Old 08-01-2007, 10:26 PM
WelderBoy's Avatar
WelderBoy WelderBoy is offline
Highest Amperage you've ever used at work
The highest I have ever used has been 400+amps with the air-arc, and about 350 amps welding with 1/4" 7018, and around 350 with 1/16" wire but with the wire you can't say exactly, but I know it is in the 350 range.
But today on our jobsite we were sub-arcing a piece of 1.5" plate with 5/32 solid wire. I asked what they usually set it for and he said close to 1,000AMPS. HOLY HELL! The machine we use at work for this is a Dialarc 1,000. It welds up to 1200amps, and welds 1,000amps at 100% duty cycle.
I was very impressed at the disposition rate of this subarc machine on that plate. It moves 10 times quicker than I do when welding and shoves in about 100 times more wire. The wire was as thick as a pencil. Pretty cool stuff.
So let's hear it, I know there are some crazy welding processes out there, and I know some of you TIG pipeliners weld up to 700 amps on big thick pipe.
Old 08-01-2007, 10:31 PM
tanky321 tanky321 is offline
Re: Highest Amperage you've ever used at work
This my friends is going to be a sweet thread!
Old 08-01-2007, 10:37 PM
Hammack_Welding's Avatar
Hammack_Welding Hammack_Welding is offline
I've used around 400 or so once arc gouging, but actually welding I don't think I have ever gotten much over 310-315. Most usually around 250-285 on a frequent basis.
Old 08-01-2007, 10:43 PM
lewray's Avatar
lewray lewray is offline
lol ...yep my thoughts exactly
weld it like you own it
Old 08-02-2007, 12:14 AM
tanglediver's Avatar
tanglediver tanglediver is offline
130 amps. Vertical down on my cert. test plate, to repair undercut. WHAT? It's allowed!!
At work the machine we got says 1-6 hi & lo, what does that tell you, it's a 200 amp MM and I have never had it all the way up, even for practice.
Cutting, 30cfm and 5cfm standard torch cutting. D'OH!
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 08-02-2007, 12:31 AM
ABwelds ABwelds is offline
I've gotten the Tig up to around 300, arc-air about 350-400, wire feed I've done to around 200 spray-arc... 250-300? stick I've done 150
Old 08-02-2007, 06:07 AM
David R's Avatar
David R David R is offline
My machine will go up to 425, but I have never been there. I have a demand meter, so sometimes when I have the welder cranked up, I turn off the air compressor. My Ranger 250 will put out around 300 and I have had it there a few times. Usually its for wire feed. I gouge around 200 to 250. 3/16 7018 @ about 230.....5/32 7024 220 amps.......
David
Real world weldin.
Old 08-02-2007, 06:46 AM
Heres some really impressive stuff, 3/4" X 36" Rods Who the hell knows what amperage.
Do some reading its really impressive.
http://hobartwelders.com/mboard/show...ight=big+welds
Old 08-02-2007, 06:50 AM
weldrwomn weldrwomn is offline
I'v gone up to the 550 - 600 amp range with 7/64 flux cored wire. That is smokin' hot
Old 08-02-2007, 07:01 AM
lewray's Avatar
Thats crazy I have one of those...the MM 200 with high and low very old,but its a great machine. I had it cranked out yesterday (on high) at tap 6 using my friend's spool gun doing some spray xfer on some 3/8 plate just practicing. It was definately topped out hot.
I also have an old 3 phase AIRCO 250 or 300 cant remember; however , I never got passed 150 amps. The feeder is not working and broke before I could crank it up.
I always wondered what it was like to weld at 300 amps for hrs at a time. Im sure some folks on here could share some stories. Like the Navy yards and places like that where you can't do submerged arc in certain situations.
WELDRWOMN ... the fluxcore 7/64 up to 600 amps? what the shmell were you welding? Or better what were you WEARING a volcano suit ...
Old 08-02-2007, 11:28 AM
lars66 lars66 is offline
800 amps air arcing.
Old 08-02-2007, 04:52 PM
I usually keep this machine on the lo tap and run as much as 5 with regularity. Some very light duty sheet metal I will stitch together on lo 1. We do mostly trailer repair and light fabrication.
Job 28:1,2
Danny
Old 08-02-2007, 05:47 PM
enlpck enlpck is offline
400-600 air-arcing on occasion, odd times 250-300 with 7024, but usually below 150A for welding. Nature of the work.
Old 08-02-2007, 06:08 PM
TozziWelding's Avatar
TozziWelding TozziWelding is online now
Over 400 amps arcairing, never over 250 amps daily.
Old 08-02-2007, 06:14 PM
Okay...
1 million jiggawatts ! ("Back to the Future" ref.)
Just a good day and wanted to post.
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 08-02-2007, 06:33 PM
I just remembered, we had a 1200 amp spot welder in school, that baby would do 2 pieces of 1/4". Why it was in a high school metal shop is still a mystery to this day.
Old 08-02-2007, 07:53 PM
Supe's Avatar
Supe Supe is offline
2" thick steel on the CNC plasma. We've got tandem power supplies for it...
Old 08-02-2007, 08:23 PM
WelderBoy's Avatar
Donation?
Old 08-02-2007, 08:26 PM
zapster's Avatar
zapster zapster is offline
Moderator
250 D.C.
310 A.C.
...zap!
I am not completely insane..
Some parts are missing
Old 08-03-2007, 11:06 PM
PatrickJ PatrickJ is offline
Gouging - 550 Amps on old Lincoln Idealarcs.
450 Amps w/400 in/min wire feed speed with NR-305 wire, either 5/64" or 3/32", I don't remember which. This was yesterday, my first day actually doing structural welding, as I was inside a sidebox of a barge that was laid on it's side.
BTW, 94 degrees, 90% humidity inside a confined area running 15' long beads with that hot a wire while wearing leathers absolutely sucked, especially the two hours before they found me a fan. Then they tell me I don't need to wear leathers while flat welding, that would've been nice to know when I got there. But they did give us two extra breaks when they brought everyone popsicles.
Patrick
Lincoln 175HD
Old 08-04-2007, 12:05 AM
WelderBoy's Avatar
Welcome to the wild world of ship building! Get used to it
Old 08-04-2007, 07:21 AM
12,000 Doors's Avatar
12,000 Doors 12,000 Doors is offline
I think it was around 300 burning some 1/4 7018s on some thick "I" beams. Been a long time and all I remember is that the spatter was so hot that it ignited part of my hair.
Old 08-04-2007, 08:45 AM
billniece's Avatar
billniece billniece is offline
Somewhere in the neighborhood of 450-485 gouging w/ a 3/8" rod and 225 using 7018 on 1/2" plate. Also around 300-350 using some P-5 hotrodding hex stainless.
Bill Niece
Old 08-04-2007, 10:03 AM
KRS KRS is offline
20 amps (less is more!).
just kidding guys! Off to go trail riding on the KLR650!
Lincoln AC225 stick welder
Lincoln HD100 WeldPak flux core wire feed welder
Three of the cheapest grinders money can buy
Old 08-04-2007, 02:47 PM
Had one like that (briefly) a few years ago. Had to break 10 min each hour and drink water until you pee. Couldn't go back on until peeing.
