Harbor Freight Bandsaw
http://www.harborfreight.com/cpi/cta...emnumber=37151
I just got this Bandsaw from HarborFreight. It seems to work good, but I have a few questions.. The blade seems to jump off the wheels if I apply just a little bit downward presure. I can cut things, but i really have to be very careful to only apply very light presure on the blade otherwise it jumps off the wheels. I've tried adjusting the tracking, the guide wheels, and everythign else that is adjustable. I find if I tighten the tension wheel as tight as it goes, it helps prevent the blade from jumping off the wheels, but it still seems like you should be able to apply more presure to the blade without worrying about it jumping off the wheels... Does anyone else have this bandsaw, and if so, do you also have this same problem? Thanks! |
The beauty of the horizontal bandsaw is that you don't need to apply pressure - you start the cut and walk away to do something else.
If you want speed and mess, use a chop saw. |
The tension spring on my horizontal bandsaw doesn't let the blade cut all the way through even on the lowest tension setting. Maybe I need to expand my spring a little bit , or loosen up the hinging mechanism. |
check the tension on the blade, sounds to me like it is to loose.
Ken |
There's a Yahoo group for that bandsaw that has a bunch of tips & tricks for getting it working well:
http://groups.yahoo.com/group/4x6bandsaw/ |
if the blade is jumping off with a new saw then take it back and trade for another saw. it only gets worse; these are throw away saws and the warrenty isn't much so do your self a favor and get one that works right to begin with.
I agree, take it back and get another one.
Then, buy yourself a decent blade- a bimetal 10-14 variable pitch from either Starrett or Lenox. These will cost you a lot- 22 bucks or so each, from MSC, but they are really worth it, and they will last a very long time if you dont drop the saw on a piece of metal, but lower it slowly. Then go to this website, and do everything it says; www.tinyisland.com/4x6bsFAQ.html These little saws can be made to work pretty well- but they are still a consumable item- I have worn out three, but we work the hell out of them, mostly on stainless, with a lot of freehand cutting to boot. The Jet seems to be the best, but at $275, its a hundred bucks more. The swivel head Grizzlys are even more, but I have heard good things about them. Jet and Grizzly actually have parts, and spec better stuff to begin with, whearas with hf, its usually exchange, or fuggetaboutit. |
I purchased the same saw 6 months ago and have cut a lot of metal with it. I just recently released all the pressure from the spring so it would shut off when done cutting.
The only problem I have had is the blades from Harbor Freight break a little to often. I purchased one with more teech (I think 24 per inch) and it works awesome. I would exchange it for another. I have had a few defective things from Harbor Freight brand new. Honestly, I would would not buy anything electric anymore unless you are desperate, Central Machinery products are not that great. I purchased two drill presses from them (different models 5 months apart) and both of the chucks wobbled and could not drill anything correct so I returned them. |
hello, i got a question about this same saw. i went and checked it out today at my local HF but i forgot to see if it miters?
its probably the perfect size that im looking for and the price isnt bad either. i'll proabably mod the heck out of it though like others have. TIA. CB |
The set screw on the front is wandering behind the top blade wheel. There is a small divet that the set screw sits in. If it is loose and not sitting in the right position the blade will jump every time.
Neil |
well i bought this saw this week and returned it today. whenever i put the vise in the 45 position it wouldnt be a true 45, it would be up to 3/16 off. i guess i'll research jet or grizzlly bandsaws.
The question of it mitering, you mean cut angles???
YEs they will cut angles
IF it Catches...Let it Burn
If you open the back cover where the saw blade is the top wheel will be about face hieght. This is the top wheel for the band to sit on. If you remove the philips screw that holds the wheel on there will be a spacer behind the wheel. Remove the space and you will see a small rectangle block. Unscrew the block from the front and you will see the indentation that the screw is wandering out of.
Neil Quote:
Thanks, Neil! I'll check it out.
If you see scratches on the block then it is wandering. I drilled the divet 1/4" in on the drill press so that the block couldn't wander.
Neil |
I just picked one of these saws up today.
I LOVE it! Granted its my first metal cutting bandsaw, but man o'man I'm really digging the fact that it cuts so neat and quite. Cut off saw just went into semi retirement... Did I mention its quite?
#19
I bought a "magnetic ground" from H F . about4" diameter . drilled a hole in a piece of aluminum 3/8 X 4" X12" ; put the plate on the magnet & presto ! a great little straight edge for oxy-acet burning (for short cuts . ) i have long straight edge (store bought ,) but i don't like them all that much ,especially for short cuts . I like the fact that the grounding magnet is
so powerful . - it don't accidentally slip & slide . P S : the grounding magets hold a calender on yer refridgerator real well, also |
#20
"Lack of planning on your part does not constitute an emergency on mine"
However "lack of planning on my part may constitute an emergency on yours" |
#21
#22
I bought one of these saws at a flea market for practically nothing. The saw works fine for light work but the sheet metal base is crap. I welded up another base out of 1" square tubing and replaced the cheap plastic rollers with 10" solid tires. It's still light enough to carry around to outside jobs.
#23
Re: Harbor Freight Bandsaw
I have the same saw and I was just complaining about that cheesy sheet metal base myself, gonna have to build a new base for mine.
#24
I have the a harbor frieght bandsaw. I bought it off a guy that couldn't get it to cut with out breaking blades he only used 4 times. I gave him the$ 50 load it in my truck before I told him he had the teeth running the wrong way. took it home played with the spring tension. changed the belt to the corect speed for what he and I both cut. While it's not super fast it cuts nicely with booth the 14 and 24 teeth blades. I find a little wd-40 on the blade seems to help. I have made alot of cuts that would be pushing the max limits with it with no real issues. Maybe i got lucky and got the one that wasn't put together right. Oh did I forget to mention the guy I bought it from is a buddy of mine.
#25
Fellas, they have the similar saw at NorthernTool for $159 right now...so you save 40 or 50 dollars. FYI...I posted in another section earlier in the week as well.
John - fabricator extraordinaire, car nut! - bleeding Miller blue! ![]() http://www.weldfabzone.com
