Old 10-16-2007, 05:42 PM
j toney j toney is offline
tensileweld rod
would this rod be o.k to tig 4130 chromo tube for a chassis. would it be to brittle?is there a better rod to choose? i have used the ers70-s2 but the tensilweld rod seems to be a little more fluid. thanks in advance.
Old 10-16-2007, 05:49 PM
zapster's Avatar
zapster zapster is offline
Moderator
Re: tensileweld rod
Never heard of "tensleweld" rod..
Is it rod or filler?..
I Myself would just use 70S-2...
But thats just me..
...zap!
I am not completely insane..
Some parts are missing
Old 10-16-2007, 05:58 PM
Re: tensileweld rod
it is made by washington alloy. the guy at the local welding shop told me it was the same as "missle rod" which is i guess a high nickel rod.
Old 10-21-2007, 11:35 AM
boilermaker boilermaker is offline
Re: tensileweld rod
I use it quiet a bit but you should preheat, and stingers only if you are stick welding with it . as for tig hey why not it is tuff stuff, just make sure all the flux is off and very clean.
Old 10-21-2007, 05:32 PM
weldgault's Avatar
weldgault weldgault is offline
Re: tensileweld rod
B2 wire (1 1/4 CR 1/2 Mo) is the choise for some people, but what you have will probably be OK and will save some $'s. John
SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFC
and Shielding Gases. There all here.
Old 10-21-2007, 06:35 PM
Supe's Avatar
Supe Supe is offline
Re: tensileweld rod
If you want fluidity, go with 70s6 wire. Most people use the 70s2 because it is LESS fluid, and makes for a more controllable puddle when out of position.
