it exploded
I was cutting steal for a swap meet bike trailer and my cutoff saw wheel exploded
only minor cuts and make shore your vice is tight
Re: it exploded
that will get your attention real quick...lol
Re: it exploded
That has happened to me before.
I think it happens when your saw, or the metal you are sawing, gets slightly angled. So, like you said, make sure your vise is tight.
The Welder Shop has great deals and reviews on Hobart, Miller and Lincoln Welders. |
Re: it exploded
Any of you who use a gas powered demo saw with a steel abrasive blade, they also explode if they have gotten wet in the past. Most of the ones I have seen grenade, were ones that had gotten wet in the past then dried out. I have no idea why but we throw any away that come in contact with water.
Re: it exploded
TxRedneck a former mod here was hurt pretty badly by an exploding grinding wheel...He ended up with a nice set of stitches and a vacation to go with it. Ever since his run-in I have been very cautious around those things. I had a HF 9" grinder bind up on my once. Luckily, the wheel shards went away from me, but it kicked like a horse right into my over-sized gut.
Smithboy... if it ain't broke, you ain't tryin'. |
Re: it exploded
I revved it up to start the cut, as I touched the blade to the work, it exploded. I missed the shrapnel and hung on, because the vibration from the now unbalanced blade, was as bad as the blade break. Needless to say it happened fast. I don't know exactly how, but the saw's arm actually broke. I may still have the saw; if I do, I'll post pictures. It's a miracle I wasn't hurt. I became extremely shy of the saws; can hardly remember using one since. It's a good habit to try not to be in direct line with any spinning objects; especially at start-up. |
Re: it exploded
I know the max RPM for gas saw abrasive blades is different from chop saw abrasive blades. I can not remember which is faster the demo saw or the chop saw. I do know you will immediately see the blade flex and wobble if you put the wrong one in the saw. I am sure detonation is not far behind.
Re: it exploded
Especially when I first fire up any abrasive wheel that I haven't just used, I make sure I am not in line with the path of destruction. I have never had one break... yet.
I have managed to get a 4" wire wheel intmately involved with my sweatshirt though. It stopped my milwaukee grinder immediately and felt like someone had punched me. No big injury, but I developed a bit more respect for that particular tool.
Re: it exploded
Last year I was cutting some 2" X 1/8" wall mild steel tubing with my 14" home brewed, belt-driven cutoff saw. About half way through, a piece of the disc came off and jammed the cut. I quickly turned the power off and all was well. The broken piece was nicely contained by my floating homemade guard that covers about 60% of the blade.
I always wear safety glasses and stand to one side. Those safety guards really work. The blade was a proper Norton metal cutter with some wear on it. I guess it developed a nick during the cut. I always look at the blade before starting a cut. You can never tell what will happen. |
Re: it exploded
My experience has been the destruction starts with just a little nick first, then can happen suddenly at any time after. Harbor Freight blades nick easily.
