Cutting Aluminum w/ Plasma
I need to cut a 4x8 sheet of 1/8 aluminum diamond plate for a project I am building. I have a small plasma cutter and was wondering if I could do it without messing the finish up (it's the tread shiny bright) from the heat.. Anybody tried this before?
Re: Cutting Aluminum w/ Plasma
If you use a guide and cut from the polished side down, then it will be okay.
John - fabricator extraordinaire, car nut! - bleeding Miller blue! ![]() http://www.weldfabzone.com
Yes, it can be done, wih some practice. Good luck John G.
SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFC and Shielding Gases. There all here. ![]() : |
It will work great.
David
Deere2210,
Yes the aluminum can be cut with a plasma cutter. Keep the pattern side down as another poster recommended. Depending on your machine, remember that the aluminum "cut capacity" of your plasma cutter is about 30% less than it is for mild steel. Also, many have experienced problems tig welding a plasma cut aluminum edge. Seems that the cut edge may become somewhat contaminated from the use of compressed air in the cutting process. I would recommend some edge grinding if you plan to tig the material. 1/8" aluminum plate can also be easily cut with a circular (Skil) saw with a carbide blade. There are blades made specifically for cutting aluminum but I've found a 60 (or so) tooth 7 1/4 inch carbide blade works nearly as well. No additional prep is generally required for tig welding. Hope this helps.
Syncro 250 DX Dynasty 200 DX MM 251 w/30A SG XMT 304 w/714 Feeder & Optima Pulser HH187 Dialarc 250 AC/DC Hypertherm PM 1250 Smith, Harris, Victor O/A Smith and Thermco Gas Mixers Access to a full fab shop with CNC Plasma, Water Jet, etc. |
I think I'll give the plasma a try and see how it works.. I do plan to try and tig it after I cut it so I'll make sure I clean it real well first after cutting it and see how it works.. Thanks
A circular saw with the above recomended blade cuts aluminum almost as well as it cuts wood. I would not waste the time and power to plas if I had a saw.
SA200,Ranger8,Trailblazer251NT,MM250,Dayton225AC,T D-XL75,SpoolMate3545 SGA100C,HF-15-1 RFCS-14 When I stick it, it stays stuck! |
350P 30A spool gun cut master 51 syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Just watch the blade depth, if you see sparks that is your work table. Ha-ha. Sincerely, William McCormick |
