Old 12-06-2007, 04:38 PM
cricman cricman is offline
Cutting open safe that may contain paper....
Hey ya'll,
I've got the opportunity to cut open a secure file cabinet here at work that is made with plate (the consensus is 1/4"). I have been told that there is "probably nothing in it, and if there is, it isn't anything that can't burn up with no cause for concern." We have several cabinets that are the same, and I have looked at how they are constructed, and have figured out a way to cut it open, remove the non-functioning lock work and drawer slides (the contracted locksmith has given up on the lock, after several attempts), and save the bulk of the cabinet to convert to a safe for my own use. I will be making a single cut (around four sides of the box) about 10 linear feet.
On the chance there is anything inside, I would like to save it. I am thinking of using my plasma cutter and purging the cabinet with a gas (argon or CO2) to mitigate the ability of any possible paper product from igniting and burning (There will be the possibility of some scorching of course.) Has anyone here ever used argon or CO2 like this. I know CO2 can be reactive, but makes a great fire suppressor. I have 2 full bottles, a local supplier that can do a fill in a few hours, and is pretty cheap, so I would like to use it. I know argon is also used in fire suppression systems, is inert, but I have 1 bottle, and it is a little cost prohibitive, if the job takes any long amount of time.
What say yee? CO2, Argon, or let it burn?
Thanks,
cricman
Old 12-06-2007, 04:51 PM
Re: Cutting open safe that may contain paper....
I was thinking more along the lines of a sawzall with a demoliton blade. NO sparks, no fire and it will cut through it relatively easy.
A larger angle grinder with a cut off disc will also do the job, relatively quick and with less slag/spark vs. a plasma.
A demolition saw (gas powered cut-off saw) will cut through it the easiest, a few sparks, so not much damage.
John
- bleeding Miller blue!
http://www.weldfabzone.com
Old 12-06-2007, 05:12 PM
denrep's Avatar
denrep denrep is offline
I would suggest to try to concentrate on the lock itself. That way maybe you can save the cabinet in nice condition. It may require something like carbide cutting.
Old 12-06-2007, 06:34 PM
maxyedor maxyedor is offline
I would use a big abrasive cut-off saw to cut most of the way through, then once the material is getting thin, finish the job with a saws-all, or since you have other similar cabinets around to look at, find out where the locking bar is, and drill through it with a hole-saw, once the bar keeping it closed is broken, you're in.
Old 12-06-2007, 07:13 PM
MoonRise's Avatar
MoonRise MoonRise is offline
Punch or drill the lock. Remove lock, manipulate lock bar, open drawer, done.
If you don't care if there's paper or other flammables inside or care about the condition of the contents after you work on the cabinet, just go to it.
Small cylinder lock or big dial combination lock? For the former, drill or punch or melt it out. Even if you can't oxy-acet CUT it out, you can still oxy-acet MELT it out.
Old 12-06-2007, 07:46 PM
TozziWelding's Avatar
TozziWelding TozziWelding is offline
I vote grinder, and razor wheel. Or drill the lock and use brute force and ignorance. Not that I know anything about opening a locked safe/cabinet
Old 12-06-2007, 08:08 PM
aczeller aczeller is offline
my vote is for some duct tape and C4... may not have a cabinet after you are done, but it sure looks pretty. hehehehhee. use a sawzall if possible... like it's already been said, no sparks=no fire. no grinding=minimal mess. if it comes down to it, run your grinding wheel so that the sparks shoot out, away from the cabinet... it will minimize the chance for fire inside. molten metal, especially large amounts usually lends itself to a flamable situation, so stay away from the plasma and the O/A torches. as far as the gas goes, don;t bother... IF this job takes you an hour, i'd be very surprised, especially with a grinder and/or saws-all. if you are really concerned about the contents, make as few cuts as possible. this reduces the chance of fire even more... less cutting=less heat=less fire. that would lead me to the option of, like it has also been afformentioned, drill/cut the lock, or the locking bar ONLY and try to play with it a bit... a 4 lb sledge may come in handy here.
Later,
Andy
Old 12-06-2007, 08:12 PM
Thanks for the replies ya'll,
I'm not so sure a hole saw or sawz-all will cut it; at least not the face. When the locksmith came out, he drilled it in a strategic location, in a attempt to line up the wheels. I wasn't there, but someone who was said that he went through 3 drill bits to get a hole in the face. I suspect the face is more than mild steel. It has a large piezo powered dial lock (I think its a Mosler) that is essentially busted off at the face, no thanks to an over-eager manager.
I don't have OA, but I do have a TD plasma cutter, and a 7" angle grinder. I thought of just slicing it open with the grinder, but I don't want to spend a lot of time on it. I just need to get it open, to either prove its empty, or to remove what's left inside. I don't want to spend any money on this project, because its for free (I'm hoping to get the remnants.)
It really (and practically for me) comes down to the plasma cutter, or a grinder with a cutoff disc. I'm not too concerned about saving it as a file cabinet. I'd just as soon gut the box, and weld on a face/door with a locking setup like a job box.
cricman
Old 12-06-2007, 08:16 PM
if that's your opinion on it (gut the box and keep the stuff), then QUICKLY do it with the plasma, or just do it with the grinder... i have found that i can cut a 55 gallon drum in half in about 5 minutes with a 4.5", 11,000 RPM angle grinder... i bet a 7" would go much faster... jsut think about it before you cut it... find the shortest possible path and have at it. don't think about the process too much, jsut use your gut and go for it.
Later,
Andy
Old 12-06-2007, 08:33 PM
65535 65535 is offline
See if you can punch the lock right out, a nice large hammer and a strong punch, a friend to hold rthe bunch or a jig, and smack the heck out of it, in the large off chance that doesn't work, I would recommend a hole saw with a cermic or something tough center bit, and just drill the entire lock assembly out.
Old 12-06-2007, 09:08 PM
txfireguy2003's Avatar
txfireguy2003 txfireguy2003 is offline
If you decide to cut the whole box apart, and you truly don't care about the contents....plasma all the way!!! I used a 4.5" angle grinder with cutoffs to cut the end off of a 150 gallon propane tank earlier this week. Made a really nice straight cut, but took about 2.5 hours to make roughly 5' of cut in 1/4" thick material. Wait, probably not that long, actual cutting time, probably less than 1 hour, I kept having to stop and let some of the water drain out so I didn't get soaked/electrified. So, on second thought, go at it with that 7" grinder!
Contact me for any metal polishing needs you may have, my avatar is a pic of a standard, painted fire axe that I ground, sanded polished and buffed to a mirror finish.
Old 12-06-2007, 09:12 PM
h2oboy h2oboy is offline
Been there, done that.
Fastest- Plasma Have a water hose near by, burn the rear or bottom.
Least chance of fire- Sawzall or hole saw
Funnest- Forklift or tall building, concrete floor
Old 12-06-2007, 09:52 PM
Rojodiablo's Avatar
Rojodiablo Rojodiablo is offline
I would try to arc gouge the lock assembly with the plasma. Very little chance of burn thru, and as you get through some of it, you can give the lock a shot or 3 with a hammer and punch. As you dig in deeper, you will probably soften up the case hardened parts with the plasma, and they will yield without too much drama. My vote??? Tell Mythbusters you simply CAN NOT flatten it with a full size steamroller at 30mph.
Old 12-06-2007, 10:18 PM
MoonRise's Avatar
Oh, it's a -real- security cabinet.
Plasma around the lock mechanism and remove the whole guts. The door will be kaputt, obviously.
If the locksmith couldn't get through with 3 bits, he :
- is clueless,
- grabbed some plain black oxide HSS bits instead of the cobalt bits.
- ran into a real security cabinet with strategicaly placed 'bit chewers' (hardened ball bearing balls, hardened tool steel or armor plate pieces, cross-wise hardened rods, etc, etc) in the way,
- more than one of the above.
The unit -may- have re-lockers that tripped already if the lock mechanism was 'forced' already. In which case you may have to plasma cut the entire door off.
Oh, and we want pics too. We -love- pics around here.
Old 12-06-2007, 10:20 PM
denrep's Avatar
I worked with a guy who's stories I really enjoyed. He confided quite a bit about safe work to me. You see, he was considered the black sheep of the family, for doing the work he had chosen, rather than carrying on the family's rich legacy of safe cracking! -Oh Henry, get off the phone- All these craftsman, were reformed and "retired" over 80 years ago.
Anyhow, I recall one of his hot tips was that the bottom is usually the "soft spot" of a safe. But also he told me about the job back in 1922 or so, when Uncle Joe was leading the assault on a big old safe. They were trying to tip a heavy box on it's side, to get at the "soft spot". They finally got it tipped over, but then, the heavy old safe, complete with Uncle Joe, and the help, went right down through a couple of the building's floors!
Back to the cricman cabinet. If you don't want to try finesse with the lock, I would say butcher the bottom to get in. Then you can hide a patch there easily, and still have a nice cabinet.
Old 12-06-2007, 10:52 PM
denrep's Avatar
I just remembered another one. - About the bidnessman who stored explosives in his safe!
Old 12-07-2007, 11:50 AM
Yeah,
I probably should have described it a little better. Imagine a premium gun safe with a $2 battleship grey finish and file cabinet drawers, instead of a door. I'm going to give it a closer look at lunch today. I want to tap the sides and top with a hammer to make sure it's not double-walled, with anything poured into the void, like concrete with carbide cubes or spheres. Again, if it is like the others, it has a hardened face, and mild steel plate sides, bottom and top. Punching the lock will probably not work. I'm sure it has at least 1 relocker, which was activated by the manager who erroneously thought he could get into it. I assume that's why the locksmith who has looked at it a few times has determined that it needed to be cut open. The initial thought was that they would pay him to open it, replace the lock, and weld it back together. I doubt they have seen his quote, but I'm guessing that they figured that they could open it to make absolutely sure it is empty, dump it, and buy a new one for close to the same.
With the help of your input, I think that I will first try to open the face around where the bolts engage the inside of the face with the plasma cutter. I should be able to get at and sever the bolts with the angle grinder. Of course, if that fails, I may tip it face up, and use the angle grinder like a can opener, and lop the top 3 inches off. That way the face, lock works, bolts and drawers pull out as one piece.
If I get the opportunity to do this, I will absolutely take pictures and keep ya'll posted on this thread. Of course, it could be a month before they let me know what they plan on doing.
Thanks again for the input,
cricman
Old 12-07-2007, 11:59 AM
good god man... what in the @#$% do you guys have in those things? what kind of documents require that kind of protection? hehehehe. oare you able to tell us without killing us after? if it's as big and bad as you describe (I don't doubt it), it'd probably be easier to start with a torch... try to get the cuts started in a known safe-spot... see what happens. if it can work, use the torch... if not, i still think the C4 and duct tape may be a little light for the job... take it one step at a time... get it home and try prying on stuff first.. see if a 2' crow bar and a 4' cheater pipe would do the trick... pound it into a crack with a sledge and try to bust it out with some sheer brute force... i prefer the idea of jsut dropping off the building's roof... it might crack the pavement tho.
Later,
Andy
Old 12-07-2007, 12:37 PM
AnotherDano AnotherDano is offline
Cricman,
Can you get some pictures of the similar units to help us see what you're up against?
Old 12-07-2007, 02:51 PM
deadman1474 deadman1474 is offline
cricman
I had to get a couple of these open. I just used bruit force and ignorence on the lock. It got them open quick and was kind of stess releaving
Old 12-07-2007, 04:03 PM
Originally Posted by 69 chevy
The basic question remains unanswered: will CO2 support the plasma and knock down any flames inside the safe caused by the sparks?
Probably not... think about how a plasma cutter works... the arc liquifies the base metal, and compressed air sprays it out the back of the panel. unless the compressor is running CO2 also, or there is enough CO2 inside the chamber (and the original oxygen has been removed from the cahmber via purging), there is still a change for combustion. there is a slightly REDUCED chance of this happening due to a given amount of CO2 being introduced into the safe, but it is still a possibility, espceailly with the high velocity of air rushing thru that nozzle. not to mention, the air will be directly in line with the sparks/molten steel.
just my two cents.
Later,
Andy
Old 12-07-2007, 04:39 PM
I opened a fire safe up once with a fire axe and halligan tool, you could try that. I wouldn't recommend it if you are planning on reusing the box afterwards....there wasn't much left when I got done with it, but the homeowner was able to recover her insurance papers in order to file a claim after her house burned!
Old 12-07-2007, 05:19 PM
Burnit's Avatar
Burnit Burnit is offline
Lets say we knew for sure that you could purge the inside of this thing and make it inert. Are there already holes to get the gas is/out? Is your plasma cutter going to be able to cut this thing?
How is it built? Is it made from sheet? Can you see any obvious seams/welds that you could grind out?
Old 12-07-2007, 10:27 PM
Hey Ya'll,
I had a chance to get a closer look at the safe after lunch. quarter inch plate all around, including the drawer fronts, which again, I am certain are harder than the sides, top, and bottom. Hammers or pry bars are out of the question. I'm a big feller (6'1" x 260lbs) and fitness is requirement for my job. There is no way in Hecuba that I would waste my time with a hammer of any size on this critter, since I am trying to save the bulk of it for myself. There are no seams (whoever constructed this thing did a great job.) and the drawers fit very closely. I would estimate a volume of about 9 cubic feet and an estimated empty weight of 450 pounds.
As for punching the lock; It is a Hamilton X-07, and punching what was left behind by the locksmith (only the dial shaft- bent at a 60 degree angle protruding through a quarter inch hole) will probably net zero gain.
As for purging (If I use plasma); There are three holes, including a quarter inch hole, on the face of the upper drawer. My thought was to tip her up, drawers up (easy fellers!), and purge it with CO2. Since CO2 is denser than air, it would settle at the bottom, with anything else that might be combustable. I would run a tube close to the bottom, and after filling it (tested by sealing all but one exit hole, and holding a flame near that sole exit to watch the bevaior of that flame) maintain a flow of about 2-3 cfm.
As for what this thing is designed to secure; Let's just say letter sized documents that need to be safe from prying eyes, and leave it at that.
And for those that want to blow it up; I would too, cuz I love me some explosions and pyrotechnics. But, I need more safe storage for myself, so this is a chance to get 5/6th of a nice safe for a little sweat and a smattering (okay, a grain silo full) of profanity . All I need to do is add a face and door (internal hinges of course.)
I'll try to find something online that looks like what I'm dealing with.
cricman
Old 12-08-2007, 10:15 AM
Engloid's Avatar
Engloid Engloid is offline
If you want to use a plasma, just hold it at an angle and blow the corner edges off the top of the box, blowing all the sparks outside, rather than inside.
HTML code is On
