Old 03-22-2008, 04:14 PM
zemzero zemzero is offline
Tillman High Heat Aluminzed Gloves, worth it?
High Heat : :
820BHP
14" AR back with aluminized Kevlar and Weldflex snap on ACK back-hand pad. Also available in left-hand only (820BHPL), replacement ACK backhand pad (820-558)
I need new gloves, due to carelessness. I have two holes in the right hand glove. I can see almost all of my index fingernail, and the side of the first knuckle. Right now I have pieces of a sock stuffed in it, with duck tape inside and outside...yeah. I changed the way I hold the stinger, and it seems to help but I'm still not comfortable with two huge holes in the glove. Plus spatter sometimes seems to shoot through the glove and gets embedded in my skin.
Looking around the internet, I found those aluminized Tillman gloves. Are they worth the 35$? I almost bought them, but something made me think it wasn't worth it.
Old 03-22-2008, 07:02 PM
Doug247's Avatar
Doug247 Doug247 is online now
Re: Tillman High Heat Aluminzed Gloves, worth it?
cool gloves! never seen them before. Its usually cheaper to buy4 pairs of ten dollar gloves then to buy one expencive pair, cause gloves wear out, they just do, no matter how much you pay. ive used the aluminised glove covers before but they wear out too. helped the glove from shriveling up though.
Nothing Ever Got Done By Quitting, Never Give Up.
Old 03-22-2008, 07:14 PM
tresi's Avatar
tresi tresi is offline
It depends on what you're doing. If you never go over 200-250 amps they're overkill. High amp spray mig or something like that it they will help.
Old 03-22-2008, 10:36 PM
I'm using Stick right now, never usually go above 170. I was wondering how fast those gloves would wear out, too. I'll probably just get a cheaper pair then, thanks.
Old 03-22-2008, 10:50 PM
tanglediver's Avatar
tanglediver tanglediver is offline
I have those gloves. For what you do, they are overkill. The heat resistance is better, but at the cost of freedom of movement.
They are meant for heavy wire fed work, such as innershield and dualshield fluxcore welding, or spray transfer mig, as was mentioned.
Job 28:1,2
Lincoln, Miller, Victor & NKJV Bible
Danny
Old 03-22-2008, 10:52 PM
WANNAWELD's Avatar
WANNAWELD WANNAWELD is offline
35 dollars isnt that bad if they last a long time
Old 03-22-2008, 11:00 PM
Mandau's Avatar
Mandau Mandau is offline
I'll prefer the norm... not flexible due to the extra protection... all glove is almost the same... unless you use it in a clean environment in your own shed... In a remote or open big workshop... it will wear soon enough...
Unit in my fab shop dept:
my good hand and team that trust me...
A lone welder make art... a village full of welder make Miracles...
Old 03-23-2008, 11:03 AM
Oldtimer Oldtimer is offline
They look very uncomfortable to me. I never buy cowhide gloves because they become hard in just a few days. I settled on Kunz, Black Stallion, or Tillman elk skin years ago.They are expensive but cheaper in the long run because they last so long. You can also rejuvinate them with WD-40 when they get stiff from heat and it doesn't work with cowhide gloves.
Old 03-24-2008, 12:37 PM
weldbead weldbead is offline
i have a pair of cowhide, hold the stinger in my right hand-left hand is completely shriveled from going over justwelded spots, right is almost new.
Old 03-24-2008, 08:39 PM
welder155's Avatar
welder155 welder155 is offline
remember those are for reflectin the heat and light..they burn and melt if you rest them on the material. i do lots of spray but i just have to backhand pads on my stick gloves
6G zirconium 702 GTAW 2" xxheavy
6G P.E.D. carbon steel GTAW 2" xxheavy
3G titanium Gr. 2 - Gr. 7 GTAW up to 3/4"
3G 316L stainless GTAW up to 1"
3G carbon steel GTAW up to 1"
3G Hastalloy GTAW up to 3/4"
1G tantalum GTAW up to .060"
Old 03-24-2008, 09:18 PM
chopper5 chopper5 is offline
me to but i dont do lots of spray transfer any more
the only gloves i were now raemechanix wear padded plam
Chuck
ASME Pressure Vessel welder
