Need to raise my truck
I have a 1988 ford f150 short bed. I need to raise the rear end up about 2-4 inches. I tow a light trailer, however with hitch system underneath the bumper the trailer is tilted downward. Any suggestions on the best/simplest way to do that?
Thanks |
Re: Need to raise my truck
air bags are pretty simple, and should allow you to change the height enough. as well as let you lower it back down when your not towing
We need pics...
Wouldn't it be easier to raise the hitch?? Is it a reciever hitch??
Miller Econotig Cutmaster 38 Yes ma'am, that IS a screwdriver in my pocket! |
Yes it is a hitch receiver. It sit below my bumper. Do thy make a receiver that goes up. Mine has a 1 inch drop.
Thanks |
Take the ball out, put it in upside down. Presto, 2" higher!
They sell hitches for receivers that raise or lower the ball 6" depending on which way you put it in the receiver.
Mike
Ol' Stonebreaker "Experience is the name everyone gives to their mistakes" Miller 175 mig Miller thunderbolt ac/dc stick Victor O/A setup Makita chop saw |
There are also a huge variety of affordable spring additions out there but they generally lend themselves better to permanent loads or you end up with a pick-up with a jack rabbit profile that'll jump two inches on every bump ya hit. |
Joe is right, adjusting with a hitch receiver could not be easier. With the correct ball mount orientation, the truck should be level and the trailer should be level.
The height of the trailer coupler should be set to be level or close to level.
So, just get the hitch with the right rise/drop to work with your trailer! Now, if the rear suspension on the truck is to soft for the tongue weight of the trailer, then you need to stiffen the suspension. Air bags, or new/extra leaf in the rear springs, etc, etc. |
If you want to lift it I would suggest re positioning the rear shackle hangar. You can either flip it, make new ones, or find something that works. I found a set of front spring hangars off an f-550 and ran my shackles upside down, I boxed them for strength.
You need to call John McGee at Tennessee Offroad just down the down the street from you I believe. Shop # 248 8638
weld it like you own it
Thanks,
I will flip the hitch over,first. Thanks Lewray, I know of a TN offroad in Franklin. |
Yup, flip the ball mount or change shackles if ya want your truck higher anyway.
Dewayne Dixieland Welding ![]() ![]() MM350P Lincoln 100 Some torches Other misc. tools |
