Old 01-19-2004, 06:25 PM
Canadian_welder
Guest
Posts: n/a
Chopper Frame & Jig Plans
I have for sale a full set of drawings on how to build a Harley Davidson based Custom Rigid Frame Chopper and include plans on modern wide tire designs like the 280 and the monster Avon 300. The mounting points for a Softail swing arm are included should you choose that your back needs a break, as well as mounting positions for motor and tranny mounts.
Also Included, is a detailed print on how to build the very necessary FRAME BUILDING JIG. A Jig is a must when building a custom bike, to be sure the frame is symmetrical, as well as to assure that your angles are correct.
ALL the dimensions you will need to build your custom motorcycle frame and jigs are on the drawings and are clear and precise. If you are considering building your own custom chopper this prints are a must have. If you are considering building a radical custom then this is a great start point as the rake and stretch can be changed quite easily.
I am selling the set of 7 plans for $65 shipping included. Email me with any questions. Thanks!!
I did a page on my website for a bit more info on the plans.
www.butchswelding.com/frames.html
Mitch
canadian_welder@yahoo.ca
