Chop saw
I don't have the money to buy a metal chop saw, but I do have a miter saw. I was wondering if anyone has tried to plug a miter saw in one of thoughs router speed controllers to slow down a miter saw to use to cut metal? Not sure if it would work. Anyone else think of this?
Re: Chop saw
I have always been told, use the right tool for the job and you will never regret it. John
SMAW,GMAW,FCAW,GTAW,SAW,PAC/PAW/OFC and Shielding Gases. There all here. ![]() : |
Re: Chop saw
i picked up a chop saw a home depot for 79 bucks. works like a champ
Re: Chop saw
Harbor Freight has their 2hp metal chop saws on sale right now for $49.00. I think sale ends 12/15/07. Haven't used it so can't tell you if it is worth $49.00 or not, but looking at it, I was impressed.
Qualified & experienced at welding scrap metal
Re: Chop saw
Hey!
It should work For the Speed BUT most metal cutting saws have Alot better clamping system (I Think) Thanks! |
Re: Chop saw
Re: Chop saw
You can go nuts on aluminum with a mitre saw and a blade for nonferrous metals. I use a Dewalt compound mitre every day at work to cut aluminum tubing. I've used it on stuff with 1/4" thick walls with no problem.
Miller Econotig Cutmaster 38 Yes ma'am, that IS a screwdriver in my pocket! |
Re: Chop saw
I have the HF $49 chop saw. It is well worth the price despite its flaws. It's cheaper than a metal cutting blade for your miter box.
Re: Chop saw
Antother problem with the speed control is that slower speed means lower power and with cutting the RPM's in half you will lose 1/2 to 5/8 oh your power. (3600 down to 1400) even if it was safe you could only cut thin stuff at best. Aluminum is a breeze on a chop sawe I use a timy spray of WD-40 on the cut because I had a little sticking to the blade but with the oil no trouble.
Steel Thunder Welding LLC. St. Thomas VI USAMM350P BOBCAT 3 MAXSTAR 150 STH 375 EXTREME PLASMA 6.5 HP COMPRESOR DEWALT 18, 24, AND 36 VOLT O/A TORCH SET AND SO MUCH MORE I DONT REMEMBER ALL IN MY 2005 2500HD EXTENDED CAB L/B |
Re: Chop saw
Hmmm... There are speed controls that can be used to slow down a miter saw?
This sounds interesting. I have a Makita 14" miter saw that spins too slow to use with an abrasive blade, but spins too fast to use a diamond or carbide blade to cut steel. It will cut aluminum and wood fine. I would like to use it to cut steel with a diamond or carbide blade, like a 'cold saw'. I would need about 1500 rpms. The saw spins at about 3200 rpms. Chop saws for abrasive blades spin closer to 4000 rpm. I can tell a big difference trying to use an abrasive blade at the slower rpm of the miter saw, it takes way too long to cut anything thick. I don't think it's because of a lack of power, I think it's just lack of speed. How can I get ahold of one of these speed controllers? Do they cause the motor to wear out quicker? This is a nice saw, I'd hate to kill it with one of my crazy experiments...
Re: Chop saw
#2.) they wouldn't make the saw wear out sooner, but the metal shavings probably wood. a miter saw, the type we are talking about here, are not meant to cut metal. period. they are not designed to have the same motor protection from metal shavings and dust that a true chop saw has. good theory to use one, but theory and reality are two different things in this scenario. if you really like that saw, don;t try to convert it. Later, Andy |
