Old 11-21-2007, 01:26 PM
Trev-m Trev-m is offline
Tig Aluminum
I would like some help setting up my welder for Aluminum.
I have been welding 3/16 X 1" flat bar.
I can't seem to get any consistency. One pass works well and I can get a nice puddle and the filler rod melts in fine. The next pass everything bubbles or generally looks like crap.
I have a
Lincoln precision TIG 185
output at 175 on AC
Gas - pure argon
Pure tung electode 3/32"
Fequency on high
AC balance on auto
I use a stainless steel brush to clean the Aluminum.
Thanks for the help
Old 11-21-2007, 01:51 PM
turboblown's Avatar
turboblown turboblown is offline
Re: Tig Aluminum
If this is 6xxx alloy flatbar from Home Depot or such a store, I 've had this same problem. No matter what you do, there seems to be no consistency to the weld.
Old 11-21-2007, 02:23 PM
eburgblue's Avatar
eburgblue eburgblue is offline
Re: Tig Aluminum
Are you recleaning after each pass? I have had problems like that and found that I needed to clean every pass before attemting the next.
Old 11-21-2007, 02:29 PM
Re: Tig Aluminum
The Aluminum is 6061 -t6 from a metal supply store.
We clean everytime we weld.
