Old 06-21-2004, 07:50 PM
grundseth grundseth is offline
Powcon 250 TIG troubleshooting
Greetings
I've been asked to troubleshoot a tig welder that's not working. Are there any manuals and parts available for a Powcon 250 anywhere? I believe its a bad water cooling switch (I found it and it doesn't work) but I jumpered it and there is no effect. The water cooling light still doesn't come on. Is it not a pressure switch ( Suco is the manufacturer)?
The welder's Power electronic are fine as the arc welder works. The foot pedal's potentiometers looks good. The wires to the unit and from the unit are good.
Thanks for the help
-Ernesto
Old 06-22-2004, 03:43 AM
vipermanz's Avatar
vipermanz vipermanz is offline
i'm not exactly sure were to track down a powcon manual, i would believe that parts like switches could be replaced with an aftermarket part though.
Stangnet
Shop Full Of Stuff.
Joey
Old 06-23-2004, 01:32 AM
revpol revpol is offline
grundseth: If you have power to the switch and you jumper it and it still makes no diff. then I would think the switch is probably ok. You should check further down the line and find out where your power is interupted or stopped. Unless no power goes thru the switch would I think that it's bad. revpol
Old 06-24-2004, 06:18 AM
david_r david_r is offline
Ernesto,
Contact Arc Products in San Diego for your manual and replacement parts.
Old 06-25-2004, 04:33 PM
Powcon Problem Found
Greetings,
I called Earl Beck which owns Kimby(sp?) who made the powcon 250 ac/dc. The tech there was very helpful. He figured out that is was a bad power line (the power&water line). It was a new line but the coolant is very old and probably lost its anti corrision properties. I had ohmed the line out but did not drain the coolant from the line. After I got the coolant out, the resistance went up to 25kohm.
-Ernesto
erg
Old 04-28-2007, 05:01 PM
slodat slodat is offline
Re: Powcon 250 TIG troubleshooting
What is the contact info for Earl Beck? I have the same problem with my Powcon 250 ac/dc TIG welder.
