Old 11-23-2007, 02:57 AM
Roland Coppens Roland Coppens is offline
Newbie: I have the welder, now what?
Interested in getting into welding, but knowing absolutely nothing about welding, I purchased a used Lincoln Electric SP-125 plus MIG welder and accompanying cart recently.
I've read the manual a couple of times through and familiarized myself with the welder's anatomy (haven't plugged it in yet). I read Lincoln's How To Weld that's in the manual, as well as the MIG section of the Haynes Welding Manual.
In educating myself, I've purchased the necessary bits & pieces for the welder. Next on the list to buy is the gas and some metal stock to start practice welds with.
Once I've got my ducks in a row and ready to go, I'll actually plug the thing in and start with the practicing. So, as part of getting those ducks organized I've got a few questions:
- Is a set of coveralls sufficient upper body protection (it'll be Carhartts and steel toe boots down below & I've got a pair of leather welding gloves) or is a leather welding jacket required?
- The welder came with an older auto-darkening helmet. Seems in not too bad a shape, but would I better to just purchase a new one? Or does the auto-darkening mechanism not 'wear out' or work less well over time?
- To practice on, would purchasing some small-ish pieces of mild steel of 2 mm to 5 mm thickness, as well as some square tubing, angle, etc. be a good place to start?
- What sorts of clamping equipment should I be looking at getting? As a woodworker, I have a skabillion clamps, but I suspect only the C-clamps are going to be of any use here, right?
- I 'd like to learn more about the theory behind welding in general and MIG specifically, and more about basic welding skills. What books/manuals/DVDs/sites have you found educational and useful?
- I tried signing up for a MIG Fundamentals course at a local trade school but it's been cancelled the last couple of times due to insufficient enrollment. Is taking this course a must do before getting started, or would my time and $$ be better invested in self-teaching?
- Are there any other questions I'm not asking, so that I don't go ?
Any thoughts/advice/guidance is appreciated!
Old 11-23-2007, 11:17 AM
Tensaiteki's Avatar
Tensaiteki Tensaiteki is offline
Moderator
Re: Newbie: I have the welder, now what?
Required? No. Highly recommended? Yes. You want as many layers of non-flammable non-synthetic between you and the arc as you can get. Try to avoid things that have pockets or folds that spatter can settle in or on and burn.
It'll probably work well enough to learn on. The auto-darkening mechanism itself won't really wear out, but they can be broken if you drop them enough. If it has a battery, it can die and need to be recharged or replaced. Chances are yours is solar powered and will be powered/recharged by the arc or by being left out in the sun for a few hours every now and then. Just be sure to clean/replace the clear cover-lens on a regular basis. If it gets too dirty, you won't be able to see what you're doing and the arc sensor might not detect the arc and darken the lens.
Yes. Try to find a steel supplier or fabrication shop that has a scrap or "drop" bin that they will sell you some of. Much cheaper than buying new steel, and saves the trouble of dealing with huge sheet or long sticks of stock.
C-clamps will work, but keep in mind that spatter and gunk will get in the threads and chew them up. C-clamps made for welding have copper, or copper coated threads to keep spatter from sticking. Aside from that, vise-grips (locking pliers) are my favorite, you can never have enough of them.
Since you mentioned that you're a woodworker, make sure that you clean up all sawdust and wood shavings before welding. Welding throws around very hot sparks and spatter and wood shavings and dust burns very easily. It's also wise to hang around in the shop at least a half to full hour to make shure that there are no smoldering embers waiting in the corner to burn the place down. Keep a fire extinguisher handy.
This thread:( http://www.weldingweb.com/showthread.php?t=7453 ) links to a good book about GMAW (MIG).
Short of taking college-level welding theory, I would suggest reading up on at least basic electrical theory. MIG welding especially is strongly governed by the fundamentals of voltage, current, inductance, transformers, rectifiers, electro-motive forces, etc.
Basic metallurgy wouldn't hurt either.
I would keep trying to get in. If there's a problem with lack of interest, raise interest. Get friends interested in welding and get them to sign up with you.
I think that it would be an excellent idea to take the class as well as practice as much as you can on your own. In a class you will have guidance by someone with more experience and will be able to work with machines that won't make you worry about duty cycle or things like that. the cost of the wire and shielding gas that you can burn through in a class is almost always going to be much more than what you actually paid for the class. When I was in school the instructors told us that the money the got from our tuition barely paid for half of the consumables that we used everything else came from donations and state subsidies.
Tensaiteki
AAS Welding Technology - TSTC 2007
Visit Tensaiteki.com
Old 11-23-2007, 01:21 PM
Skwerly's Avatar
Skwerly Skwerly is offline
Nice response - hard to add to that, really. I guess just remember welding is a very FUN thing to do, and the safer you do it the more enjoyable it will become. . Welcome to the wild world of welding Roland!
Old 11-23-2007, 03:06 PM
Jee's Avatar
Jee Jee is offline
It's very difficult to add anything now after Tensaiketi posted that very comprehensive answer. Thanks Ten
I'll try though...
Depending on what you want to spend i suggest a leather apron over flame retardant overalls. Obviously a good pair of gauntlets too...
Sounds ok to me, especially to learn with. It should last for years if it's been looked after. You will need a stack of clear protective screens for it what with the spatter from the MIG. Might be a pain tracking them down? Or improvise. I couldn't find my screens so i cut it leaving enough for the solar panel, then slid a normal screen underneath over the bit i see out. Works great...
Again great move. What i did to start, and i'm sure most do is a pad. Basically a 7" by 7" flat plate of 5 > mm thickness. Basically you do beads from top to bottom until it looks right. A run on the top side then the bottom, then flip the pad over and repeat. Helps with distortion as the heat is added more evenly...
Pretty much, for now. There are a few clamps to learn with (Outside corner etc) I'd say a G clamp is fine for now...
Good man, learn as much as you can. This will get you started...
http://content.lincolnelectric.com/p...ture/c4200.pdf
If you like you could also email me with questions and what not? I'm working my way through my apprenticeship in the Ship building industry right now, I'd be happy to pass on what i get taught. Might make up for the issue with no training round your way? Kinda anyway...
It would be better if you can do a course, but many welders are very good and they taught themselves. I've seen tradesmen who are a bag of s***e while guy's who learned themselves bury them in rod ends!
Hmm, can't think right now.
Mind yer eyes...
Metaltrades.co.uk
Old 11-23-2007, 07:15 PM
Bobcatter's Avatar
Bobcatter Bobcatter is offline
Great answers! Have fun with it. The only things I can think to add are:
welding table
a chop saw
drill press
drill bits (many, many)
4" grinder
band saw
tubing bender
oxy- fuel heating torch for bending
engine cherry picker for lifting heavy metal projects
Ha, lol, you get the idea! You are just peaking into Pandoras box of welding addiction!!
Old 11-23-2007, 07:30 PM
papa65's Avatar
papa65 papa65 is offline
And the list goes on and on and on
If I'm teaching someone to weld, I'd rather
have someone who has never welded at all.
especially if their using a mig I still catch myself trying to lace a weld with a mig. Old habbits die hard
papa
the gorilla that made it hold
Ranger 8 15 yrs old
SP150 mig 25 yrs old
several Victor sets
Snap On 130 mig 25 yrs old
Lincoln 225 buzz box
SA200 F163 78 mdl
they all work
just added a Idealarc 250/250
Old 11-23-2007, 07:35 PM
MB2005's Avatar
MB2005 MB2005 is offline
Weld something
You only need to be 2% smarter than what you are working on.
Lincoln pm140
hacksaw
a big hammer
Old 11-23-2007, 10:01 PM
lewray's Avatar
lewray lewray is offline
Hey you found us
Yeah great answers above so get to it and show us what you got
Gmaw is a great process and some folks just dont give it enough credit
Just burn and go to town!
weld it like you own it
Old 11-24-2007, 07:22 PM
Thanks for all the great responses everyone, especially Tensaiketi - wow! that was great!
I've already got:
- a Makita 2414NB cut-off saw
- a benchtop drill press
- drill bits, but mostly for woodworking use
- a 5" angle grinder
- Delta 8" variable speed bench grinder
- a propane 'tiger torch' for pre-heating
- a small 115V plasma torch
I take it by band saw, Bobcatter meant a portable metal bandsaw, right? (If not, I of course have one for use with wood.)
I'm going to need to procure a welding table. I was thinking a bench grinder stand as a base and bolt a steel top on - would that work?
I hadn't considered these, so thanks for the suggestions:
- tubing bender
- oxy- fuel heating torch for bending
- engine cherry picker for lifting heavy metal projects
I'll be sure to post pics of my first welds to get some more advice!
Thanks everyone!
Before you criticize someone, walk a mile in their shoes. That way, when you criticize them, you're a mile away. And you have their shoes.
Roland
Old 11-24-2007, 09:57 PM
Diehard Diehard is offline
hey roland, a table is the first thing a new welder builds, just after his mig cart. ha ha
Old 11-25-2007, 06:17 PM
That last post twigged a few more questions I realized I should ask. But first, I forgot to add to the list of stuff I already have is the a cart that came with the welder, which looks to be shop-built and is fairly nice.
Now, the questions: First, what things would need to be looked to see if they need to be replaced? Gun cable liner, gas diffuser and gun tip seem like they'd be likely candidates. Anything else - anything in the wire feed drive mechanism, etc.?
Second, what kind of shielding gas and how large a bottle? Third, what kind & size of wire? Most of my welding at the start will be practice welding on the mild steel plate, tubing, angle, etc. After that it'll be all small project hobby stuff for the first little while. I'd mentioned in my OP. From what I've read so far, C-25 in a small bottle (unfamiliar with the terms, but the bottle I'm thinking of is ~3' high) seems reasonable - any thoughts on that? There seems to be a dizzying array of wire & I'm frankly not at the point I'd be able to match up the kind of wire to its intended purpose.
Fourth, what sort of regulator equipment is recommended?
Roland
Old 11-25-2007, 07:13 PM
Bobcatter's Avatar
One of the first things I found I needed was more tips for the gun. These go by the size of the wire you use. I ruined a few when I started, now I go a couple months before I have to replace one. Get a pack of 10 (or whatever, they are cheaper in the pack). Once I found out about "nozzle dip", it made things much easier. A one pound tub cost $4 and it will last me 10 years. Smear this on the tip and inside the nozzle of the gun and it keeps it clean. I have also heard of using it on the project to keep spatter off important parts.
Your local welding supply (LWS) will be a big help as to gases, tanks, regulators, and wire. Talk to them. You will have to have one to get gases, anyway. I went with a little larger bottle, since they don't cost much more to fill than the smallest ones. That way you don't have to get it refilled so often, maybe once every six months. Less likely to run out in the middle of the next project!
I was joking about the whole list of stuff, you don't have to get that till..... you really need it! A good metal bandsaw starts at close to $1000 (used), but there are much cheaper ones around, see other threads.
Sounds like you are on your way, just..... do it!
Old 11-25-2007, 07:22 PM
Bobcatter's Avatar
My welding table is a piece of 11 gauge steel about 24" by 38" with some angle iron welded on the back so it fits on top of my Craftsman heavy duty tool cart. I wheel it around in the garage. It is far from perfect but it works for me, no big heavy projects. I think the leftover piece of 11 gauge (about 1/8 inch thick) was 2' by 8' and cost something like $70 at the pipe and metal supply (and probably weighed 70 pounds). It is sturdy and hasn't bent on me. I cut it up with a sawzall and used it on several little projects.
