Old 12-05-2004, 03:34 PM
neversatisfied neversatisfied is offline
weld bead is ''peaking''
Just picked up a new miller 210 machine and went to lay some beads down and they seem to peak.like with every weave there is a small ''mountain peak'' of metal.If i turn the machine up it will burn nicely but has the long arrow appearence to the bead.I am trying to get a nice ''stacked coin'' beads.Does this have anything to do with the metal?its 1/4'' stock,a little rust flash on it.Thanks for any help,sorry no pics yet,cam is bad.thanks guys!
Old 12-05-2004, 04:41 PM
DDA52's Avatar
DDA52 DDA52 is offline
It sounds like you need to get the travel speed fine tuned. If you are going too slow, the weld metal will pile up as well as when the wire speed is too high. Give it some practice time. New machines need an adjustment time period so you can get used to them. Use the door chart to get you started with the settings, and adjust from there. They will be close, but may need some tweaking.
Old 12-05-2004, 10:17 PM
hankj's Avatar
hankj hankj is offline
A high bead profile is usually associated with a stickout or travel speed problem. On weaves, I hesitate on the high and low sides and move quickly through the center.
Hank
Old 12-08-2004, 06:47 AM
Dan Dan is offline
first of all, you want your basemetal to be brite and shiny no rust or millscale when ever possible. Now, to produce the stacked coins look, you can t use the doorchart settings for 1/4". Drop down to the 3/16" or 1/8" settings to perform the oscillation needed to produce the weld bead your after.
ESAB Migmaster 250
MM 210
Hobart Ironman 230
Hobart Handler 210 MVP
HH125EZ - nice little fluxcore only unit
PM 180C
Maxstar 150 STH - very nice
Old 12-09-2004, 07:35 AM
Thanks alot guys.I will try it out.Its nice going from my old machines to this new one just to get it all dialed in now.thanks again!
