Old 12-27-2007, 09:47 PM
zapster's Avatar
zapster zapster is offline
Moderator
HI Speed Tool Steel To Mild Steel..
Had to make a plunge tool for the face of a big 'ol piece of steel in the lathe..
Here is the pieces..
Simple enough..
Grind before welding then clamp and weld..
(Yeah I fixed the vice)
Name:  Clamp and Weld 2.jpg
Top of the bit..
Name:  Top weld 3.jpg
Little stitch on the bottom..
Name:  Bottom stitch 4.jpg
The hook for digging on the end..
Name:  The Hook 5.jpg
More on why next..
...zap!
I am not completely insane..
Some parts are missing
Old 12-27-2007, 09:55 PM
zapster's Avatar
Moderator
Re: HI Speed Tool Steel To Mild Steel..
Gotta turn out major metal in this just for lightening only..
Leave a 2.5 Dia center and then drill and tap 1-8" 2" deep after..
Gouging near the center hub..
Name:  Plunge turning 1.jpg
Looking for a groove like this..
For a regular carbide insert tool to do it's damage..
Name:  Boring bar 3.jpg
Turn to the outside edge while taking off 1/4" at a time..
Name:  Boring bar 4.jpg
Next!..
...zap!
Old 12-27-2007, 09:58 PM
zapster's Avatar
Moderator
Even with a small gouge tool...
If you try to take too much off at one time?
This happens.....X3
Did'nt break off at the thin part..
Broke at the body..
Go figure..
Oh yeah..
120 amps give or take..
3/32" Red.
.045 70S-2
I get all the repetitave jobs..
...zap!
Old 12-27-2007, 10:21 PM
Brainfarth's Avatar
Brainfarth Brainfarth is offline
What did you use as filler? Do you ever have problems with it cracking out on the HAZ when using er-70s?
Common sense in an uncommon degree is what the world calls wisdom.
Old 12-27-2007, 10:29 PM
zapster's Avatar
Moderator
.045 70S-2 and No..
Not yet anyway..
Let air cool..NO WATER!!!
...zap!
Old 12-27-2007, 10:52 PM
tanglediver's Avatar
tanglediver tanglediver is online now
So you're saying the plunge tool was the HS tool steel, and the big ole piece is mild steel?
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 12-27-2007, 10:58 PM
zapster's Avatar
Moderator
Yup..
...zap!
Old 12-28-2007, 12:38 AM
Scrapmetal's Avatar
Scrapmetal Scrapmetal is offline
Your beads look really nice. I probably should have made my screen name booger welds. On the stitch do you use short "U" type movements to get it to look like that?
______________
Clarke 95
Lincoln 135
Lincoln AC 225
I'm an idiot, please talk slowing and simple.
Old 12-28-2007, 07:48 AM
zapster's Avatar
Moderator
Not really..
Its just back and fourth over a root pass while adding filler on the edges..
...zap!
Old 12-28-2007, 06:12 PM
welderman1 welderman1 is offline
Did you pre-heat the high speed? It probably busted because welding made it brittle. Unless you pre and post heat. I would have silver soldered it. Most if not all cutters are silver soldered.
