Rivet Nuts
I'm thinking about using some rivet nuts on an iron bed project. The nuts would be inserted in some .065 mild steel 2"x 2" tubing. 1/4" x 20 is the size. Never used these gizmo's, do they work? spin in the hole? pullout?, any info would be appreciated.
Thanks, Ragnar |
Re: Rivet Nuts
A lot of the truck boxes are manufactured with the door hinges fastened on with a type of rivet nut. Seems to work ok in that application.
Anything worth doing is worth doing RIGHT |
Re: Rivet Nuts
Ragnar, I'v used them before and had no problems. You need a special tool to install them. Tighten them up like a pop rivet without the pop.
![]() Doug |
Re: Rivet Nuts
Guys,
Thanks for the info, McMaster Carr seems to have it all, including a reasonably priced install tool. Thanks, Ragnar |
Re: Rivet Nuts
Like anything else, they got their good points and the bad. Be careful to not crossthread the bolt or bind it in any way. If you use too long of a bolt and run out of threads and the shoulder hits the nut, you will spin 'em. Use anti-sieze and the right bolts and your ok.
Re: Rivet Nuts
I had no faith in them. But I bought an old 61 VW Baja bug. The old timer I bought it from made a custom roof rack for spare tires and such.
When I removed the rack one day, I noticed he used rivet nuts. I had beat the HECK out of that car. The rivet nuts were still intact the day I sold it years later. If installed and used properly I say they do a decent job.
Lincoln Power Mig 350MP Ready Pak Lincoln Precision TIG 275 Ready Pak ![]() Lincoln WeldPak 100 CK TIG TORCH gas diffuser and pyrex cup Thermal Dynamics Cutmaster 101 A stout 15 yr old son to help!!
Re: Rivet Nuts
We use these things on all kinds industrial machines for all sorts of attachments such as guards and cover panels.
They work great and are a fantastic option for installing threads into items that are too thin for taping threads into. Sure they can be cross threaded and stripped out just like any other thread. However if you have the tool to install them they are also as easy to replace as a pop rivet. They wont pull through the metal because they are larger on the back side. Washman |
Re: Rivet Nuts
use em every day by the hand full ,thay work real good
![]() Chuck ASME Pressure Vessel welder |
Re: Rivet Nuts
a little trick to keep them from spinning in the hole is to use a star looking lock washer under the head of the Riv nut and it also gives it a little more thickness to clamp onto when you squeeze them.
just a trick from the aviation world when we use them
People are more violently opposed to fur than leather because it's safer to harass rich women than motorcycle gangs. Unknown Pro Mig 175
Hyphertherm 600 Lots of toys at work |
