Old 11-21-2007, 01:01 PM
umahunter's Avatar
umahunter umahunter is offline
splitting a water heater
i need to dye some grass for duck season and need something to do it besides a bucket i was thinking of cutting a old water heater outback in half anyone ever done this i know there's an inner tank just trying to figure best way to do it i don't think ill do the plasma cause the foam and if i can keep the foam that will keep the water hot longer when dieing offer up opinions if ya got em
350P 30A spool gun cut master 51 syncro 250 other stuff
" take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Old 11-21-2007, 01:44 PM
fordtrucks fordtrucks is offline
Re: splitting a water heater
I would use a Sawsall.
Old 11-21-2007, 01:47 PM
Hye Uma we need to hook up and smash some flyers together. Do you hunt the Colorado? I've hunted it at blyth before. Ive also been to the salton sea a couple of times.
Old 11-21-2007, 01:48 PM
MoonRise's Avatar
MoonRise MoonRise is offline
I'd skip cutting a water heater tank. Not only will you have the insulation jacket to deal with, but you'll also have the inner tank lining of glass or epoxy or plastic to deal with.
I'd say to just get a large metal can/tank/barrel and then use that. How about a plain old metal trash can? Galvanized metal, stick it on an outdoor cooker (turkey fryer, whatever) for heat, and go at it. Want insulation? Wrap some plain fiberglass insulation around it. Careful if you have the insulation and use a burner to heat the water, don't light the insulation on fire.
Old 11-21-2007, 02:14 PM
umahunter's Avatar
thanks for the advise bit im kinda already intent on the tank longer and shallow means less water and less dye to buy i plan on the sawzall ill post up how it goes either it will work or ill throw it out ford trucks sounds like a good idea if any birds ever show up i went out yesterday and it was coots galore
Old 11-21-2007, 03:13 PM
aczeller aczeller is offline
if you wanna try it, i bet a skill-saw would cut straighter than a sawzall... especially withmy sawzall abilities . a sawzall will probabyl be faster tho... got any kids? in order to get them outta the house tomorrow while you're watching the games and the misses is cooking, give 'em each 5 bucks and a hacksaw. hehehehehe. that should keep 'em busy for a while.
later,
Andy
Old 11-21-2007, 03:27 PM
umahunter's Avatar
later,
Andy
lol my kids have four legs and fur and there hacksaw abilities are marginal at best
Old 11-21-2007, 03:57 PM
Amen to that Umahunter. Amen to that!
Old 11-21-2007, 05:23 PM
jamlit's Avatar
jamlit jamlit is offline
I have cut a water tank apart before. It isn't much fun. The glass liner can be a pain in the butt. I would just think about going to wal-mart and pick up a cheap container the size you need.
Miller DVI2
Lincoln Precision Tig 225
Thermodynamics Cutmaster 38
Everything else needed.
