired of losing my chuck key. Clamp made from 22g and table made from 18g all welded at 70amps with silicon bronze.
SIN CITY METAL WORKS
visit my YouTube channel
https://www.youtube.com/user/devvon
Old 06-08-2012, 06:58 PM
Jürgen Jürgen is offline
Re: Drill press table
Looks nice
One question: what is the advantage of the silicon bronze over the E70S2?
Old 06-08-2012, 07:30 PM
Originally Posted by Jürgen View Post
Looks nice
Melts at a lower temp... On thin sheet metal it helps with warping
Old 06-08-2012, 10:05 PM
Lanse Lanse is offline
Wow, nice work
"Overkill is an often under-rated achievement" -Will Hayden
HTP Mig 2400
Hypertherm Powermax 45
Lincoln Precision Tig 225
Longevity StickWeld 250
Hobart Stickmate AC/DC
Hobart Handler 187
a.k.a ChuckE2009 on Youtube
Old 06-08-2012, 10:32 PM
Originally Posted by Lanse View Post
Wow, nice work
Lanse i think your drill press needs one pm me!
Old 06-09-2012, 11:54 AM
CharleyL CharleyL is offline
I can see doing that for the oil can, but for the chuck key?
I put a strong magnet on the side of my drill press head. It holds itself in place and also holds the chuck key very well. The magnet is well above the work, so it doesn't collect chips unless they are on your hands when you reach for the key.
Charley
Miller MM252
Miller Bobcat 225NT
Miller DialArc HF / DIY Cooler
2 Victor O/A Torchsets
Milwaukee 8" Metal Saw
Milwaukee Dry Cut "Chop" Saw
5 Ton Wallace Gantry
Various Grinders, Benders, etc.
Old 06-09-2012, 05:51 PM
DanT DanT is offline
I like the idea. Another shelf is almost always handy and magnets aren't always what you want. Looks good!
Old 06-09-2012, 07:20 PM
Stampeder Stampeder is offline
Nice job. Had a plastic one but it bit the dust. Need anohter and I like what you did.
How did you cut the major diameter of the 22g clamp. Inner done with hole saw. What size is the outer diameter?
Also, how did you account for the rack that the table rides up and down on? Can you show us that side?
Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Old 06-09-2012, 09:46 PM
lik2waterski lik2waterski is offline
very nice, I need one well two of these..
Old 06-09-2012, 10:49 PM
SWells's Avatar
SWells SWells is offline
Moderator
Paint the key red, make it a bit easier to spot. I chunk of rubber tubing over one side of the "T" handle and attach it to something helps too. Nice tray BTW!
If you don't want to stand behind our Troops, feel free to stand in front of them.
Old 06-10-2012, 11:31 AM
the rack you are talking about ends about an 1" below the table so that was not a factor. i cut the out side diameter with a plasma
Old 06-10-2012, 01:29 PM
garagecat's Avatar
garagecat garagecat is offline
The simple fix is to silicone a chunk of tubing to the head of the drill press. But then overkill is always a good thing!
