Old 03-26-2008, 06:46 AM
ere1983 ere1983 is offline
second pass welding
hey guys, i have a 110V lincoln electric weld pak 3200HD mig/flux cored welder. I was reading the manual and it said it can do up to 5/16" steel but multiple passes will be needed. Can somebody explain to me how to know when you need to do multiple passes. Is there an special way to do this or do you simply go back over you original weld a second time?
Old 03-26-2008, 06:59 AM
MAC702's Avatar
MAC702 MAC702 is offline
Re: second pass welding
May I ask what you are building?
Multiple pass welding starts before you run the first bead. You have to prepare the joint with a suitable bevel for the application.
You must use a self-shielded FCAW wire that is rated for multipass welding to even HOPE to meet the manual's highly exaggerated claims.
You must clean the first pass of all slag and may even need to grind some out before you can run the next pass.
Old 03-26-2008, 07:42 AM
arcflashlynn's Avatar
arcflashlynn arcflashlynn is offline
It is needed for the thicker materials. Depends on what you are building also. The ends need to be beveled (single or double depending on where and what it is for) then you put the root pass in clean it and follow a pattern of passes so the heat is displaced throughout the peice evenly... cleaning each pass so you dont get inclusions etc. if it mentions multiple pass welding the typically it will show you a pic of what one should look like/ and how to do it.
Certified Welding Inspector at your service...
Level II Nuclear Welding Inspector
Level II Nuclear Electrical Inspector
Level II Nuclear Civil Inspector
Level II Ultrasonic Thickness Testing Technician
Certified Smartass,and Wise Acre
Old 03-27-2008, 02:22 PM
worldsgreatestwelder worldsgreatestwelder is offline
Well not so true on the requirement of beveling.
I would suggest you find your way to a book store or library and do some reading on welding.
welding starts before you run the first bead not judt multi pass but all welding should start this way have a plan don't just pull the trigger and hope it works out.
Operators manuals are guides for using the machine not to be substituted for welding education.
Learning to weld via the internet forums is ill advised.
Good luck
Jimmy
welding starts before you run the first bead not just multi pass but all welding should start this way have a plan don't just pull the trigger and hope it works out.
Good luck
Jimmy
Old 03-27-2008, 02:57 PM
ironken's Avatar
ironken ironken is offline
Good luck
Jimmy
ahhh come on Jimmy, be easy on arcflash. She has umpteen degrees and, "knows what she's talking about." Not bad for 22 years old........
Yeah, yeah, I know you are a weldor too. But, are you a good one?
Old 03-27-2008, 03:26 PM
OOPS. Just an uneducated welder with 30+ on the job.
Old 03-27-2008, 05:27 PM
qaqc qaqc is offline
for standard structural steel welding, the max size for a single pass weld are 1/2" for flat, 3/8" for horiz., 1/2" for vert, and 5/15" for overhead. Although your machine will difficulty with these sizes.
Old 03-27-2008, 08:21 PM
Where did you get these numbers?
Old 03-27-2008, 08:30 PM
30 years on the job doesn't mean you're the greatest welder, despite your alias... but at least you can admit that you are UNEDUCATED.
Please, buddy you cannot scrutinize people for using the word need... it wasn't the word SHALL, perhaps you should get educated then post. perhaps after 30 years you should retire
Old 03-27-2008, 08:42 PM
kc8yhk kc8yhk is offline
WOW what a complete @ss worldsgreatestwelder is
Old 03-27-2008, 09:03 PM
now there's a guy who knows what he's talking about. haha
Old 03-27-2008, 11:55 PM
smithboy smithboy is offline
http://www.esabna.com/EUWeb/SA_handbook/585sa4_45.htm
ere1983,
Here is the basics of multipass welding for thicker materials...well, maybe a bit more than basics, but it gives you some idea what it is, even though yours isn't this thick. You don't always simply go over the weld. There is sometimes a stacking pattern involved, and it and other details differ somewhat depending on the required joint. The first link is for submerged welding...obviously not what you are doing, but it was the best picture I could find to give you a bit of an idea. I have accomplished 1/4" welds on mild steel using a 110v welder (MM130), but it was a real stretch for the machine...or me, maybe. Preheating the joint helps. Using higher amp welder would make this a lot simpler process. Getting by with a lower amp welder requires a bit more finesse. I think the reason folks are asking about what you're welding is because they want to make sure you aren't doing anything that might be a critical weld...The manufacturer's claims are probably based on optimal conditions, which might include a bunch of experience practicing that specific weld. It probably wouldn't hurt to practice with some scrap just to get an idea what you might be up against.
Smithboy...
Old 03-28-2008, 12:38 AM
6010's Avatar
6010 6010 is offline
Question for Miss Arcflashlynn
Lynn,
I know whose brain I am going to be trying to pick now.
I have a question for you. When I worked at a paper mill we had pipe that had to be stress relieved and they used a machine with thermal blankets to do this. I was wondering if you could tell me how high the temperature had be and how long at temperature before they started dropping. I saw this done many times but never ask about the temperature. It wasn't until I retired from the paper mill that I took a keen interest in welding.
The pipe was on our digesters - 10 and 12 inch pipe carrying white liquor at 340 degree F at a PH of about 14. You can see why they thought it was so important that they get a good weld. I was wondering if you could go over this process with me. I didn't get into the welding too much because I was in Electronics/Instrumentation, although I had some welders that worked for me.
They didn't do the welding on these pipes though. There were only a couple on site that we trusted enough to do this job.
Thanks
Hope I am not hijacking the thread here.
Old 03-28-2008, 07:58 AM
so you dont hijack the thread i'll answer in a private message
Old 03-28-2008, 12:54 PM
AWS D1.1 the max size single pass that are prequalified for GMAW and FCAW
Old 03-28-2008, 01:57 PM
ironken's Avatar
Do you know how silly you look? You are 22 with all of this experience and a buttload of degrees.......It doesn't add up. You come bustin on here like a hot rod welder....but, again the math don't lie. You have a good vocabulary, but little time in the field........chill out there hot shot. On the degree thing.....people with experience speak of their years in the craft....people with no experience speak of their education....think about it.
Old 03-28-2008, 04:26 PM
If you had bothered to read my introduction post you would see the monicker (pardon the slang) came from my grandson. Retire at my age I still need to educate young punks like you on what welding is all about.
At 22 I had 8 years welding in. Welding full time in the summers and part time in the school year.
In your 22 years you have spent 17 getting educated, what time have you had to get real world experience? How much time under the hood do you have?
I acquired my CWI in 1992.
Now lets look at what all this education has done for you: grammar is a challenge, as is punctuation and spelling.
So all multi-pass welds require a bevel? Now we both know this is not true.
[COLOR="Red"] peice [/COLOR Spell checkers are free.
]evenly... cleaning each pass so you
dont Spell checkers are free.
get inclusions etc.
Nice grammar but then you worked more on welding then English, maybe English is not your first language.
All I wanted to point out to the original poster, is that like in life few absolutes exist. If your got your feelings hurt so the original poster could learn a bit more then so be it. Bang bang back at you.
You were more interested in showing us how smart you are. No one on the job cares about your education, what matters is the ability to asses deficiencies, and find suitable corrections.
Jimmy
Have a beer let your hair down and enjoy what you have. With some moderation of you attitude you might make it as an inspector some day.
Old 03-28-2008, 05:06 PM
you are the most immature person ever. I am 22 and have 6 years welding experience HANDS ON EXPERIENCE so don't think you know me. i could give a (s)hit about you frankly. people like you make people not want to comment or talk on here in fear that you will cut them down or tell them they aren't good enough. i AM a welder thank you.
Old 03-28-2008, 05:44 PM
ironken's Avatar
6 years isn't all that much.....looks like you are digging pretty deep to come up with 6 years at that! Heck, I struck my first arc when I was about 10...should I count that toward my years of experience? If I do, that puts me at 24 years of experience, but, reality sets in and I simply count years being full-time employed and doing it....I certified and began compensation at 21. See how easy that was. What you are getting is reaction from a couple of guys here that call bull**** on ya. You burst onto the scene here tossing out the 'ol, "I gotta degree," crap and spouting scripture from books. Maybe you should look at yourself and how you present yourself. I work with a few females. The gals that are humble are the ones that I trust to handle tasks and they do well. The females that come off like you do are the ones that wet the bed when it comes time to perform. You come here like you have something to prove.....you've shown your hand.
Old 03-28-2008, 06:07 PM
Miss. I don't know you I simply pointed out that you had either misspoke or misinformed another member. If you can not accept being corrected how the heck do you think you are going to survive in in this business, or life for that matter.
We all screw up the smart one admits it and takes responsibility, learns the error and moves on. You are too caught up in your emotions for your own good.
How you figure I am immature is beyond me I talk in calm rational tone, I define my perspective, I admit I am offering an opinion. You talk in definitives and absolutes.
Chill out kid you are only 22 still wet behind the ears, you do have valuable information stuck in that head you mouth is not letting us hear it.
Comment all you like I'll call BS on you or any one else I see misleading other members.
I don't know it all I am smart enough to know this are you?
Jimmy
If you were not engaged I would think you had a crush on me
Old 03-28-2008, 07:31 PM
WOW!!! this thread went off topic QUICK
Old 03-28-2008, 07:35 PM
Sorry all!
Old 03-28-2008, 08:24 PM
daddy's Avatar
daddy daddy is offline
WooooHoooo! Internet fight!
Since I don't have anywhere near Jimmy's experience and qualifications, or Lynn's education, and am probably about half way between their ages, I deem myself qualified to comment here.
Lynn, If you are interested in rubbing people the wrong way and being self righteous, you are doing fine. If you want to earn the respect of forum members and help those less informed than you are, may I suggest a different tack? (That there's a boatin' word I looked up in my dicshunarry)
Jimmy, With due respect and deference to your years of experience and knowledge, may I humbly suggest that you go a bit easier on the kid? I agree on calling her out on any mistakes, but a bit more tact might keep the discussion civil and help the original poster more. She reminds me of my little sister, I feel obligated to stick up for her a bit
Have a drink on me...
Old 03-28-2008, 11:08 PM
Well Daddy you are overqualified and thanks for speaking up.
As well your point is taken and will be implemented.
now as for that drink I think I will
Jimmy
