Cutting Speed/Feed Speed
There needs to be a machining area here at the forum.
Anyways i have a question about Cutting Speed. How do i figure out the Cutting speed and feed speed for lathe and milling? I found a few things. Steel 50-60 Ft/min Mild Steel 100-125 Ft/Min I don't know what they mean by Steel ? Cold rolled? Hot Rolled? Formula Cutting speed = k x speed / Diameter What is k? |
Re: Cutting Speed/Feed Speed
K is for picking how your measuring everything
K=320 for metric K=4 for 'merican (inches) that way when you plug all the numbers in you get a value that you can use |
What are you cutting? Are your cutting tools HSS or carbide? that makes a big difference
I know on the lathes , we just use hardened steel cutters. I will find out on the mills. |
Oh , alright then i would use 4.
Standard Sizes
Surface Feet per Minute = RPM x .262 x Tool Diameter RPM = Surface Feet Per Minute x 3.82 / Tool Diameter example CS is the cutting speed of the material, a property that you can find in reference books. It is measured in surface feet per minute (sfpm). Our shop uses the following values: 500 plastic 300 aluminum 200 brass 100 mild steel 50 stainless steel D is the diameter of the tool in inches. Example: If you were using a 3/8”-diameter endmill on mild steel, you would perform the following calculation Speed = (100sfpm)*4/(.375") = 1067RPM Feed Rate (in/min.) = RPM x Chip Load per Tooth x No. of Flutes Feed is the calculated feed rate in inches per minute (ipm). ChipLoad is the amount of material that each flute will remove on each revolution. Each material/operation has a suggested value, which you can find in reference books. It is measured in inches, sometimes written inches per tooth (ipt). Our shop uses the following typical values: 0.005” for roughing 0.001” to 0.002” for finishing n is the number of flutes on the tool. Speed is the spindle speed in revolutions per minute (rpm). Example: If you were doing a roughing pass with a four-fluted endmill turning at 1000 rpm, you would perform the following calculation Feed = .005" * 4 * 1000rpm = 20ipm Chip Load Per Tooth = in./min. / RPM x Number of Flutes in 3 /min = Width x Depth x Inches per Minute Required Horsepower = in.3/min. / Powerfactor Horsepower = 1.341 x kW Metric Surface Meters per Minute = RPM x .00314 x Tool Diameter RPM = Surface Meters Per Minute x 318.057 / Tool Diameter Feed Rate (mm/min.) = RPM x mm per Tooth x No. of Teeth Chip Load Per Tooth = mm/min. / RPM x Number of Teeth
"Retreat hell, were just fighting in the other direction" Miller Trailblazer 302, Extreme 12 VS, Dimension 400, Spectrum 375, HF 251D-1, Milermatic 251 w/ spoolgun Hypertherm 1000 Lincoln sp 170 2000 F-450 to haul it |
There is a major diffrence in Carbide vs. Hi Speed..
Most times you just go untill the chips turn blue and then "back off" a bit.. But sometimes vibration will set in.. You need to figure out how fast per diameter vs. feed speed.. Small 2" diameter stuff you can "Buzz Away" in no time... 16" diameter goes way slower... All a learning curve.. Carbide tools do not like interupted cuts.. ![]() Snap Break Shatter every time... But Carbides will put up with heavy loads if under constant load.. Hi Speed on the other hand will put up with interupted cuts to a certian extent.. But under a heavy load.. Melt usually happens and the melted tool gets in your piece...No good.. How you grind your tools makes a big diffrence also but that can get too involved here now... Trial and error.. Go by that.. I have been grinding my own bits for 30 yrs.. All seat time.. Just like anything else you want to be good at.. ![]() ...zap!
Its 4-5" Dia with 6 cutters. If i calculate it , it turns out to like 100 RPM which i find is super slow. |
Think about the surface speed of that tool though. How fast the edge is moving. Does that make sense?
like if you swing something on a string, your hand isnt moving that quick but whatever is tied to the end is really movin |
[QUOTE=Bikespot;168031]There needs to be a machining area here at the forum.
Anyways i have a question about Cutting Speed. How do i figure out the Cutting speed and feed speed for lathe and milling? I found a few things. Steel 50-60 Ft/min Mild Steel 100-125 Ft/Min see attachments lathe: mill: |
I did some milling today
Face mill 4-5 Dia At about 300-400 RPM , works good. 1/2" End Mill I tried at around 800 and 600-700 RPM , i had to be in high speed for 800 , low speed for 600 RPM. I found that at 600-700 RPM it cut better. I think it could be the machine also , because it seemed like it didn't have enough power to cut when it was in high speed. |
Start slow and work your way up, don't go any faster than you have to, in order to make deadlines and time costs. Breaking tools is much more expensive than the time you save.
