More Boring Welding..
This time it's Aluminum!!
Roller in the positioner.. This is where the bearing was spinning and banging everything out of shape.. And it's pretty dirty too.. What do we do with dirty Aluminum? Acetone and a stainless brush.. All clean now.. And all welded back up.. 180 amps.. Gas mix.. 3/32" Red End.. 1/16"4043 filler.. 45 mins.. It will be machined tomorrow.. Got lots of welding to do today.. I get all the fun jobs.. ...zap!
Re: More Boring Welding..
You're not kidding about the fun jobs.. that looked like a royal pain in the ***. How long did that take? Looks great!!
very nice!
Nice job. I like your end roller device, I'm going to have to remember that one. Is 3/32" filler to big to use? It would seem you would have to really shove that 1/16" in at high rate to get that much build up. You seem like you get quite a bit of those shaft jobs. What kind of uses are they for?
Why did you pick a weave over running stringers?
--Gol'
Welds look great. I envy your skill.
______________ Clarke 95 Lincoln 135 Lincoln AC 225 --------- I'm an idiot, please talk slowing and simple.
3/32 would work but its better to use small wire to get into "tight" places along with the torch and your hand in there at the same time.. These are usually rubber covered after and then used in material handling.. ...zap!
It is a stringer! Its just not straight... Honestly? Because you can cover twice the area in the same time it takes to run 1 stringer pass.. Me fast.. ...zap!
s##t zap you nailed that one, beautiful beads
Boring? Your aluminum welding is never boring Zap - just your humour
Fire!, Fire! Oh wait, that's my torch... Lincoln PT-225 TIG Lincoln 175 MIG |
Looks awesome as usual.
David
sad thing is itll all be gone tommorrow and nobody will ever know how pretty it was
Complete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work. |
