TIG welding amperage requirements
I'm looking at getting a TIG welder in order to weld aluminum. The material will be mostly in structural tube and bar stock with thicknesses of 1/2" and under...mostly 1/4" and 3/16", though I do plan to weld tabs to thicker materials occasionally. The big question here is can I get away with one of the TIG welders producing amperages of 160 - 200 amps by using multiple passes on short welds,( say a 2" long x 1/4" thick tab), to thicker materials, (say 1" thick) plate ?
Re: TIG welding amperage requirements
If its a routine thing, you may be money ahead to just buy a TIG unit with higher output from the get go. Between the time you'll take preheating and the tanks of helium you'll be buying...
I have an arcmaster 185. 1/4" plate is about as big as it goes. That is with wave balance around 25%, 25 Hz. A water cooled torch would be good for you.
David
You need a 300 amp watercooled machine and a gas mixer...
Then you'll be all set.. ...zap!
That just depends on how big that 1'' plate is...you was doing pretty good until you mentioned that part. A couple sqare feet? If it was a regular thing then you're gonna need something bigger but for just a one time project a little pre-heat can go a long way (altho myself I just blast it with a ton of power when 200 amps ain't cuttin' it!!)
I just got a 200 Dynasty and I will say it does amaze me so far..I looks like it'll do 90% of my mobile biz.
Miller Dynasty 700 ![]() Miller 350P ![]() Bobcat 225 NT Dynasty 200 DX ![]() 30-A spoolgun Spectrum 300 Enuff power and hand tools to fix or create one of anything but mass produce nothing!!! |
what ZAP said ,and even if you dont get a 300 amp'er 5min of tiging
with the machine maxed out and you'll beg for a water cooler torch
![]() Chuck ASME Pressure Vessel welder |
No matter what get a cooler for the torch, your hand and the torch will appreciate it!! Aluminum takes A LOT of heat.
Thanks for the help ! I think that the 1" plate is definitely out, I'll just stick with bolted connections on that material. A water cooled torch would be neat, but I think that I'll just have to see how much of this I end up doing. I'll post some pic's when I get this going.
