I just had the machine completely gone over and replaced everything that needed it.I put a new radiator, a new alternator, new battery, rewired from the inside out, and also completely rewired machine, new brushes inside and out. The motor is the F-162 no oil leaks and runs like a champ no misses ever, idles down and purrs like a kitten. I put a new pc board, and new gauges that needed to be replaced, new range selector, new carb. i did leave the magneto system on cause its never given any problems. its wired up for a Lincoln remote but can be switched to a cables very easy. I also repainted the machine to a glossy black and added a new stainless hood its beautiful a must see, I cut the machine down 7" to make it shorter. I have a truck that its on that i can sell too, its a dodge 3500 2wd with 230000 that runs fabulous and a fresh paint job on the welding bed, im just getting out of pipeline welding and doing more inspecting. There is leads and torch hoses to go with it, I am asking $13000 for all of it but will separate If you have any questions call or txt. 2252531847
